Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Sports
Reply
Thread Tools Display Modes
Old 10th of February 2006 (Fri)   #1
fslshooter
fslshooter's Avatar
Default Baseball Shooting Tips and Example Pics
With baseball season starting I expect a lot of moms and pops will be anxious to capture images of their kids in action on the diamond. I don't claim to be an expert on the subject but I've taken quite a few photos at baseball games and learned a few things about the subject so perhaps some tips and example pics might be of interest to some.
If you can get field access, by all means do so -- you'll get consistently better results shooting closer to the action and you'll not have to shoot through the backstop which can get tricky. If you're not sure who grants field access ask the coach or school's sports information director. If you're granted field access, it's a good idea to talk with the head umpire prior to the game and ask what rules apply to you. BTW, don't assume that rules for photogs are the same at all venues and if you're issued written credentials be sure to read them before you go onto the field.
Prior to start of the game you might want to try and get a couple of posed shots of your favorite subject. The classic posed pitcher shot is with them holding their glove hand up to their chest and the other arm down by their side. The classic posed position player shot is with the player down on one knee, their glove lying in the foreground and them leaning on their bat. Both shots look best with either the scoreboard or grandstand in the background.
If you're comfortable shooting in manual mode you'll probably get the best results doing so. If not or if light conditions are changing rapidly AV might work better -- just remember that white or very dark uniforms will mislead your camera's light meter and you'll need to compensate. Check your histogram frequently to insure correct exposure. Maintain a bare minimum shutter speed of 1/350 with 1/500 or faster best along with the widest aperture you can use and still nail the focus. Adjust ISO as necessary to stay within these parameters. Shoot with single focus point and as tight as you can while still capturing the action that you want. Try and get picture with faces as this will make your images more interesting.
The best shooting positions for infield action are from along the first and third base lines somewhere between home plate and first or third base. From these positions you should be able to cover infield action with a 70-200mm zoom. At high school, college and professional levels, with 90 feet between bases, you'll need the reach of 300mm glass for best results. If you want to shoot outfield action your best bet is to go outside the fence and shoot from near the player. Unless you've master the technique of shooting into the sun, you'll probably get better results shooting with the sun at your back.
Pitchers are best shot from their throwing side -- lefties from the first base line and righties from the third base line. Many pitchers have their own unique style of delivery and if you watch them carefully you'll see these quirks -- an unusual windup, stretch, arm angle, facial expression, follow through, etc. If you can capture these split second moments you'll get more interesting stuff and with a starting pitcher you should have 50 or more chances to do it during most games. You'll probably get the best results shooting pitchers in single shot mode and timing your shots carefully. If you have field access and the ump allows it, stand near the catcher when the pitcher is warming up between innings and get a few head on shots from there. If you don't have field access and the backstop is narrow, get these pitcher shots from just beyond the edge of the backstop.
You'll probably get your most interesting batter shots if you shoot in AI Servo continuous mode then keep on shooting after the batter puts the ball in play. Some of my favorite shots are of batters coming out of the box. Baseball is one of those sports where you can anticipate many of the action shots and it's best to prefocus on the spot where you anticipate action -- second base and home plate primarily. Manual focus continuous shooting mode works best for these shots and you might want to stop down a bit to insure that everything stays in focus.
We won't talk about post processing except for a few tips on what to keep and what to cull. The obvious apply -- out of focus and those that are over/under exposed beyond rescue are culls. Unless you need them for lessons learned, delete them and save storage space and processing time. As for the remainder, very few images without at least part of a player's face are of interest. Also (unless you're a fan of the opposing team) photos of position players who make errors and batters who swing and miss or foul tip the ball with the ball still in the frame are usually of no interest.
As I said in the beginning, I don't consider myself to be an expert on the subject of baseball photography so please don't take anything I've said here as written in stone. These are just a few things I've learned in my pursuit of marketable baseball photography that others might find of use.
Here are links to some example pics I shot last season:
Jerry ~ Baseball is a game where only defensive players handle the ball and offensive players who hit successfully in only one third of their at bats are among the best in the sport.
