Thread started 06 Jun 2013 (Thursday) 11:40
Prev/next
YongNuo 622c & Multiple Cameras
ShotByTom
ShotByTom's Avatar
Indianapolis
Jun 06, 2013 11:40 |  #1
When my partner and I shoot wedding receptions we put 2 flashes on stands with 622's, and have a flash on camera as well. We tried this setup this past weekend but couldn't get it to work with 2 cameras.
We tried setting his camera to fire ch 1 and mine to fire ch 2, and set the two ocf to CH1 & CH2. We couldn't get this to work with both cameras. Does anyone know if this set up will work?
Gear
Websiteexternal link
v35skyline
San Diego, CA
Jun 06, 2013 12:49 |  #2
If I understand the way the YN-622c works, then C1 and C2 are both lit, that indicates the tranceiver is on the 4th channel. It does not mean it can be fired by a YN-622c on C1 and another on C2.
From how I understand...
C1 lit = Channel 1 (same for C2 and C3, respectively)
C1 + C2 lit = Channel 4
C1 + C3 = Channel 5
C2 + C3 = Channel 6
C1 + C2 + C3 = Channel 7
Someone correct me if I'm wrong.
I'm not sure how the YN-622c works. I wonder if it can detect what mode to be in (transmitter or receiver). If the YN-622c can detect it is on a camera and be set to a transmitter only mode, that would be cool. So all transceivers would be on the same channel and when you fire your shutter/flashes, your partner's on-camera flash isn't triggered because the YN-622c it's on is acting only as a transmitter.
I only have one camera (and it's not even in front of me), so I can't really test this out...would be curious to know the outcome, though.
X100s | X-Pro1 | X-T1 | XF 14 | XF 18 | XF 35 | XF 56 | XF 60 | XF 10-24
Gear List & Feedback
tagnal
Bay Area, CA
Jun 06, 2013 16:58 |  #3
From CliveyBoy's TOYUG:
Two-Shooter Setup (John UK technique)
A second shooter can share augmenting flashes. There is a problem – preventing the zooming and firing of the other camera’s on-top flash.
· Camera 1 set to E-TTL or Manual, and Firing Group A:B at some ratio/power.
· On-camera 622 set to Remote mode and Group C, with an on-top flash.
· Camera 2 set up the same.
· Enhancing flash stand with remote 622 set to Group B, plus flash.
· When either camera takes a shot, it's on-top flash is treated as Group A, the augmenting flash as Group B, and the other camera as Group C. Group C is not enabled in Firing Group A:B, so does not fire.
http://photography-on-the.net ...hp?p=14791737&postc​ount=1
5D3 / M3 / S100 / Σ 35 Art / 50 1.8 / 135 L / 17-40 L / 24-70 L / 70-200 f/4 IS L / m 22 2.0 / 580ex II
Toy List | flickr (external link) | FAA (external link)
CliveyBoy
R.I.P.      He will be missed
CliveyBoy's Avatar
Joined Nov 2005
Tauranga, NZ
Jun 08, 2013 01:12 |  #4
v35skyline wrote in post #16005955external link
C1 + C3 = Channel 5
C2 + C3 = Channel 6
Correct.
The YN-622C is always in Receiver mode, except when on a camera AND on camera startup, flash control menus open, quick panel open, or 1/2-shutter. So, at other times it is a receiver and the on-top flash acts as a remote using the group setting on its 622.
John UK's solution is the right configuration for two photog's using shared augmenting lighting.
Clive, and Great G/D Abbie
50D; 580EXII, 430EXII, 550EX, YN685EX; YN-622C II, YN622C-TX and YN560-TX controllers TOYUG II v5.10 YN622 System Guide (external link)
I tried retiring, but gave it up - it's a dead end
ShotByTom
ShotByTom's Avatar
Indianapolis
Jun 08, 2013 09:02 |  #5
Thanks so much for the responses, I was pretty sure it was possible, just not sure how to do it so I'll give this a try.
Gear
nicksan
Man I Like to Fart
nicksan's Avatar
NYC
Jun 08, 2013 23:45 as a reply to ShotByTom's post |  #6
I purchased these last week and tested them out at a wedding. Wished I read this before hand! I had a second shooter with me and we were having some mysterious flash exposure issues. Turns out we were triggering each other's on-camera flashes. Hahaha. Anyways, we temporarily solved it by changing channels on the off-camera lighting and using one of each.
I finally got to test the "workaround" at home and while at first it was a little difficult to understand how things exactly worked, I managed to get it working.
