Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > General Photography Talk
Reply
Thread Tools Display Modes
Old 1st of July 2003 (Tue)   #1
shamrock838
Default Mini-Table-Top Macro Setup
Greetings ...
I'm looking to set up a small, no-frills, table-top macro "studio" that can be easily set up and kocked down. I have a Canon D-60 with EOS 100mm macro lens.
For lighting I'm thinking of two free-standing, small-footprint, mini hi-intensity lights that I can move around at will. Brand names ... models #s ...availability?
Of ancillary interest is a small (10-12") circular rotatable "table" on which to mount my subjects. Again ... brand names ... model #s ... availability?
Everything here is spelled small-scale in a space-conscious environment.
Suggestions? Many thanks,
M i k e
shamrock838 is offline   Reply With Quote
Old 16th of July 2003 (Wed)   #2
Derek Smith
Default Re: Mini-Table-Top Macro Setup
Hi Mike,
I use a Cannon 10D with a Sigma 105mm 2.8 Macro, a Cannon 550EX on a small tripod and two PortaFlash 336VM Studio flash units.
For a subject stand, I use a laboratory stand, a universal joint and a flask clamp to hold and position the subject ( usually a piece of plant ).
For reflectors, I use artboard or Foamex offcuts, it's light and easily held in place with some Bluetak. They also stand in as backdrops
Not quite mini as it can take up the space of a large tabletop.
Derek Smith is offline   Reply With Quote
Old 16th of July 2003 (Wed)   #3
excessnoise
shamrock838 wrote:
Greetings ...
M i k e
You might check out EZ Cube at http://store.yahoo.com/greenbatterie...topstudac.html
I bought the large but they have a small size cube.
excessnoise is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
mini/table top tripod azpix Accessories & Storage 6 23rd of April 2007 (Mon) 21:55
Table Top Suite AV Mode Still Life, B/W & Experimental 5 3rd of January 2007 (Wed) 21:15
Table Top Photos AV Mode Still Life, B/W & Experimental 7 3rd of January 2007 (Wed) 16:30
Table top tripod ungx0013 Accessories & Storage 3 11th of September 2006 (Mon) 22:55
first try on table top photography clengster_77 Critique Corner 3 18th of April 2006 (Tue) 04:08
