Reply
Thread Tools Display Modes
Old 6th of February 2006 (Mon)   #1
Curt Wells
Default 100-400mm or 28-300mm?
I have a 20D with a 24-70mm L and am considering a telephoto zoom for mostly outdoor and wildlife. I'm thinking about the 100-400mm L or the 28-300mm L and need a push. With the 1.6 multiplier these are essentially 160-640mm and 45-480mm lenses. Will the 160mm low end be too long at times? And, would the newer, more expensive lens be worth the extra money and be long enough?
Any advice? Thanks.
Curt Wells is offline   Reply With Quote
Old 6th of February 2006 (Mon)   #2
LightRules
"flat out embarrassing"
LightRules's Avatar
Default Re: 100-400mm or 28-300mm?
Mostly outdoors and wildlife? Easy: 100400IS.
LightRules is offline   Reply With Quote
Old 6th of February 2006 (Mon)   #3
Skip Souza
Moderator
Skip Souza's Avatar
Location: The Left Coast in the Land of Fruits and Nuts
The 28-300 l is a better PJ lens. Go for the 100-400 L all the way.
Canon Pro1 and Colt .380 are always with me. If you don't have it when you need it, you can't shoot it.
That which does not kill me ~~ Should Run. كافر
5DMkII, 7D, 70-300L IS, 24-105L, 100-400L
"PERSONAL MESSAGING REGARDING SELLING OR BUYING ITEMS WITH MEMBERS WHO HAVE NO POSTS IN FORUMS AND/OR WHO YOU DO NOT KNOW FROM FORUMS IS HEREBY DECLARED STRICTLY STUPID AND YOU WILL GET BURNED."
For Sale: ASUS Netbook
Skip Souza is offline   Reply With Quote
Old 6th of February 2006 (Mon)   #4
fWord
fWord's Avatar
Though I lack the experience, it might be safe to say that you need all the reach you can get when you're dealing with wildlife. The 1.6X crop factor extends the reach of either lens significantly, but I'd still go for the 100-400mm, even if I had enough dough to get either.
The 28-300mm strikes me as a lens that's walkabout in terms of range, but certainly not in terms of weight.
Since you already have the 24-70mm to cover wider shots, it might seem to be a bit of an overlap if you got the 28-300mm lens.
LightWorks Portfolio
Night Photography Tutorial: Basics & Minutiae
Gear List (Past & Present)
The Art of Composition IS the Art of Photography.
fWord is offline   Reply With Quote
Old 6th of February 2006 (Mon)   #5
jj1987
hrm if you have used the 100-400 you wouldnt even have to ask. 100-400!!!
jj1987 is offline   Reply With Quote
Old 6th of February 2006 (Mon)   #6
chancellor
chancellor's Avatar
Curt Wells, I'm a person who has a 28-300L curse (keep buying and selling the damn thing). In this context I definitely agree that you need 100-400L. Someone may throw a friendly "poison-pill" by mentioning Bigma, but given the choice your bet is 100-400L.
5D Mk II|1N|28-300L|35L|85L II|
chancellor is offline   Reply With Quote
Old 6th of February 2006 (Mon)   #7
lon10c
lon10c's Avatar
Third the 100-400.
lon10c is offline   Reply With Quote
Old 7th of February 2006 (Tue)   #8
Andy_T
Of course, the Sigma 300-800 would give you even more reach
Best regards,
Andy
Andy_T is offline   Reply With Quote
Old 7th of February 2006 (Tue)   #9
nitsch
I find wildlife needs at least 400mm (even with the 1.6x crop factor), so on that basis I would recommend the 100-400, it's a cracking lens and the focal length will go nicely with your 24-70.
nitsch is offline   Reply With Quote
Old 7th of February 2006 (Tue)   #10
Curt Wells
Thanks guys, it sounds like my mind is made up for me. I kind of expected such replies. The 100-400mm seems quite popular. Take care.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
400mm? 300mm? 100-400mm? 50-500mm? Can't choose!!! RbrtPtikLeoSeny Canon EF and EF-S Lenses 42 5th of November 2009 (Thu) 13:41
Comparison of EF 300mm f2.8 and EF 100-400mm TSKFin Canon EF and EF-S Lenses 24 28th of February 2006 (Tue) 23:18
300mm f/4L + 1.4X TC or 100-400mm f/4.5-5.6L? fWord Canon EF and EF-S Lenses 32 23rd of January 2006 (Mon) 19:41
100-400mm f5.6L [at 100-300mm range] prsast Canon EF and EF-S Lenses 12 20th of November 2004 (Sat) 01:40
EF 100-400mm f/4.5-5.6L IS VS. EF 70-300mm f/4.5-5.6 DO IS Csst Canon EF and EF-S Lenses 11 3rd of May 2004 (Mon) 03:42
