Thread started 14 Apr 2013 (Sunday) 17:43
Slipping command dial 50D
Mavgirl
Joined Mar 2013
Apr 14, 2013 17:43 |  #1
My trusty 50D is having problems. When I turn the command dial (the one by the shutter release) it slips sometimes. I have to press really hard on it to make it actually change the settings. It feels like the rubber around the dial is slipping.
So, my question, has anyone here popped open a body to repair a problem like this? Or am I better off sending it in for repair? It seems like it would be an easy repair but I've never done more than cleaning on a DSLR and I'm hesitant to dig in to it without knowing what I'd be in for.
Thanks for any advice y'all have.
6D/50D/350D with too many lenses
Calumet 4x5, Pentax SV 35mm, Canon A-1, Rebel G and many more toys...
yogestee
Apr 14, 2013 22:17 |  #2
My 50D does this also, I'm thinking dust.
What I've done in the past is a few good blows from rocket blower which has worked. I have also given a few good blows out of my mouth (be carful not to spit) which has cleared the problem.
I also use a grip so in real emergencies I use the dial on my grip. After a couple of goes, this problem often clears itself.
Jurgen
50D~700D~EOS M~G11~S95~GoPro Hero4 Silver
Mavgirl
Joined Mar 2013
Apr 14, 2013 23:27 as a reply to  @ yogestee's post |  #3
Thanks, I'll try the air.
Getting a grip is my backup plan. I've avoided them because I have hands the size of a ten year old. But I think I'd rather do that than a repair right now since I'm about to get a new body.
mjww
Apr 15, 2013 21:46 |  #4
I had that problem with my 30D and the solution is to peel back the little rubber cover. The rubber part looks like a "[" and the disc of the switch is "----". So the whole switch look like this [----] Clean with rubbing alcohol on a Q-tip if you see any dirt or oils from your hands (should be clean). Place a tiny bit of Goop on a toothpick and get it between the rubber ring and the plastic disc of the rotary switch. Repeat around the rotary switch as many times as you can. Let it dry for 24 hrs and it should be as good as new. My repair has lasted 2 years so far. Hope this helps.
Equipment list - According to the wife - "how many more lenses do you need? Yet another camera?"  ???
Mavgirl
Joined Mar 2013
Apr 16, 2013 09:00 as a reply to  @ mjww's post |  #5
mjww.. Which Goop adhesive worked? The household one?
I tried my Rocket Blower on it and it didn't help.
mjww
Apr 16, 2013 21:08 |  #6
I used either household or automotive (the two I usually keep in stock). Either one should work.
1,365 views & 0 likes for this thread
Latest registered member is abrahamf
1012 guests, 429 members online