Example scenario:
2 x 5D3+YN-622+600EX
1 x YN-622 + 600EX on a light stand.
  • YN-622 that is mounted on the 5D3 uses Group C.
  • Via the 5D3's flash menu, set it to fire for A:B.
  • YN-622 that is on the light stand is set to Group B.
So I am guessing that the YN-622 that is on the 5D3 is receiving on C and transmitting on A & B. Since nothing is "listening" for Group C, nothing is fired. Same with Group A, at least radio-wise. According to the document, the speedlight that is mounted on top of the YN-622 that is mounted on the 5D3 will be Group A. (?)
Something like that? :lol:
NYC Wedding Photographerexternal link | Blogexternal link | facebookexternal link | Flickrexternal link | Gear
CliveyBoy
CliveyBoy's Avatar
Joined Nov 2005
Tauranga, NZ
Jun 09, 2013 00:04 |  #7
To repeat post #3:
Each on-top flash is handled as group A by its own camera; its flash head is considered to be the light-emitting component of the "Master Flash". The 622C is the Master.
When the transmitting flash is idle, it is a receiver. Each on-top flash then reacts to a fire instruction from another camera. If the 622 on the other camera is set to group \C, and the current camera is set to firing group A:B, then a group C flash will not fire.
This is all standard Canon, plus the effect of momentary change of the 622C to transmitter state.
Read TOYUG p.10 - see link in my signature.
nicksan
Man I Like to Fart
nicksan's Avatar
NYC
Jun 09, 2013 09:31 as a reply to CliveyBoy's post |  #8
OK, so I have things working where 2 shooters can use the remote OCF and not trigger eachother's on-camera flashes.
Is it accurate to say that in this scenario, there can really only be one OCF group since A is on-camera flash and C is off-limits (so that on-camera flash doesn't get triggered)?
Another question is say shooter #1 adjusts the power on the OCF from the camera. Let's say he dials in -2 FEC. When shooter #2 shoots, will this still take effect or would whatever shooter #2 has set the camera to, for example +1 EC take effect?
**Figured this out myself. It works as expected. Camera #1 & #2 retain whatever flash power values they have.
deltroid
deltroid's Avatar
Porto Alegre, RS - Brazil
Mar 20, 2017 09:39 as a reply to nicksan's post |  #9
I'm having the same issues, but I'm not getting the same results by following the "John UK technique". And here's why...
I'll use nicksan's example scenario:
Both YN-622's mounted on a 5D3 are set to Group C...BUT....when you set the 5D3s' in camera flash menu to fire for groups A:B only, the YN-622 automatically changes itself to group B. And if I change the group on the YN-622 back to group C, the in-camera flash menu automatically changes itself to fire for groups A:B C.
This totally ruins the solution for me, because I cannot keep the YN-622's on camera set to group C.
Also, I prefer to use all YN-622's in MIX CONTROL MODE, which allows me to independently change settings to each flash without influencing the others.
For example:
1 x 5D3+YN-622+600EX set to E-TTL
1 x 5D3+YN-622+600EX set to MANUAL (1/64)
1 x YN-622 + 600EX on a light stand set to MANUAL (1/32).
Can anyone shed some light...?
Fay
5D mk III | 5D mk II |Canon 15 f/2.8 fishy | Canon 24-70 f/2.8L | Sigma 35 1.4 ART | Canon 85 1.8 | Canon 135 f/2L | 580 EX II | Yn-600Ex-RT
Faytography
 (external link)
deltroid
deltroid's Avatar
Post has been edited 11 months ago by deltroid.
Mar 20, 2017 10:04 |  #10
Ok, so I did some more testing, and it turns out it does work...I just had to get a deeper understanding of the YN-622's.
I repeated all the steps in my previous post, to set everything up.
This is what I learned: Even though selecting to fire only groups A:B in the in-camera menu changes the group on the YN-622 from C to B automatically, once you half-press the shutter button on one of the cameras (which are now in group B according to the YN-622 mounted on it), the YN-622 on the other camera automatically goes to group C and does NOT fire. Yay! :-D
That's very clever, but very complex.
Wouldn't it be easier just to allow the receiving YN-622 (with the flash on lightstand, for example) to be in two channels or two groups at once?
Anyhow, I love this forum, and this is one of the main reasons why...it's an amazing source of knowledge.
Thanks!
Fay
Faytography
 (external link)
1,893 views & 0 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.00188 for 4 database queries.
PAGE COMPLETED IN 0.08s
Latest registered member is Gmacs
824 guests, 379 members online
