Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Compact Digitals by Canon
Reply
Thread Tools Display Modes
Old 15th of January 2006 (Sun)   #1
Loading
Default How many on/off cycles for A610
I just got a A610 about a month ago. It seems like the lens extension/retraction would be a fairly 'wear' heavy item, so I try to avoid turning the camera on for just one shot.
If I wanna take a shot of something, I try to plan it so I can take pictures of lots of things, in a brief time span.
I'd feel a lot better if I knew what Canon specd the lens retract/extend life to, and how many times you guys have used yours. Zooming sorta falls into the same category, as that moves the lens about.
Thanks.
Loading is offline   Reply With Quote
Old 16th of January 2006 (Mon)   #2
nwyman
nwyman's Avatar
Default Re: How many on/off cycles for A610
I think you're worrying unnecessarily - if it's gonna' go, it'll go.
And, you might take careful note of this particular feature, only to have something else break down - you know, Murphy's Law and all that. So just go out and shoot already! And pray that if something happens, it happens while the camera is still under warranty.
Nancy
nwyman is offline   Reply With Quote
Old 16th of January 2006 (Mon)   #3
adas
adas's Avatar
The lens gearing is not as fragile as you might think, (or as it may sound )
If you're not bumping the lens, it will work long.
adas is offline   Reply With Quote
Old 16th of January 2006 (Mon)   #4
boboy888
boboy888's Avatar
I bought my s400 almost 4 yrs ago and one year i literally was using it everyday for 6 months,it has your usual wear and tear and its still clicking away.Had one lockup of the lense wouldnt retract,removing the battery reset everything back.
20D(70-300,50);EOS 630(35-135);Minolta Hi-Matic 7S;Powershot S400
My Flickr Page
Click Here and Join the POTN flickr Group Today!
boboy888 is offline   Reply With Quote
Old 17th of January 2006 (Tue)   #5
supergoat
supergoat's Avatar
the a610 has a good lens motor. It seems better than the old powershot series. Not sure why, but it just seems like a better piece.
Canon 50D | 430exII Speedlite
Canon 50mm 1.8, Sigma 24-70 F2.8 EX HSM
supergoat is offline   Reply With Quote
Old 28th of January 2006 (Sat)   #6
denyed
My lens is pretty loud... just got the camera today and when I zoom out it's loud. Another thing I noticed with the A610 is when I go from video mode and go around through the night, portrait shots way to get to auto, auto turns into video mode. But if I were to go the opposite way past custom, TV, AV etc., it goes to auto, anyone experience this problem and should I bring it back. Or is this correct? Thanks!
denyed is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
How many shutter cycles is high? and yours is?? PEACHMAN Canon EOS Digital Cameras 86 1st of July 2008 (Tue) 01:50
Shutter Cycles jsanz11 Canon EOS Digital Cameras 17 17th of April 2008 (Thu) 18:01
Shutter Cycles? totalbeginner Canon EOS Digital Cameras 1 18th of July 2007 (Wed) 09:57
CCS Cycles R Mutt Motorsports 8 18th of May 2007 (Fri) 21:03
Determining shutter cycles bwolford Canon EOS Digital Cameras 1 9th of August 2006 (Wed) 13:52
