Thread started 18 Jul 2013 (Thursday) 22:59
Does anyone make one of these for the 600EX-RT?
dmward
Gallery: 28 photos
Jul 18, 2013 22:59 |  #1
HERE (external link)
Its the replacement foot for a Canon 580EX that Lon at Flash Zebra.
I had these mounted on my 580EXs and loved them.
Would love to have one for my 600EX-RT if its available somewhere.
symbolphoto
Joined Nov 2005
Jul 18, 2013 23:17 |  #2
I see where you are going with this. :)
Boston Wedding Photographer (external link) | Flickr (external link) | Gear
jonneymendoza
Jul 19, 2013 04:00 |  #3
symbolphoto wrote in post #16133491 (external link)
and where is he going?
Canon 5dmkIII | Canon 85L 1.2 | Sigma 35mm ART 1.4|Canon 16-35mm L 2.8 |Canon 24-70mm L f2.8 | Canon 70-200mm F2.8L MK2 | Canon 430EX MK2 Flickr (external link)
FlyingPhotog
Cream of the "Prop"
Jul 19, 2013 04:23 |  #4
Why do you need the mini-jack?
I assume the 600 has a PC port, yes?
Jay
frugivore
Gallery: 11 photos
Jul 19, 2013 07:03 |  #5
FlyingPhotog wrote in post #16133909 (external link)
To use it in manual mode together with his monolights? I want some too please!
Trailboy
Jul 19, 2013 07:19 |  #6
Because the PC port on the flash is input, not output.
digital ­ paradise
Gallery: 10 photos
Jul 19, 2013 08:58 |  #7
This person may be able to do this mod for you if you send the flash there. They do all types of mods.
http://michaelbass.blo​gspot.ca (external link)
Image Editing OK
symbolphoto
Joined Nov 2005
Jul 19, 2013 09:10 as a reply to  @ symbolphoto's post |  #8
jonneymendoza wrote in post #16133875 (external link)
I believe it's in conjunction with a Cheetah product.
dmward
Gallery: 28 photos
Jul 19, 2013 10:05 |  #9
symbolphoto wrote in post #16134403 (external link)
A bit broader than just Cheetah Lights. :-)
There are times when I want to fire other strobes with the 600EX-RT on camera controlling others. And it the modded foot would fit an STE3 even better. :-)
I have, for example, 6 older speedlites that I can use in manual mode with the 600EXs. That means 10 speedlites. but having a second trigger hanging off the side of my camera is a bit of a clug. Thus this question. I was reminded about how nice this mod was when I saw the way Jim Coleman had his setup for firing his CL-180s with a 580EX on camera for close fill.
Thanks for the Bass suggestion. I'd forgotten about him, I was hoping that someone had started doing this in a production mode.
I have a broken foot, maybe its worth fiddling with to see if I can figure out the wiring. :-)
Or, better, I'd be happy to send it to someone who really knows what they're doing. :-)
drvnbysound
Jul 19, 2013 10:12 |  #10
How does that foot resolve this?
dmward wrote in post #16134572 (external link)
I use manual exposure settings on the copy machine
..::Gear Listing::.. --==Feedback==--
...A few umbrella brackets I own...
butterfly2937
Gallery: 201 photos
Jul 19, 2013 13:30 as a reply to  @ drvnbysound's post |  #11
Why can't you use the camera's sync port?
GEAR
The ­ Loft ­ Studios
Jul 19, 2013 15:08 as a reply to  @ butterfly2937's post |  #12
I'm interested in knowing where and how the "modded foot" resolves the problem of firing other lights. I too owned (at one time) 8 Canon 580EXII's flashes with the PC Sync Port and had no problems firing it in manual mode either as a Master (meaning I had a receiver of some sort plugged into the PC Port) or as a slave (meaning I had an optical sync that plugged into the PC Port)..... I now have 4 Canon 600EX's and still use the procedure stated above with no issues. Maybe I'm missing something that you leaving out, Dave. Can you elaborate why you would like the modded foot over the OEM?
MARK
frugivore
Gallery: 11 photos
Jul 19, 2013 16:27 |  #13
butterfly2937 wrote in post #16135136 (external link)
I am wondering this also, now that I think about it. I have used a flash on the hot shoe with a CST stuck to the flash using Velcro with the PC sync to mini jack cord plugging into the CST. This fires both the flash and the mono lights that I have set up.
butterfly2937
Gallery: 201 photos
Jul 19, 2013 16:45 as a reply to  @ frugivore's post |  #14
I have used a phottix odin transmitter in the hot shoe and a 580 EX II on a ProMedia Gear flash bracket and a CyberSync transmitter in the camera sync port to fire Einstein strobes. This gives me complete control of both flashes and strobes plus focus assist if needed in very low light. I have CC in my pocket to adjust power on the strobes. Couldn't you use a similiar setup for Cheetah lights. Does the Cheetah transmitter have the option of connecting to the camera sync port?
GEAR
dmward
Gallery: 28 photos
Jul 19, 2013 19:17 |  #15
All of the various methods you are describing work. I've used them.
The 600EX-RT PC port is only to fire the 600EX-RT with an external trigger. It does not deliver a fire signal to an attached trigger.
Plugging a cable into the camera works and I've been using that approach when I need duel system triggering. To make that work I've then used a velcro strip to attach the trigger to the camera strap.
I hadn't really thought too much about its disadvantages until I dug out the 580 foot to give to an associate after we shot a wedding together and I saw his CST attached to a bracket attached to his camera with the CST in a hot shoe with a short cable plugged into the PC port on the camera. That reminded me of how handy it was to have flash and trigger as a single package that could be put on the camera by sliding the speedlite into the hot shoe.
If there were a way to easily make the PC connection on the 600EX-RT two way that would work as well.
3,638 views & 0 likes for this thread
version 2.0 /
Latest registered member is ppahv
751 guests, 369 members online
