Reply
Thread Tools Display Modes
Old 9th of February 2006 (Thu)   #1
pitabread
pitabread's Avatar
Default Would this make a good lens kit?
Right now I've got the 18-55mm stock lens, plus the 100-400mm f/4.5-5.6L.
I'm not happy with the 18-55mm lens (esp when comparing it to pics I get with the 100-400), and I'm strongly considering buying the 17-40mm f/4L to replace it. I'm also considering buying the 50mm f/1.4 to use mainly indoors, low-light. In particular, I want something I can use in an art gallery or museum where flash photography is usually prohibited.
So that would give me:
17-40mm f/4L
50mm f/1.4
Does this look like a good set for the 17-50mm range?
And obviously that leaves a gap in the 50-100mm range. I'm not sure if that will be an issue for me, but I was wondering: if you had one lens to pick to fill that gap, which would it be?
pitabread is offline   Reply With Quote
Old 10th of February 2006 (Fri)   #2
bolantej
Default Re: Would this make a good lens kit?
could do an 85 1.8.
bolantej is offline   Reply With Quote
Old 10th of February 2006 (Fri)   #3
CRE@TE
CRE@TE's Avatar
...and a 35 1.4
I got stuff for taking pictures. When things are unclear - It's time to refocus.
My Flickr
http://www.flickr.com/photos/7605380@N08/
CRE@TE is offline   Reply With Quote
Old 10th of February 2006 (Fri)   #4
fWord
fWord's Avatar
It depends on what you want to shoot. Assuming you don't work under low-light conditions or indoors, the lenses in that kit are perfectly fine. I'm making well with just the kit lens and the 100-400mm.
If you're on a budget, and need quite an extensive range for museum, gallery or church photography, AND are on a budget, then you could try looking at wider primes such as the 24mm or 28mm.
But seeing that your subjects won't be moving (at least not very much), then I'd say that an IS lens would be helpful too. Instead of the 17-40mm L, look at things such as the EF-S 17-85mm, or the more expensive 24-105mm f/4L IS.
LightWorks Portfolio
Night Photography Tutorial: Basics & Minutiae
Gear List (Past & Present)
The Art of Composition IS the Art of Photography.
fWord is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Good replacement for Kit lens Bsmooth Canon EF and EF-S Lenses 5 14th of May 2007 (Mon) 09:32
How can I make my 18-55 KIT lens fit on my 10D Photolistic Canon EF and EF-S Lenses 11 20th of February 2007 (Tue) 20:19
How to make the best out of kit lens? hegemon Wildlife 7 17th of August 2006 (Thu) 10:35
Is the 17-85 IS a good kit lens upgrade? DaveSt Canon EF and EF-S Lenses 7 13th of August 2006 (Sun) 00:38
Canon 100-400: Will this make a good sports lens? Lonewolf Sports Talk 27 12th of June 2006 (Mon) 15:39
