Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > General Photography Talk
Reply
Thread Tools Display Modes
Old 25th of January 2006 (Wed)   #1
FlipsidE
FlipsidE's Avatar
Default Medium Format?
Seeing that I hope to be shooting mostly models and hopefully mostly in a studio not too far into the future, I'm curious about Medium Format photography.
Now, one thing I will say is that I probably would've gotten much deeper into photography a long time ago had it not been for film. Developing costs, handling, etc. Plus, I'm an absolute gadget freak.
But, for some reason, Medium Format has just got me so incredibly interested...esp for the kinds of shots I intend to be taking. I've been considering buying a used Mamiya 645 or 645 Pro off eBay just to have around for the occasional use. The problem is...I know nothing about film, the different types of film stock, or how to use filters with film to get white balance correct.
In my case, would looking for an inexpensive Medium Format system be worth the effort? Or should I just wait until Medium Format digital backs become somewhat affordable?
Thanks in advance
FlipsidE
FlipsidE is offline   Reply With Quote
Old 25th of January 2006 (Wed)   #2
Longwatcher
obsolete as of this post
Longwatcher's Avatar
Default Re: Medium Format?
I would say (having a hassleblad that sits on the shelf)
You should get really good with what you have first and then when you just can't get anything better from what you have then go up a level.
In my opinion a 1DsMkII competes with MF film cameras for color photography. It is only in B+W where MF film is still obviously superior. Most portrait and model photography will be in color so not gaining a lot there.
All that said if I had the money to spare I would have a 39MP digital back in my hands for doing my model shoots. But I don't have $22,000+ for MF, I barely afforded the 1DsMkII. Heck even my 10D worked to some extent. I think the lenses make more of a difference then the camera after a certain point.
So use your current camera until it just doesn't for it for you any more. Then you are ready.
"Save the model, Save the camera, The Photographer can be repaired"
www.longwatcher.com
1DsMkIII as primary camera with f2.8L zooms and the 85L
http://www.longwatcher.com/photoequipment.htm
Longwatcher is offline   Reply With Quote
Old 25th of January 2006 (Wed)   #3
Wilt
Wilt's Avatar
White balance, before digital, was supremely simple for the typical photographer...
Buy daylight film, shoot in daylight or with flash. Buy tungsten-balanced film, shoot under tungsten lights. Shooting under fluorescent lighting, get a 10M filter and the result is 'close enough' to get rid much of the greenish tint, especially since every fluorestcent tube is a bit different in color output! Shoot color neg film, and let the lab deal with color balance! Only digital made photographers widely anal about WB (although pros shooting fim could sometimes be anal about WB, too).
Getting Med Format is not merely about resolution (which is where 1D2MkII can compete with MF). It is also about the absolute tonality and the realism of larger format slides. In photo workshops I personally have experienced "Oooooh! Ahhhhh!" when 35mm photographers collective see my medium format slides projected onto the same projection screen, at the same size their 35mm slides were projected, because of the better tonality and realism.
Medium format can also SLOW YOU DOWN so you are not machine gunning shots thru like with the digital camera. It makes you THINK about the shot before you take it, rather than merely getting photos a 2fps-5fps...if you want to shoot everything at that rate, bring a movie camera!!! The slower pace allows you to understand better, to debate the merits of one approach vs. the other and then decide what you want to create, not merely record at 5fps.
Wilt is offline   Reply With Quote
Old 25th of January 2006 (Wed)   #4
Mark_Cohran
Moderator
Mark_Cohran's Avatar
I agree with Wilt. Medium Format, and to a greater extent, Large Format, require a slower pace and more deliberate process than shooting with digital. I use a Mamiya 645 Pro TL and it's absolutely great for studio work or landscapes when I want the best resolution I can get for prints or slides. But, with only 12 shots to a roll of 120 film, the process has to be thoughtful and deliberate, or you're going to waste those shots.
Mark
Mark
Some primes, some zooms, some Ls, some bodies and they all play nice together.
Thirty-five years of shooting and still learning.
My G&N Blog (NSFW)- My Complete Gear List - Mac-Photo Website - My Tumblr Site (NSFW)
G&N FORUM EARLY ACCESS & IMAGE POSTING RULES
Mark_Cohran is offline   Reply With Quote
Old 26th of January 2006 (Thu)   #5
condyk
Africa's #1 Tour Guide
condyk's Avatar
This is a fundemental piece of advice about how to really master the craft and your equipment. You don't need a MF camera to do it of course.
Now full! Great African Photo Safari 2013 - Kruger National Park, South Africa click
condyk is offline   Reply With Quote
Old 26th of January 2006 (Thu)   #6
mbze430
mbze430's Avatar
Mark
You sure you only get 12 shots to the 120 on the 645? I usually get 15-16 on a 6x4.5 120...... 12 shots is with a 6x6..... you must be out of practice
My Hub to my personal work (just click on the banners)
mbze430 is offline   Reply With Quote
Old 26th of January 2006 (Thu)   #7
mbze430
mbze430's Avatar
I am pro-MF. Because it gives me much better flexibility in a studio. In anycase I shoot digital in MF as well as film. The amount of stuff I shoot in studio isn't that much. So I still get more useage out of the 1dsmk2 & 1dmk2.
Personally I love the images I get out of my Contax 645 than my 1dsmk2. The DOF is excellent, if you talk to anyone that uses heavily MF, that's the first thing they tell you is how much "seperation" of objects has on MF and LF has.
Old 26th of January 2006 (Thu)   #8
Mark_Cohran
Moderator
Yep - you're right - 15 shots - I am out of practice
I've got two backs, preloaded they give me about 30 shots - but I haven't used the MF in about 9 months.
Mark
Mark
Old 26th of January 2006 (Thu)   #9
Wilt
Wilt's Avatar
>>that's the first thing they tell you is how much "seperation" of objects has on MF and LF has.<<
The landscapers bane is the portraitist's blessing! Longer focal lengths for same FOV as the tiny formats (sub-FF dSLR) overcomes the slow max apertures (and resultant deeper DOF) found with too many zooms on entry level dSLRs.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Medium Format sumozebra Weddings and Other Family Events 17 22nd of June 2007 (Fri) 13:03
I need some help with Medium Format photography and Medium Format film? FlipsidE General Photography Talk 27 24th of December 2006 (Sun) 11:33
Medium Format? flyb0y General Photography Talk 15 12th of May 2006 (Fri) 09:54
5D vs. Medium Format rssfhs Canon EOS Digital Cameras 71 19th of January 2006 (Thu) 23:52
