Thread started 30 Jul 2013 (Tuesday) 17:04
The best battery pack for 600 EX-RT? Turbo SC Slim?
nathan_wong
Joined Oct 2012
Jul 30, 2013 17:04 |  #1
Hi,
I am a wedding photographer and have been using CP-E4 battery packs for my 600 EX-RT. The recycle time is ok but I often find myself running out of juices towards the end of the wedding. (I do a lot of Indian weddings and they are LONG...). Wondering if anyone has experience using 600 EX-RT with more powerful batter packs like Turbo SC Slim? I don't really want to use strobes as they are not as flexible as 600 EX-RT.. Thoughts?
Thanks!
dmward
Gallery: 28 photos
Jul 30, 2013 17:48 |  #2
Nathan,
I have just recently started to use Cheetah 4500 (external link) pack with speedlites. They offer loads of energy. Small, relatively light and you can even get a second battery if you want that slides onto the control section.
It also has two outputs if you for some reason want to carry two cameras with speedlites on them.
I got turned onto this while beta testing the Cells-IIc trigger for Edward.
The ­ Loft ­ Studios
Jul 30, 2013 18:08 |  #3
nathan_wong wrote in post #16167678 (external link)
Hi,
Thanks!
•Purchase several sets of rechargeables (assuming that is what you are using) and change them out when necessary..... $25+
•Purchase another Battery Pack Magazine "INSERT" and already have a fresh set of batteries ready to go and swap them out quickly (less than 30 seconds)..... $75+
•Purchase a Cheetah Litium-Ion Battery Pack..... $200+
•Purchase one of the nicer Quantum Battery Packs.....$300-$600
Since I use the Canon Battery Packs like yourself (I have 4 of them along with 48 recharbles), I'm never concerned about my battery life for my flashes.....
MARK
dmward
Gallery: 28 photos
Jul 30, 2013 18:15 |  #4
The Loft Studios wrote in post #16167838 (external link)
Mark,
I agree. I have 6 Pixel packs, extra trays, from packs that failed for one reason or another, and enough batteries to refill each flash and tray at least twice. If I hadn't gotten the 4500 with a Cheetah Light, I'd still be using the packs and rechargeable AAs.
I have associates still using the Quantum SLA turbos. All work. The 4500 is just easier to use for long events since it just keeps truckin' :-)
Jul 30, 2013 19:16 |  #5
dmward wrote in post #16167856 (external link)
Agree with the Cheetah Battery Pack, Dave just haven't had the "real" need to get one..... but it's coming soon, probably by years end! And I'm afraid I won't want just one, gotta buy in pairs, LOL.
MARK
dmward
Gallery: 28 photos
Jul 30, 2013 23:32 |  #6
The Loft Studios wrote in post #16168034 (external link)
When you break down and get one, or two, get the flash cable with it. Also, get a one of these (external link), its longer and springier. I can put the pack in my back pocket and still have easy movement with the camera.
Jul 31, 2013 03:20 |  #7
dmward wrote in post #16168586 (external link)
Cool..... Thanks!
MARK
JakAHearts
Gallery: 6 photos
Jul 31, 2013 06:59 |  #8
Another option, though pricier than the Cheetah, is the Calumet powerblock 900. I bought one a bit ago and so far I love it. Recharge at full power on my 580exii is about 1 second. I used it last weekend for a wedding and shot around 700 shots with it at higher power levels. (the ceiling was high and the walls were wide) :D
http://www.calumetphot​o.com …earchterm:power​block|9000 (external link)
Shane
nathan_wong
Joined Oct 2012
Jul 31, 2013 09:41 |  #9
Great information so far guys, thank you! I will look into the Cheetah and the Camulet! (seem like Camulet powerblock 900 -- $249.99 -- is actually slightly more expensive than the Cheetah -- $215).
Ideally, I would love to not have to replace batteries in the middle of the event. 700 shots is not enough for me.. sometime, my wedding last as long as 16 hours and I need to be able to fire considerably more than 700 shots! I usually fire speedlite at 1/16 but sometime I need more power to overpower the ambience light or create some interesting looks.. With CP-E4, it works ok but it seem like towards the end I have to wait longer for my speedlites to recycle and I miss some good shots sometime.
