Thread started 09 Jun 2013 (Sunday) 09:08
Best battery for speedlight in fast continuous shots
mrmarks
Jun 09, 2013 09:08 |  #1
Is there any good AA battery or battery pack (preferably rechargeable) that will allow fast recharge times for fast continuous shots? I have tested sanyo eneloops and the recharge rate is too slow. Thanks for the inputs.
PacAce
Joined Feb 2003
Jun 09, 2013 09:32 |  #2
mrmarks wrote in post #16013691 (external link)
You need an external battery pack in order to decrease the flash recycling time. Also, the lower the flash output, the faster the recycling will be. Just be warned that continuous shooting without letting the flash cool down can lead to a flash malfunction. The newer Speedlites, though, do have thermal shutdown circuits to protect the flash from a thermal meltdown. :)
...Leo
mrmarks
Jun 09, 2013 09:35 |  #3
I am currently using the 600ex-rt. I think this has the thermal shutdown protection? Which external battery pack would you recommend? Hope this is not heavy. Thanks!
PacAce
Joined Feb 2003
Jun 09, 2013 10:02 |  #4
mrmarks wrote in post #16013769 (external link)
I use the Canon CP-E4 and the Quantum Turbo 2x2 for my Speedlites. However, there are other 3rd party options available although I don't have any experience with any of those.
Take a read through the following thread for more suggestions:
http://photography-on-the.net …/showthread.php​?t=1304652
...Leo
dmward
Gallery: 28 photos
Jun 09, 2013 16:01 |  #5
Cheetah Stand has a nice Lithium battery with ports for two speedlites. And it will last forever. (Well at least for a large number or flashes.)
As mentioned, when the speedlite reaches a thermal threshold, the screen goes orange and the recycle time goes way up. If you want rapid recycle for continous burst keep it below 1/4 power and keep the burst to about 5. Then wait a bit before next burst.
1/4 to 1/8th power seem to deliver near instantaneous recycle. If you plan ETTL high ISO, wide aperture and close to subject.
Whortleberry
Joined Dec 2011
Jun 09, 2013 16:51 |  #6
As per David Ward's post - the Cheetah L4500 (link) (external link) / Godox PB960 (different link) (external link) (depending on where you are - you seem to be keeping it secret) is currently hugely popular.
If you look in your Canon destruction book for your flash unit, you will see warnings about overheating. They generally run along the lines of "no more than 15 full power flashes". The thermal cut-out slows things down by lengthening the recycle time but it's still, I am told, possible to overheat things to the point where it stops playing altogether for a while till it has cooled down.
The Pixel TD381 is my favourite among the AA battery packs (as per original request). Seemingly the same as all the others, it benefits from using 2 seperate banks of 4 AAs. That way, if a single cell fails, you still have a functioning battery pack albeit at a marginally slower rate of recycle.
No matter what batteries or rechargeables you put into the flash unit battery compartment, you cannot speed up recycling that way. The only way to do that is with an external power pack delivering circa 330 volts. It's a matter of voltage and the circuitry attached to the battery compartment limits output to roughly 6 volts no matter what you cram in there. DON'T be tempted to put the higher voltage Lithium AAs into the battery compartment unless you like expensive burning smells.
Phil ǁ Kershaw Soho Reflex: 4¼" Ross Xpres, 6½" Aldis, Super XX/ABC Pyro in 24 DDS, HP3/Meritol Metol in RFH, Johnson 'Scales' brand flash powder. Kodak Duo Six-20/Verichrome Pan. Other odd bits over the decades, simply to get the job done - not merely to polish and brag about cos I'm too mean to buy the polish!
FlickR (external link) ◄► "The Other Yongnuo User Guide v4.12" by Clive Bolton (external link) ◄► UK Railway Photographs 1906-79 (external link)
mrmarks
Jun 09, 2013 18:42 |  #7
dmward wrote in post #16014635 (external link)
Does the 600ex-rt record or display the emitted flash power level in ETTL mode?
