Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > General Photography Talk
Reply
Thread Tools Display Modes
Old 17th of January 2006 (Tue)   #1
pepsirich
pepsirich's Avatar
Default Still tryin to get basketball right
I still can't seem to nail basketball. I have to push ISO to 3200 to get speeds above 250. I really struggle with hitting the focus point perfectly. I have the camera set to center point focus and I use custom function to focus with the thumb seperate from the shutter button. Any suggestions?
Sorry, I can't get the pics to attach right now
www.richardkimberley.com
50D|20D| 28-135IS | 17-55 IS 2.8 | 70-200 IS 2.8L | 50 1.4 | 85 1.8 | 24-85 3.5 | 11-18 2.8 |2xtc | (2) Speedlite 580EXII and 430EX
pepsirich is offline   Reply With Quote
Old 18th of January 2006 (Wed)   #2
smassey
Default Re: Still tryin to get basketball right
What is the lighting like in the gym, and what more are you shooting in?
Sean Massey
Massey Photography
Canon 20D
Canon Digital Rebel XT (backup)
Canon 70-200 f/2.8L
Canon 50mm f/1.4
Sigma 28-105 f/2.8-4.0
Epson Stylus Photo R1800 Printer
smassey is offline   Reply With Quote
Old 18th of January 2006 (Wed)   #3
liza
User is banned from forums
Must be an awfully dark gym. Which lens are you using?
liza is offline   Reply With Quote
Old 18th of January 2006 (Wed)   #4
Transportithere
Transportithere's Avatar
Use lots of megapixs, take alot of photos and crop.
POTN is a wonderful source of information.
POTN has taken me around the world.
Transportithere is offline   Reply With Quote
Old 19th of January 2006 (Thu)   #5
gmen
gmen's Avatar
I've visited a couple of your galleries and, yep, the images are dark.
However, I would suggest that some simple work in PS, even just on the levels, would improve the overall brightness of the images.
If you're shooting at ISO3200 then it certainly must be a dark gym. There is not much you can do without adding some light of your own via flash/strobes. Of course this may not be allowed. If it is feasible (consult with the players and officials), here are some thoughts on how to do it with an on-camera flash:
http://www.photography-on-the.net/fo...sketball+flash
You are correct to use the centre point only for AF.
If you are not getting good results with the AF set to the * button, then go back to using the shutter release. The * button technique does not work for everyone. There is a lot of hype about the * button... but only use that technique if you are 100% comfortable with it. I will use the * button for some sports and not for others, it's horses for courses.
Good luck with your next shoot.
---- Gavin
gmen is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Tryin black and white....again CheetaPita Critique Corner 2 10th of June 2007 (Sun) 18:34
Tryin' to make a buck.... Elisabeth-Ann Urban Life & Travel 8 11th of March 2006 (Sat) 18:06
I'm still tryin to get a Dragon Headshot. rockyc2 Macro 8 24th of August 2005 (Wed) 02:54
Tryin' 2 Get Better - Need Input! mlivingstone Critique Corner 11 8th of April 2004 (Thu) 13:42
Newbie tryin' to get some skills bigdave Critique Corner 2 18th of September 2002 (Wed) 21:23
