Reply
Thread Tools Display Modes
Old 1st of July 2003 (Tue)   #1
Deckyon
Deckyon's Avatar
Default Need some opinions...
Came across this in a search for photo screens. Anyone think this is worth it, or would it be cheaper to make on my own?
http://www.ezcube.com/
Seems pretty neat, but also a bit expensive, especially the lights, considering I could get a couple tabletop lamps for $30 each.
Thanks,
Brad Buskey
http://www.sturmphoto.com
Canon EOS 1D Mark II
Canon EOS 20D
Canon EF L Lenses
Omega View 45F Monorail View Camera
Deckyon is offline   Reply With Quote
Old 1st of July 2003 (Tue)   #2
slejhamer
slejhamer's Avatar
Default Re: Need some opinions...
I made one with a large cardboard box (top removed and large holes cut in two adjacent sides.) Painted the inside flat white. Covered the holes with frosted shower curtain material. Before shooting, I line the box with a piece of thin white or black posterboard, depending on the desired effect. Cost: somewhere between free and US$15, depending on what you have laying around.
I took THIS in the box, with a couple of lights outside.
The one for sale is collapsable and easily portable, though. Yours would always be a big box.
Mitch
slejhamer is offline   Reply With Quote
Old 1st of July 2003 (Tue)   #3
Deckyon
Deckyon's Avatar
My wife is a great seamstress, and she has made laundry baskets that collapse like that, so I dont think it would be too hard to recreate that as well... I imagine that nylon would be a decent material to cover it with.
Real question was with the lamps. Would 2 or 3 desk lamps provide the same quality as something like they have?
Thanks,
Brad Buskey
Canon EOS 20D
Canon EF L Lenses
Old 1st of July 2003 (Tue)   #4
pukkita
deckyon, the lamps doesn't have anything special, but the lightbulbs.
As long as the lamps you get can stand the heat, they'll suffice.
You could even use another kind of bulbs provided you don't mix them: hallogen (beware, they generate heat) or whatever.
Simply include a gray card on one of the shots and shoot RAW to later get the right color temp and you'll be done.
If yoo finally build the tent at home, make provisions for more holes to shoot from, something like this http://www.bhphotovideo.com/bnh2/con...#goto_itemInfo
pukkita is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Opinions on this... ib2loud The Business of Photography 14 13th of May 2007 (Sun) 22:17
I need a few opinions please Sp00ks Transportation 18 8th of December 2006 (Fri) 17:11
Opinions please rab3rd Canon EF and EF-S Lenses 11 23rd of December 2005 (Fri) 15:04
Would like your opinions morenoar Critique Corner 2 27th of February 2004 (Fri) 17:53
