Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Accessories & Storage
Reply
Thread Tools Display Modes
Old 2nd of July 2003 (Wed)   #1
Ratfink
Ratfink's Avatar
Default Tiffen Infrared Filter 87 & D10
Has anyone use the Tiffen Infrared 87 filter on a D10 yet? If so what were the results? I was also wondering how the Tiffen 87 compares to the Hoya R72 when used on a D10.
Ratfink is offline   Reply With Quote
Old 3rd of July 2003 (Thu)   #2
carnagex2000
Default Re: Tiffen Infrared Filter 87 & D10
Ive read about them here:
http://www.photo.net/bboard/q-and-a-...?msg_id=004nrn
example:
http://www.photo.net/bboard/big-imag...ad_id=12155584
carnagex2000 is offline   Reply With Quote
Old 3rd of July 2003 (Thu)   #3
mattchase
I have used my 10d with an IR filter from Harris and Harris (it is supposed to be about the same as a Tiffen RM72 filter). It does work, my exposures were ISO 100 around 4-6 seconds at 5.6, in bright desert sunshine. Here are a couple of examples...
color photo converted to B&W
http://www.matthewchase.com/forum/ir1b.jpg
color photo shot with IR filter, converted to B&W
http://www.matthewchase.com/forum/ir1a.jpg
Notice the leaves and grass have turned white. Also, the details in the mountains are much clearer. These two shots were taken about 2 minutes apart, with the only changes being the additional of the IR filter and the adjustment of the exposure for that filter.
And with a little help in Photoshop, you can get a false color image going...
http://www.matthewchase.com/forum/ir01.jpg
mattchase is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
