#1 |
Formerly known as Bluedog_XT
It uses more memory to record the image and as for me If I'm shooting RAW (which is 99.99% of the time) I'm going to post process the image any way _ to some extent. If using RAW it basically doesn't matter what the color and sharpening are set at but it does help for the user to have the exposure at least fairly close to right. I just don't see the need for RAW + JPEG.
Canon EOS 7D | Canon EF-S 10-22mm | Canon 17-40mm f/4L | Canon 24-105mm f/4L IS Canon PowerShot S95 MY PBASE GALLERY Last edited by Tsmith : 20th of January 2006 (Fri) at 07:09. |
| sponsored links |
#2 |
I always shoot RAW+small JPG, then use the small JPGs to browse through and get a feel for which shots I want to process from RAW. I find it easier (and faster) that way than trying to browse through the RAW files themselves.
They're also big enough to print as 6 x 4's as proofs. |
#3 |
I shoot RAW all of the time now and find browsing my shots easy using Raw Shooter Premium - It has a good slideshow feature and whilst viewing them you can 'mark' and catagorise images for later post-processing - RAW+jpg just seems a waste of memory card to me, although to be fair if you select the small jpg's this is not a real problem as they are so small.
-- K e v i n -- Nikon D700, 17-35mm, 28-105mm, 70-200mmVR, 50mm f/1.4 Canon EOS 3, 24-105L, 135L |
| sponsored links |
#4 |
I don't use them that often ... I just find them faster to browse through than the RAWs, plus if someone wants to have a quick look at all the shots from a particular day (albeit unedited), I just give them a copy of the JPGs - or just run off some quick 6 x 4's.
I've never run out of CF card space, so whether they chew up a bit of space is a non-issue to me. |
#5 |
We use RAW plus large JPG. Some images don't need much post-processing and the JPG file can be used instead of the RAW. Also, I make contact sheets of the shots, so the JPG files are used for those.
Eating up memory cards is not an issue - pop in another card while we download full card to an Epson P2000. cheers, jim
www.pix2go.ca Sometimes I do get to places just when God is ready to have somebody click the shutter. - Ansel Adams |
#6 |
"Scut Farkus"
Often when I shoot an a capella concert I shoot RAW+small jpeg and immediately give the group a cd of the jpegs to look at while I post-process. This is a way for them to get back to me about specific shots they are interested in before I process the majority of the images (not to mention that it's a neat slideshow for their post-concert party).
Cody Goddard www.artmadewithcraft.com Thanks in advance for comments and criticism. CAMERAS! I USE CAMERAS! |
#7 |
I'm not sure how the XT handles RAW in camera, but on my G6, RAW+Large jpeg allows you to zoom in to the image (in playback mode) to examine detail. Otherwise, the camera simply generates a jpeg thumbnail the size of the LCD, and what you see is what you got until you can get back to a computer.
I didn't find that the difference (in terms of # images per card) was significant, so I enabled +Large.
7D, G10, 17-55 f/2.8 IS, 70-200 f/2.8 IS, 100 Macro, 50 f/1.4, 430EX II There are no wrong notes --Thelonious Monk |
| Thread Tools | |
| Display Modes | |
| Do you shoot in RAW or JPEG? | lyssa615 | The Business of Photography | 15 | 2nd of February 2007 (Fri) 10:18 |
| What Benefit To Shoot in both RAW and JPEG | CanonConcord | RAW, Post Processing and Printing | 5 | 1st of June 2006 (Thu) 10:05 |
| Why shoot RAW + JPEG? | pitabread | Canon EOS Digital Cameras | 16 | 6th of December 2005 (Tue) 07:48 |
| Do you shoot Raw or L JPEG? | dennykyser | Canon EOS Digital Cameras | 40 | 14th of February 2004 (Sat) 16:13 |
| Shoot Raw Or JPEG ? | CJMORGAN59 | Canon G-series Digital Cameras | 14 | 30th of April 2002 (Tue) 17:05 |
