Thread started 15 Aug 2013 (Thursday) 11:58
OP/TECH Pro strap over shoulder?
wanner
Joined Jul 2013
Aug 15, 2013 11:58 |  #1
A question to everyone with the optech pro / pro loop strap.
Can you quickly and easily access your camera when wearing the strap over your shoulder instead of around your neck?
Reason I'm asking is because black rapid models and similar brands that make sling straps use the tripod mount I figure there must be an advantage to that?
https://www.flickr.com​/photos/malwan/ (external link)
ed ­ rader
"I am not the final word"
Aug 15, 2013 12:38 |  #2
wanner wrote in post #16210425 (external link)
yes but I use http://www.amazon.com …m-Connector/dp/B002R6KZL​O (external link)
and I am broad shouldered so unless you are really huge this should work well for you. black rapid has 0 (zero) appeal to me. I won't hang my camera from one (very expensive) point.
5D4, 80d, 16-35L III, 24-70L II, 70-200L F4 IS, 100-400L II, sigma 15mm FE, 35mm ef-s macro, 430exII, gitzo 3542, gitzo GM4562, markins Q10, markins Q3, kirk, really right stuff
wanner
Joined Jul 2013
Aug 15, 2013 14:24 |  #3
ed rader wrote in post #16210533 (external link)
Yeah, fastening it to the tripod mount doesn't appeal to me either.
However It's not the length that worries me but rather the way it's fastened to the strap (the regular camera strap mounts on each side). What I'm wondering is if it works good to pull the camera from hanging on your side up to your eyes, or I'd the strap will get in the way and you have to rearrange it.
joeblack2022
Joined Sep 2011
Aug 15, 2013 14:31 |  #4
wanner wrote in post #16210859 (external link)
The only way you'll find out is to try it for yourself. I do this with my Optech and it works fine for me. The only thing is that the pad doesn't slide so it is a 2-handed operation for the most part.
It's easier to do with a BR since the camera slides up and down the strap, but the pad slides off too easily unless you spend more money for one of these:
http://www.blackrapid.​com/products/brad (external link)
Joel
ed ­ rader
Aug 15, 2013 15:31 |  #5
[QUOTE=wanner;16210859​]Yeah, fastening it to the tripod mount doesn't appeal to me either.
However It's not the length that worries me but rather the way it's fastened to the strap (the regular camera strap mounts on each side). What I'm wondering is if it works good to pull the camera from hanging on your side up to your eyes, or I'd the strap will get in the way and you have to rearrange it.[/quote]
doesn't cause me any problems. i usually wear my camera this way when i'm walking around. if I am more involved in shooting I just keep the strap around my neck. even on tripod I keep the strap around my neck -- because with extenders it's long enough -- unless I am doing long exposures and there's no one around me.
I would try it first because it's a lot cheaper solution than BR especially when you start adding straps and plates. of course BR to some is a fashion statement ;).
Craign
Gallery: 11 photos
Aug 15, 2013 16:17 |  #6
Works good if shooting landscape, not good for portrait. Much more comfortable than using the OEM strap with my gripped 50D with 70-200 f/2.8 lens. The strap seems to always be over the viewfinder in portrait. I will remove it this winter when shooting basketball, which is nearly always shot in portrait.
Overall: Good value for my needs.
Canon 7D Mark II w/Canon BG-E16 Battery Grip; Canon EOS 50D w/Canon Battery Grip; Canon SL1; Tokina 12mm - 24mm f/4 PRO DX II; Canon EF 24-105mm f/4L IS; Canon EF 70-200mm f/2.8L IS; Canon 70-300mm f/4-5.6L IS; Sigma 85mm f/1.4 EX DG HSM; Canon EF 300mm f/4L IS; Canon EF-S 18-135mm f/3.5-5.6 IS STM; Canon Extender EF 1.4x II; Canon Extender EF 2x II; Canon Speedlite 430EX II Flash
Image Editing Okay
ed ­ rader
Aug 15, 2013 16:40 as a reply to  @ Craign's post |  #7
If you do try the optech I recommend the classic, which is my favorite strap.
joeblack2022
Joined Sep 2011
Aug 15, 2013 16:41 |  #8
Craign wrote in post #16211175 (external link)
Since your body is gripped, have you tried using the bottom strap attachment point on the grip instead of the top right one? It will probably work better in portrait orientation this way.
