Thread started 05 Jan 2014 (Sunday) 16:20
Best Landscape lens??
Spuddyd
Gallery: 25 photos
Joined Sep 2012
Jan 05, 2014 16:20 |  #1
Need some advice as to what my next lens should be. I'm looking for a landscape lens to use on a 5D3. I already have a 24-105L which is fine and sharp enough but I really want to step up a level now.
Any help would be appreciated.
5DMk4, 16-35 f4L IS, 24-105 f4 L IS, Sigma 35 f1.4 ART, Sigma 50 f1.4 ART, Sigma 70-200 f2.8 OS, Sigma 1.4 and 2x converters, Lightroom CC.
The difference between genius and stupidity is that genius has it's limits!
flickr (external link), Photobucket (external link), My 500PX (external link)
ed ­ rader
"I am not the final word"
Jan 05, 2014 16:30 |  #2
Spuddyd wrote in post #16580211 (external link)
by the time this thread has run its course you'll get recommended almost every lens made. I use all my lenses for landscape.
5D4, 80d, 16-35L III, 24-70L II, 70-200L F4 IS, 100-400L II, sigma 15mm FE, 35mm ef-s macro, 430exII, gitzo 3542, gitzo GM4562, markins Q10, markins Q3, kirk, really right stuff
JeffreyG
Gallery: 39 photos
Jan 05, 2014 16:31 |  #3
You could upgrade the Sigma for a Canon 70-200/2.8 IS II.
Another option that might be handy would be one of the tilt-shift lenses, probably either the 17mm or the 24mm. The 24mm would be a good option as it could stand in for the 24-105L in the range where the 24-105 is weakest, at 24mm.
JeffreyG
Gallery: 39 photos
Jan 05, 2014 16:34 |  #4
ed rader wrote in post #16580230 (external link)
No doubt you are right Ed, but one would hope people would at least be thinking in terms of lenses that have low distortion, sharpness across the frame and low vignette. That's where I like see the TS-E being good, as well as the 70-200 II.
The new 24-70 II is also a good landscape lens, but the OP does not look for a replacement to his 24-105L right now.
Scrumhalf
Gallery: 36 photos
Joined Jul 2012
Jan 05, 2014 16:36 |  #5
By landscape, do you mean focal lengths less than 25mm? Landscape shots can be made at any focal length.
Sam
5D4 | 6D | 7D2 (2 bodies) | Reasonably good glass
If I don't get the shots I want with the gear I have, the only optics I need to examine is the mirror on the bathroom wall. The root cause will be there.
BrickR
Joined Mar 2011
Jan 05, 2014 16:41 |  #6
Scrumhalf wrote in post #16580246 (external link)
Yeah. You can shoot landscapes with a 70-200, a 35, a 50,... What FL are you looking for in particular?
My junk
The grass isn't greener on the other side, it's green where you water it.
macvisual
Joined Dec 2011
Jan 05, 2014 16:43 |  #7
I'd be looking at prime lenses, I shoot with a C.Zeiss 21mm on full-frame. Superb lens for landscape duties.
IMAGE: http://farm3.staticflickr.com/2819/10782602534_a20220af8c_b.jpg
IMAGE LINK: http://www.flickr.com …95336112@N07/10​782602534/  (external link)
Evening sunshine (external link) by Peter McCullough Photography (external link), on Flickr
'Peter McCullough Photography'
Follow my flickr
http://flic.kr/ps/2sfe​3P (external link)
Tony_Stark
Shellhead
Jan 05, 2014 16:45 |  #8
Invest in filters. Youll see more change than just buying a new lens. For landscapes you stop down anyway so all lenses to a certain extent will do the same.
Nikon D810 | 24-70/2.8G | 58/1.4G
EOS M | 22 f/2 STM
Website (external link) | flickr (external link)
tincanman99
Jan 05, 2014 16:58 |  #9
2 words - Lee Filters. Go do a search on the forums and there is tons of info on them. The things you can do with Lee Filters is amazing. The best part is its a system and you only need to buy an adapter for each lens which is not that expensive ($30-$60).
vengence
Joined Mar 2013
Jan 05, 2014 17:46 |  #10
If you're really looking for a landscape lens (and not simply a wide angle lens), then a TS-E will be your best bet, focal length is up to you.
Somebloke
Joined Sep 2013
Jan 05, 2014 17:55 |  #11
lol why hasnt anyone recomeneded the tried and true 17-40L? So far we have had responses for a large apperature telephoto zoom, 2 for filters and another for tilt shift???? Is the most obvious answer the least obvious, or are we all being deliberatley obtuse?
MalVeauX
"Looks rough and well used"
Gallery: 1057 photos
Joined Feb 2013
Jan 05, 2014 17:55 |  #12
Heya,
21mm to 24mm on full frame would be a sweet spot for wide, but not quite "ultra" wide.
24L? 21 Zeis?
And get some neutral density filters. They are the difference between good landscape and exquisite.
Very best,
JeffreyG
Gallery: 39 photos
Jan 05, 2014 18:04 |  #13
Somebloke wrote in post #16580439 (external link)
Why is the 17-40 a better choice for landscapes than the TS-E lenses? Or the 70-200/2.8 IS II for that matter?
The three lenses I suggested are very sharp corner to corner, they have very low distortion, they have very little vignette, they deal with flare very well......all very important aspects for landscape photography.
The 17-40 is.....well it is pretty good with flare. It also has a lot of distortion and the corners are not all that great.
Are you recommending the 17-40 simply because it is ultra-wide and not all that expensive? Not all landscape photography is done with wide angle lenses (I've seen a lot of great shots with telephoto lenses) and the OP didn't specifically suggest he needed a low cost lens.
lovemyram4x4
Gallery: 97 photos
Joined Mar 2013
Jan 05, 2014 18:17 |  #14
Well the OP did say best, the 17-40L is more the best bang for the buck and very versatile.
I recent picked up a TS-E 24 f3.5 II, I don't think my 17-40 will get much use in the landscape department anymore and will be limit to UWA distortion shots and underwater.
Another from for TS-E and IMO the 24mm is best for landscapes. It can take much cheaper filters (screw on or 100mm square/rectangle), I find 24mm FOV more of the sweat spot for landscapes, if wide is needed you can pano and/or shift stitch, longer-add a TC, you don't need to stop down much to get DOF when you use the tilt, you can get creative with DOF with the tilt(tilt up or sides), and you can keep verticals vertical and use shift to frame the shot.
I also like using my 70-200 and even at times my 300.
moltengold
Joined Jul 2011
Jan 05, 2014 18:24 as a reply to  @ lovemyram4x4's post |  #15
17-40 f/4L
| Canon EOS | and some canon lenses
10,247 views & 1 like for this thread
version 2.0 /
Latest registered member is Cliodiver
626 guests, 342 members online
