Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > RAW, Post Processing and Printing
Reply
Thread Tools Display Modes
Old 31st of January 2006 (Tue)   #1
russellsnr2
russellsnr2's Avatar
Location: Greek Island of Rhodes.. Ex. Sussex @ Cumbria
Default sharpening
the shot needs a lot of sharpening.
Sorry me again.
The above is an extract from another forum on a photograph i submitted.
What I need to no is what is ment by 'sharpening' within software manipulation.
Below is said photograph.
Many Thanks,
Russell.
russellsnr2 is offline   Reply With Quote
Old 31st of January 2006 (Tue)   #2
jfrancho
jfrancho's Avatar
Default Re: sharpening
Meaning "post process" the image using an image editor to apply some form of sharpening to improve the in camera capture and processing. With your permission, I can show what I mean.
jfrancho is offline   Reply With Quote
Old 31st of January 2006 (Tue)   #3
jfrancho
jfrancho's Avatar
Also, for information the image is tagged as ARGB color, which isn't supported by a web browser, and tends to make the image look dull. Looks beautiful in Photoshop. To present this over the web you should use PS to Edit>Convert with sRGB IEC61966-2.1 as the destination space.
Old 31st of January 2006 (Tue)   #4
subtle_spectre
subtle_spectre's Avatar
About 1 degree of CCW rotation would be nice, as well.
Scott
Vista owner...and user _________________________________________
Gear
www.scottcphotography.com
subtle_spectre is offline   Reply With Quote
Old 31st of January 2006 (Tue)   #5
jfrancho
jfrancho's Avatar
And clone out the dust spots on the sensor...jeez, we're picky.
Old 31st of January 2006 (Tue)   #6
russellsnr2
OK jfrancho,
Please do with as you wish but if you have the time please advise of the changes you make.
Also please confirm that the act of sharpening is applied to the whole image and not just certain parts.
Many Thanks.
Many Thanks,
Russell.
Old 31st of January 2006 (Tue)   #7
jfrancho
jfrancho's Avatar
OK, Workflow:
Opened
Verified color space, Edit>Convert to Profile...Canel
Save as .psd
Image>Mode>16-bits/channel
Image>Mode>Lab color
New Curves Adj. layer
Added saturation to the a* and b* channels
Added contrast via s-curve to L*
Ran TLR Capture Sharpening script: Low Res., Medium, USM, 2, 3, 2, 0, 0
Flatten Image
Image>Mode>RGB color
Crop for rotation using rulers and crop tool
Use the Clone and Patch tools to fix sensor dust
Ran TLR Output Sharpening Script: Web, 800px.
Flatten
Convert to sRGb
Mode>8-bits/channel
Save as .jpeg, quality 12
It's a little over the top, but I wanted to be dramatice to demonstrate the point. There was nothing done locally or selectively using color adjustments and sharpening tools. The clone and patch were local fixes. But for the most part all the data was there for the manipulations.
Old 31st of January 2006 (Tue)   #8
jfrancho
jfrancho's Avatar
Old 31st of January 2006 (Tue)   #9
blue_max
blue_max's Avatar
It's very over-exposed. Sharpening probably makes it worse.
Graham
Lamb dressed as mutton.
blue_max is offline   Reply With Quote
Old 31st of January 2006 (Tue)   #10
Wilt
Wilt's Avatar
jfranco, if you shot film I bet it would be Velvia! A bit overshapened (see water in the foreground...looks quite artificial)
Wilt is online now   Reply With Quote
Old 31st of January 2006 (Tue)   #11
jfrancho
jfrancho's Avatar
Yep, in fact I used shoot slides of tropical fish. Like I said, it's over the top. The OP didn't say "fix this," he said show me some sharpening, plus there was the requirement that it be a global adjustment. Personally I'd crop out most of the water.
Old 31st of January 2006 (Tue)   #12
jfrancho
jfrancho's Avatar
Like this:
Old 31st of January 2006 (Tue)   #13
Wilt
Wilt's Avatar
Hope this attempt to share photo works...never did it this way before, using the location I just used...
Altered Curves, then reduced Saturation, then Unsharp mask with 150/0.3/6 with Photoshop LE (the only thing available on this computer I'm at)
Old 31st of January 2006 (Tue)   #14
Wilt
Wilt's Avatar
OK one more try then I quit trying...
Old 31st of January 2006 (Tue)   #15
russellsnr2
Firstly gents thanks for all the input on this.
Graham :- when you say over exposed do you mean in the 1st instance or after manipulation?
jfrancho:- Thank you for all the work you have put into this, looking at it to me it seems you need to become well versed in photo manipulation as well as learning the in's and out's of photography itself.
Again thanks all.
Many Thanks,
Russell.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Over-Sharpening spcalan RAW, Post Processing and Printing 4 16th of February 2007 (Fri) 19:53
Need Help Sharpening... Dylanlewis2000 RAW, Post Processing and Printing 6 20th of January 2007 (Sat) 01:22
Sharpening Help Tomgt40 RAW, Post Processing and Printing 5 14th of August 2006 (Mon) 07:38
PS CS Sharpening - Help NatsRoses RAW, Post Processing and Printing 6 4th of August 2006 (Fri) 07:40