Also, this way the lens hangs down close to your body and does not stick out.
Joel
CyberDyneSystems
Admin (type T-2000)
Gallery: 79 photos
Joined Apr 2003
Aug 15, 2013 16:41 |  #9
I "wear my camera like a purse" far more often than around my neck, ( like 85%/15% ) and I use Optech/POTN strap.
Works well for me.
CDS' HOT LINKS
Craign
Gallery: 11 photos
Aug 15, 2013 17:11 |  #10
joeblack2022 wrote in post #16211224 (external link)
I use the right camera attachment point and the bottom right grip attachment point. This is not typical. Don't ask why I am using it this way. I might have seen a photo or something on You Tube and then I might have had a dream. It works fine like this as the lens lies next to my body.
I seldom shoot portrait except for basketball. I will remove it and use a hand strap then.
Image Editing Okay
CanonCameraFan
Joined Sep 2011
Aug 15, 2013 19:04 |  #11
Considering all the rave of BR type straps, I bought a Sunsniper from my local store, about $85. High quality, theft resistant, etc. I hated it. The Shoulder portion seemed very heavy, slick and always fell down. Quite annoying, in spite of all I read of the BR lovers and similar. It simply isn't right for me. I missed my Op/Tech straps of years gone by. Well, after seeing they had a Slider version but with their stickier shoulder strap, I had to try it. Loved it!
Advantages were it is lighter, more flexible, comfortable to store and use, easier to maneuver, held at 2 lugs, freed tripod mount for my Manfrotto plate, less bulky both in use and especially in storage, color selection, 15 years previous experience and price (about $25) . Having my camera stolen by a knife wielding snatcher is low on my list of fears/concerns. I like it so much, I am going to get another for my spare. I did buy extensions, and used just 1 of the 2 to get the perfect length for me, even though I'm just of average height.
BTW; on subject of camera being only held at one point: Tripod mount is a risk, but never bothered me (except loss of QD plate). However, even with 2 points of connection with conventional straps, it still has risk of one point of attachment as the main strap it self could slide apart in some manner, unsnap, untie... Not common if properly assembled of course, but just be aware and be certain all is tight, regardless of brand/style!
Op/Tech actually sells a velcro type piece to wrap around it's Military style connectors to assure they never separate. I never had that problem, except one connector when I was in the military, on my TA-50 strap!
EOS 7D w/BG-E7 (3), 550EX (3), 430EX II, Vivitar 285HV, Opteka 6.5mm/3.5, Canon EF-S 10-18/4.5-5.6 IS STM, Canon EF-S 24/2.8 STM, Canon EF 40/2.8 STM, Canon EF 100mm/2.0 USM, Canon EF 70-300mm/4-5.6 L IS USM, Canon 77mm 500D Macro, Tamrac 614 Bag & 787 Backpack, Crumpler 8 MDH, 7 MDH, 6 MDH
http://www.flickr.com/​photos/johnebersole/se​ts/ (external link)
ed ­ rader
Aug 15, 2013 20:04 |  #12
CanonCameraFan wrote in post #16211567 (external link)
an optech that slides? let me go a do a quick google search :cool:.
clacson
Joined Oct 2012
Aug 16, 2013 00:07 |  #13
ed rader wrote in post #16211703 (external link)
Here you have it:
http://optechusa.com …/utility-strap-sling.html (external link)
| Canon EOS 6D | EF 24-105mm f/4L IS USM, EF 40mm f/2.8 STM, Sigma 12-24 f/4.5-5.6 DG II HSM |
| Canon EOS M | EF-M 11-55mm f/3.5-5.6 IS STM, EF-M 55-200mm f/4.5-5.6 IS STM, EOS EF-M adapter |
| Film Age: Canon EOS 33v, Canon EOS 5 |
ed ­ rader
Aug 16, 2013 02:49 |  #14
I looked at that earlier. for $25 i'm going to have to give it a try. looks interesting!
clacson
Joined Oct 2012
Aug 16, 2013 06:49 |  #15
ed rader wrote in post #16212349 (external link)
I made the same decision and ordered mine today.
5,623 views & 0 likes for this thread
version 2.0 /
Latest registered member is dan.potter86
684 guests, 337 members online