The thing is I set up 4 lights at every corner of the reception area so I have to buy 4 of these battery packs!
dmward
Gallery: 28 photos
Jul 31, 2013 09:59 |  #10
There is also this option: http://www.linkdelight​.com …USB-Output-for-Canon.html (external link)
It works, but its not very well made and if there is a problem its a throw away considering the Chinese source and difficulty getting warranty support. Cables short and stiff so it pulls out of the jack easily, power switch is easy to hit, turning the battery off. It has 4 LED charge indicators. The 4th (full charge) indicator has never lit for me.
Whortleberry
Joined Dec 2011
Jul 31, 2013 11:31 |  #11
A few small points of difference I notice comparing the Cheetah and the Calumet. I feel that any small price difference is inconsequential relative to the amount of service each would potentially provide.
CHEETAH
  1. Lithium battery - the accepted norm for this type of battery is a 5 year life cycle.
  2. Spare battery supply available at extra cost. (Not currently (31 July 2013) listed by CheetahStand but definitely available, if not from Cheetah then definitely HERE (external link) although I'd definitely check with CheetahStand FIRST IF you are in the USA - you coyly don't say).
  3. One battery chamber could be charged while second in use.
  4. Any future failed battery could be replaced easily, if ever required, without losing the whole power pack.
  5. TWO power outlets as standard - option to use 2-to-1 cable and halve recycling time (at your own risk as it's designed for the Godox Witstro / CheetahLight flashes :lol:).
  6. Bayonet-fit cables don't pull out of power pack.
  7. Claimed 900+ full-power flashes per charge. Apply your own degree of scepticism to claimed number in both cases.
  8. No in-car charger available. Not exactly vital, I'd personally like to have the option though; to many I appreciate it could be totally unimportant.
CALUMET - (in the same order)
  1. Nickel metal hydride battery - the reliable norm for this type of battery is a 2 year life cycle. Yes, I appreciate that they often last much longer - as too may Lithium cells similarly.
  2. Fixed internal battery with no quick change option.
  3. Charge or use option - unclear if it could be used while simultaneously charging.
  4. Any future failed battery would necessitate surgery or replacing the whole unit.
  5. ONE power outlet as standard.
  6. Push-fit cable connection may possibly pull out of power pack (see David Ward's note re the alternative Sky Eagle PB3000 from Link Delight which uses similar DIN plugs.)
  7. Claimed 500 full-power flashes per charge. Again apply your own degree of scepticism to this figure!
  8. In-car charger included.
With those points in mind, I know which I would spend money on. ;) Both are, like the Sky Eagle, Chinese-sourced but both come with impeccable after-sales service so no worries on that score - the Cheetah service is especially highly regarded by members here..
Phil ǁ Kershaw Soho Reflex: 4¼" Ross Xpres, 6½" Aldis, Super XX/ABC Pyro in 24 DDS, HP3/Meritol Metol in RFH, Johnson 'Scales' brand flash powder. Kodak Duo Six-20/Verichrome Pan. Other odd bits over the decades, simply to get the job done - not merely to polish and brag about cos I'm too mean to buy the polish!
FlickR (external link) ◄► "The Other Yongnuo User Guide v4.12" by Clive Bolton (external link) ◄► UK Railway Photographs 1906-79 (external link)
nathan_wong
Joined Oct 2012
Jul 31, 2013 11:46 |  #12
Whortleberry wrote in post #16169810 (external link)
CHEETAH
Oh man.. you made this choice too simple to pick!
nathan_wong
Joined Oct 2012
Jul 31, 2013 12:03 |  #13
gotta love that Chinese guy in Cheetah 4500 video!
JakAHearts
Gallery: 6 photos
Jul 31, 2013 13:13 |  #14
That would be Edward! He owns/operates Cheetah and is one stand up dude. I didnt realize Cheetah had such a product or I would have purchased theirs. Oh well, the Calumet works just fine and they have a store 2 minutes from my house.
Shane
Roshan
Joined Feb 2013
Jul 31, 2013 19:37 as a reply to  @ JakAHearts's post |  #15
Didn't want to start a new thread. I'm in the same boat. Just bought the 600ex rt a week ago.
http://www.bhphotovide​o.com …act_Battery_Pac​k_for.html (external link)
Is this a good battery pack to use?
16,940 views & 0 likes for this thread
version 2.0 /
Latest registered member is HBGPhotos
631 guests, 414 members online
