Thread started 20 Jul 2013 (Saturday) 21:50
Why no focal reducer
Rstanford
Jul 20, 2013 21:50 |  #1
Does anyone know why canon or anyone else for that matter does not make focal reducer? Wouldn't you like to turn your 50 1.4 into a 35 f1.0 or close to it.
krb
Jul 20, 2013 21:53 |  #2
Lack of demand is probably the largest issue. I suspect that there are technical issues with making them work well on the wide angle lenses where such a tool would be desired.
-- Ken
Gear list
Jon
Joined Jun 2004
Jul 20, 2013 21:59 |  #3
Well, technically there are - they're called "close-up lenses" and they screw onto the front of your lens. The drawback is that they also take away infinity focus. There are a very few rear-mounting examples of this; one of which is the 1:1 adapter for the 50 mm f/2.5 macro (which focuses to 1:2 without the adapter; the adapter lets it focus to 1:1, and will also let other lenses focus closer than normal).
Jon
Cocker Spaniels
sapearl
Gallery: 63 photos
Jul 20, 2013 22:03 |  #4
They seem to be popular among astronomers. Some do cause an amount of vignetting though.
MY WEBSITE (external link)- MY GALLERIES (external link)- MY BLOG (external link)
Artists Archives of the Western Reserve (external link) - Board
Wilt
Jul 20, 2013 22:31 |  #5
The only focal length reducer that mounts on the rear of the lens I have ever heard of is one which only reduces the size of the image circle to a smaller format coverage, in order to both produce more angle of view.
You need to give me OK to edit your image and repost! Keep POTN alive and well with member support http://photography-on-the.net/forum/donate.p​hp
Rstanford
Jul 20, 2013 22:58 |  #6
http://www.engadget.co​m …edbooster-ef-nex-adapter/ (external link)
"increasing the speed of a lens by a full stop. That may sound impossible, but it apparently works by concentrating the extra light-gathering area of a full-frame lens down to the smaller E-mount sensor area, turning an f4.0 lens into an f2.8 lens,"
Wilt
Jul 20, 2013 22:59 |  #7
This not only talks about the FL reducer, but in the first paragraph mentions what inherently has made that difficult up until now...
http://www.sansmirror.​com …reducer-lens-adapter.html (external link)
Rstanford
Jul 20, 2013 23:51 |  #8
This is the direction canon needs to go in, they need to make a small sensor dslr in a small frame like the eos-m and make a focal reducer. then we can have below f1 lenses.
tkbslc
Jul 21, 2013 00:03 |  #9
You can't make a focal reducer for EF lenses to work on an EOS camera. The way they work requires space for the focal reducer to fit in the optical path, which only works adapting to significantly shallower mounts. They can make one to use EF lenses on a NEX because the mount depth is about 26mm difference. You also require a larger imaging circle, so you'd have to use a FF lens on a APS-C body, or a medium format lens on a FF body, etc.
Taylor
60D | ELPH 330 | iPhone 5s
tkbslc
Jul 21, 2013 00:06 |  #10
Rstanford wrote in post #16138966 (external link)
But since you have to go to a smaller sensor for them to work, you take away effective aperture. All it does is get you back to where you would be if you used the lens on a FF camera in the first place.
Also, the attractiveness of a small camera like the EOS-M diminishes rapidly with adapters and larger FF lenses.
Taylor
Rstanford
Jul 21, 2013 00:10 |  #11
If thats not what I said thats what I meant, they need a smaller sensor in a small frame dslr camera.
maverick75
Joined May 2012
Jul 21, 2013 00:15 |  #12
Cameras are getting better and better at high ISO that I think lens manufacturer are going to stop trying to make them faster.
ElectronGuru
Jul 21, 2013 09:03 |  #13
maverick75 wrote in post #16139002 (external link)
The relevance of big apertures is changing. The point used to be compensating for slow ISO. With that disappearing, the relevance will be DOF. If shallow DOF is not worth it for customers, they will stop buying them and manufacturers will stop making them. If shallow DOF is worth it, manufacturers will not stop. When I show someone a photo of them taken at 1.2, they get all excited and ask what camera I'm using. What they really want to know is how do I get a fast lens.
Tying back into topic: as tkbslc notes above, reducers seem to be creating equivalency with FF, not really gaining an advantage. You're shrinking the projected light as you're shrinking the sensor. 1.4 becomes 1.0 in brightness (concentrated light), but not shallow DOF. 1.4 on FF will look like 1.4 on crop + reducer, just with less of the ISO than would normally be needed.
"Light is the paint, lenses are brush, sensors are the canvas"
6D | 100L Macro | 50L | 24L TSE
Builder of custom flashlights, OVEREADY.com (external link)
maverick75
Joined May 2012
Jul 21, 2013 17:19 |  #14
Well all know aperture is not the only thing that controls DOF....
Rstanford
Jul 21, 2013 21:33 |  #15
It also improves sharpness in the center.
2,577 views & 0 likes for this thread
version 2.0 /
Latest registered member is Cliodiver
707 guests, 424 members online