PhotoMatte
Gallery: 22 photos
Jun 09, 2013 20:20 |  #8
The 600EX-RT does indeed have hair-trigger thermal protection; it's much faster than on any other Canon speedlight I've used. Even with the Canon BP-E4 battery pack or the Quantum Turbo 3 battery pack (for Canon), I've still had the 600EX-RT enter the 'shutdown' mode after only 3 or 4 shots when firing at full power (but this has only ever happened when I'm using an on-camera 600EX-RT to fire a couple remote 600EX-RTs in bright sunlight--and I'm using a 5D3, so everything should be compatible).
the site (external link)
the blog (external link)
Smugmug (external link)
My gear: Canon, Macintosh, Adobe
PhotoMatte
Gallery: 22 photos
Jun 09, 2013 20:25 |  #9
Whortleberry wrote in post #16014742 (external link)
This is all I ever used until I got the 600EX-RT (I put the lithiums into my flash and into my Canon battery pack). I never had any thermal shutdown issues with my 550, 580 or 580EXII flashes while using Energizer lithiums. I did have an issue with thermal shutdown on the 600EX-RT almost immediately so I invested in 36 Eneloop batteries and a fast MAHA 8-cell charger...but still encountered the thermal shutdown on the 600EX-RT. If I attach my Quantum Turbo 3 to my on-camera flash, the issue seems to go away, no matter what batteries I have in the flash itself.
Whortleberry
Joined Dec 2011
Jun 10, 2013 05:17 |  #10
PhotoMatte wrote in post #16015283 (external link)
I was perhaps rather too sweeping in my assertion to not use Lithiums - APOLOGIES for the lack of clarity. I guess that's what you get with over-generalisations :oops:. In mitigation, though, at least what I suggested was safe for your gear. Perhaps instead of "don't be tempted to use the higher-voltage Lithium AAs...", I should have stressed the HIGHER VOLTAGE aspect and explained sizing - especially with folks now wanting to make their own battery packs.
There are certain AA-sized Lithiums which are truly 1.5v output - the Energizer Lithiums are one example - and these are safe of course. This type, the Lithium-Iron disulphide chemistry - LiFeS2 - produces a single use primary battery which IS safe to use - so long as you actually READ the specifications and are aware of the requirements. Unfortunately, there are identical sized Lithium ION (notice the differentiation between ION and IRON) secondary batteries (what we call rechargeables) which use Lithium Iron Phosphate - LiFePO4 - with a nominal voltage of circa 3.7v and they can go up to 4+v. These are USUALLY built-up as battery packs and include a voltage regulator circuit, either in the pack itself or in the appliance circuitry.
They are, unfortunately for the unwary, also found as loose single AA sized cells and it's this size similarity which can catch folks out. "Oh, wow. really high powered AA cells, rechargeable too - they'll be great. BANG."
It's at least partly our fault as, lazy blighters that we are, we tend to lump all cells of this type together as "Lithiums". That name is really a FAMILY of battery-types and not just a single chemistry - it's a bit like saying a Wright bi-plane is the same as a Boeing 787 is the same as an F-16 because they're all aircraft! We're familiar with Lithium rechargeable (ie 'secondary') batteries for our cameras - 2 x 3.7v LiFePO4 cells = 7.4v as per the (eg) Canon LP-E6 - so anything 'Lithium' must be OK. It may be OK, and it may not - we have to rub both our remaining brain cells together and check voltage as well.
So, let's try this one. Don't be tempted to use the HIGHER VOLTAGE Lithium rechargeables which you may come across. The oft-quoted invocation to READ THE INSTRUCTIONS (and specification) definitely applies.
'Thermal shut-down' is a designed-in function of the flash and the way it's used. Firing the flash sends a pulse of energy through the tube. This generates light (the bit we want) and HEAT (unwanted by-product). It's the secondary function, this generation of heat, which causes the thermal protection to come into play. Another sweeping generalisation for you - it's not the batteries you put in the flash which causes thermal cut-out/shutdown/protectio​n, it's the itchy finger you put on the shutter release. ;)
Which now leaves scope for a myriad of "Ah, well, I've always ..........." replies. :rolleyes:
bobbyz
Jun 10, 2013 08:53 |  #11
What are you trying to shoot? Since you mention eTTL, what is your shooting apertures, ISO etc.
5dmk3, 35L, 85L II, 300mm f2.8 IS I, 400mm f5.6
Fuji XT-1, 14mm f2.8, 23mm f1.4, 35mm f1.4, 56mm f1.2, 90mm f2, 50-140mm f2.8
dmward
Gallery: 28 photos
Jun 10, 2013 09:20 |  #12
mrmarks wrote in post #16015013 (external link)
No, the power range reference is from testing. I use manual speedlite settings to test output in an environment and to get an idea of recycle times. ETTL is going to determine the power output on a shot by shot basis.
I also use manual 1/1 as a quick check on battery state in my external AA packs. i.e. switch speedlite to M 1/1 and press the test fire button. If it takes longer than normal for the ready light to come on, its time to replace the batteries.
2,773 views & 0 likes for this thread
version 2.0 /
Latest registered member is MsDeen
750 guests, 390 members online
