Thread started 18 Sep 2013 (Wednesday) 23:27
Sekonic L478DR and Pocket Wizard Plus
jim35mm
Sep 18, 2013 23:27 |  #1
I have a Seconic L-478DR anda few pocket wizards plus. My flash is a canon 600EX-RT and a Canon 580EX. My problem is I can't get the meter to trigger the flash wirelessly for a reading. Can anyone help?...thanx....Jim
DamianOz
Joined Jul 2011
Sep 19, 2013 06:52 |  #2
Are they using the same frequency?
Bodies - Canon EOS 5DIII | EOS 6D
Primes - TS-E24 f/3.5L II | Σ 35mm F1.4 DG Art | EF 85 f/1.2L II | EF 135 f/2L
Zooms - EF 16-35 f/2.8L II | EF 24-70 f/2.8L II | EF 70-200 f/2.8L IS II | Σ 24-105mm F/4 DG OS Art | Σ 120-300mm F/2.8 DG OS Sport
PacAce
Joined Feb 2003
Sep 19, 2013 07:02 |  #3
jim35mm wrote in post #16308224 (external link)
1) Are the PW Plus units and the Sekonic all set to the same channel (channels 1 through 4 only)?
2) If using the PC port on the EX flashes to connect the PW unit, are the flashes all set to normal flash mode (instead of master or slave mode)? The PC port does not function when the flashes are in slave or master mode.
3) Is the Sekonic set to radio triggering flash mode?
...Leo
jim35mm
Sep 19, 2013 09:30 as a reply to  @ PacAce's post |  #4
The meter is set to flash triggering and the flash and meter both set to ch2
PacAce
Joined Feb 2003
Sep 19, 2013 09:36 |  #5
jim35mm wrote in post #16308919 (external link)
Did you check to see if the PW Plus units are at least receiving the trigger signal from the light meter?
...Leo
digital ­ paradise
Gallery: 10 photos
Sep 19, 2013 09:39 |  #6
My guess is you have a PW receiver the 600 as well? Just in case Canon RT only plays nicely with Canon RT so any Sekonic products will not fire the 600.
Image Editing OK
PacAce
Joined Feb 2003
Sep 19, 2013 09:53 |  #7
The flash? You mean the PW Plus units that're connected to the flashes (600EX-RT and 580EX), right? Or are you doing what Digital Paradise was thinking you're doing in the previous post?
...Leo
The ­ Loft ­ Studios
Sep 19, 2013 10:49 |  #8
Sorry about the simple questions but.....
•Does the meter "actually" have the pocket wizard module. Even though the meter supports pocket wizard, sometimes when people buy a sekonic meter, they assume the module comes with it. It is a separate purchase.
•Make sure that the meter and the pocket wizard receivers are on the same channel
•Make sure that the meter is set to wirelessly fire via the pocket wizard. There are two different firing modes for this feature. One is to set the meter, then the meter waits for a flash to fire, the other is, when the set button is depressed on the meter, it fires the flash wirelessly and reads the power of the flash at the same time.
•You do have the pocket wizards Plus attached to the 600EX and 580EX, right?
Hope this helps.....
MARK
PacAce
Joined Feb 2003
Sep 19, 2013 10:54 |  #9
The Loft Studios wrote in post #16309089 (external link)
It's the "DR" version so it'll have the module in there right out of the box. :)
...Leo
Sep 19, 2013 10:58 |  #10
PacAce wrote in post #16309103 (external link)
Oh, O.K..... learn something new everyday!
MARK
1,609 views & 0 likes for this thread
version 2.0 /
Latest registered member is fishesman
793 guests, 397 members online
