Thread started 25 Mar 2013 (Monday) 07:47
580 ex I or II vs Yongnuo yn568ex
Martin ­ Dixon
Gallery: 59 photos
Joined Sep 2009
Mar 25, 2013 07:47 |  #1
Is the yn568ex a way way better deal than a 580ex I or II?
Does it do everything the 580 ex II does?
Small issues with colour balance?
Lack of power port.
I have a 430ex ii and 580EX ii (use as master of short or possibly long cord) and am mulling over getting a (low cost?) 3rd flash for very amateur indoor work (most set-ups seem to need 3 light sources). I am thinking ETTL mainly. Possible experiments with HSS and rear-curtain etc.
I see there are similar threads I could have revived, but I think my query is slightly different to warrant a new topic.
flickr (external link) Editing OK (external link)
Alex_Venom
Mar 25, 2013 08:39 |  #2
That depends on your needs.
The 568 is a great unit for the price. It does ALMOST everything the 580EXII do, but not everything.
It is built cheaper, you get no weather sealing, no power port and you never know the compatibility with future bodies.
That said, everything else is pretty good and for the price of one 580EX II you can get almost 3 568's. so thats your call:
Do you need (and are willing to pay extra for) the better build, probably longer lifespan, weather sealing and power port of the 568EX II?
I have both units and if I would start again, I'd get more 568's and no 580. But that's me.
Photography is about GEAR and not talent or practice. Practice won't make you a better photographer. Expensive equipment will. =D
"Nobody can buy a scalpel and become a doctor, but anyone can buy a camera and become a photographer."
gremlin75
Mar 25, 2013 12:42 |  #3
Martin Dixon wrote in post #15752683 (external link)
No. The yn568ex is less powerful, does not have a master function, does not have a distance scale, does not have an external battery port, and is not weather sealed (that's all I can think off off the to of my head)
With that said the yn568ex is a good flash. Is it equal to the 580ex II? No, it's actually closer to the 430ex II (with a tiny bit more power).
As long as you won't miss the things it doesn't have then it's a good alternative, but not a direct alternitive.
Alex_Venom
Mar 25, 2013 13:15 |  #4
gremlin75 wrote in post #15753711 (external link)
Curious.
My experiments with the 568 against my 580 showed the 568 a bit more powerful than the 580!
Calibration perhaps?
gremlin75
Mar 25, 2013 13:53 |  #5
Alex_Venom wrote in post #15753829 (external link)
Curious.
From what I've been told the 568ex has the same output as the 565ex and the 565ex tested at a lower power output then the 580exII
http://speedlights.net …iew/#Guide-Number-Testing (external link)
If the 568ex does have a higer output then the 565ex and 580ex II then awesome, the 568ex is the flash I use. Like I said, I've only been told the 565ex and 568ex have the same output, I do not have a meter to test them myself.
Alex_Venom
Mar 25, 2013 14:45 |  #6
gremlin75 wrote in post #15753991 (external link)
Well, I didn´t do a much scientific testing myself. Just put both on 1/1 and shot a very dark subject with the same configuration in camera. The 568 appeared brighter but that is all....
Think I might do a better test after reading your link! ;)
gremlin75
Mar 25, 2013 20:41 |  #7
Alex_Venom wrote in post #15754182 (external link)
If you do please post it up. I'd be curious to see if the 568ex is more powerful then the 565ex and 580ex II
Martin ­ Dixon
Gallery: 59 photos
Joined Sep 2009
Mar 26, 2013 04:43 |  #8
Gide numbers both 58m - same?!
Pupu
Mar 26, 2013 04:53 |  #9
Actual test GN numbers of YN flashes are less compared to their official specs. There is a discussion thread in flickr on YN565 / YN 568 power vs Canon 580. From the discussion, it seems both these YN flashes are comparable to Canon 430. 58m for YN flashes are misguiding.
Note: I dont have either of these flashes, I'm saying based on numerous post on internet on this topic.
550D gripped I Sigma 50mm F1.4 (Non Art) I Canon 100mm F2.0 I Nissin Di622 Mk II I YN 622C triggers I...and few other accessories
gremlin75
Mar 26, 2013 17:44 |  #10
Martin Dixon wrote in post #15756421 (external link)
Company's tend to over state their guide numbers. Click on the link I posted earlier so see actual tested GN and meter readings (though the 568ex has not been tested or reviewed by that site yet)
watt100
Mar 26, 2013 18:04 |  #11
if you have a smart phone get one of those light meter apps (free!) and measure the lux or foot candles or whatever
https://play.google.co​m …=com.bti.lightM​eter&hl=en (external link)
PUREBRAD
Mar 27, 2013 15:40 as a reply to  @ watt100's post |  #12
Just my two cents...Unless you are very highly experienced with your current flashes to the point where you can notice the very subtle differences in power between them, then you are not going to notice much (if any) power difference with the 565 / 568 Yongnuo units.
This is why there are some many conflicting responses here... The power output is similar in strength.
For purposes of intent, the flashes produce "around" the same power and the differences between them are most likely to be noticed only by those who have very critical eyes. For the other 95% of us, the power will seem the same.
50D / 28-1.8 / 100-2.8L / 200-2.8L / YN565Ex
Martin ­ Dixon
Gallery: 59 photos
Joined Sep 2009
Jul 05, 2013 11:48 |  #13
Got my YN568EX and I'm impressed so far. To check the colour and max power output I took these tests - looks like there is a detectible blue tinge to the Yongnuo, but I don't believe this is noticeable. It is less powerful than the 580 EX II- pretty close to 2/3 stop (ie putting max power - 2/3 on 580EX II is close to the YN of full.
IMAGE: http://m-dixon.com/potn/fullpower.jpg
This is ETTL mode - as expected the balance seems fine:
IMAGE: http://m-dixon.com/potn/ettl.jpg
mamaof2
Gallery: 10 photos
Joined May 2014
Jan 09, 2015 07:36 as a reply to  @ Martin Dixon's post |  #14
Are you still happy with your flash? I am trying to decide if I should go with the Canon 430 EX II or the one you bought YN568EX.
Thanks!
Jessi
T4i/Nifty fifty/ 18-55/ DCR 250 macro attachment/ 55-250 stm/ Few old film lenses
GeeMack
Gallery: 10 photos
Jan 09, 2015 07:51 |  #15
I can't speak for Martin but I'm very happy with my YN568EX II. However my next flash will be their YN600EX RT so I can eventually do away with my YN622Cs.
7D, 50 f1.8, 17-55 f2.8, 70-200 f2.8 II, 100-400 f4.5-5.6L, 2x TC III, 580EX II, 430EX, 568EX II, 622C
glmphotos.zenfolio.com (external link)
8,021 views & 0 likes for this thread
version 2.0 /
Latest registered member is insurfr
808 guests, 433 members online