Baseball Shooting Tips |++| www.jerryhalephotography.com
fslshooter is offline   Reply With Quote
Old 10th of February 2006 (Fri)   #2
QUASIPHOTO
QUASIPHOTO's Avatar
Default Re: Baseball Shooting Tips and Example Pics
Thanks Jerry very informative!!! I'm sure these hints and helps will also apply to girls fast pitch softball. The season is upon us!!!!!
Your site/images are awesome....crisp and clean. Dang great work there.
Jeff
Canon 20D w/Grip, 70-200 f2.8L IS USM, 24-70 f2.8L USM, 17-85 USM, 85 f1.8 USM, 1.4 TC, 580EX, manfrotto monopod, Omnibounce
www.flickr.com/photos/quasiphoto
QUASIPHOTO is offline   Reply With Quote
Old 10th of February 2006 (Fri)   #3
Croasdail
Great timing on the post - 2 hours and 22 minutes until first pitch. I've made notes and am ready... thanks!
Mark
Its by knowing and mastering all the rules that you learn which ones you can break.
Croasdail is offline   Reply With Quote
Old 10th of February 2006 (Fri)   #4
gmen
gmen's Avatar
Very informative Jerry. If anyone asks about baseball over in the Q&A thread, I'll point them in this direction pronto
Now, where do I find some baseball?
---- Gavin
gmen is offline   Reply With Quote
Old 10th of February 2006 (Fri)   #5
cking2
cking2's Avatar
Jerry,
Thanks for the tips.....This will be my first year Shooting my son's Baseball games. Your tips are greatly appreciated. The people on this board are GREAT...
Thanks,
Rick King
Gear List Here
cking2 is offline   Reply With Quote
Old 10th of February 2006 (Fri)   #6
cking2
cking2's Avatar
---- Gavin
Oh that's right....you have that strange game they play with a flat board
Go to the Airport get on a jet and head to any large town in the southern US....Spring training starts around the first of March. You will get a lot of sun and might just decide to stay here.
For Baseball fans.....would it not be great to take the whole month of march and travel around to all the Spring training camps...winding up with a visit to Cooperstown, NY. This would be a dream for my son and I to do.
One thing is for certain....you are not going to see baseball in the Olympics anymore. The dropped it yesterday
Rick King
Gear List Here
Old 10th of February 2006 (Fri)   #7
Croasdail
Jerry - just got back from first game of the year.... quick question for you - shoot portrait or landscape. I generally shoot most sports portrait... but found myself switching a lot today... any general advice here. Didn't like landscape for pitching, and didn't like portrait for catching base running. Cheers.
Mark
Old 10th of February 2006 (Fri)   #8
fslshooter
fslshooter's Avatar
Mark -
Unfortunately there's not a one size fits all answer to that question. Perhaps it's safe to say that I use the mode that fills the frame best. Two situations that are almost universal are posed shots and head on pitcher shots which are usually portrait mode. Another situation is action shots at second and home which are usually landscape mode. The mode for picthers depends on their height, how much they stretch during delivery and the final composition I want. Generally speaking I shoot pitchers in portrait mode during their windup and landscape mode in their stretch. I probably shoot batters more in portrait mode unless I'm expecting them to bunt then landscape mode usually works best. Switching a lot as you did today is normal. In fact when I'm using a monopod I never bother to tighten the orientation lock knob because I switch back and forth so often.
Old 10th of February 2006 (Fri)   #9
fslshooter
fslshooter's Avatar
Originally Posted by QUASIPHOTO
Thanks Jerry very informative!!! I'm sure these hints and helps will also apply to girls fast pitch softball. The season is upon us!!!!! Jeff
Jeff - the tips should apply for softball too. As a matter of fact I posted this thread just before I walked out the door today to shoot my first fastpitch game of the season. BTW I see you have a 70-200 and 1.4x TC -- I used this combo for every shot today. I've not processed the images yet but based on what I saw through the viewfinder and in chimps, I think that combo is excellent for daytime fastpitch.
Old 11th of February 2006 (Sat)   #10
liza
User is banned from forums
Thanks for the tips, Jerry! I shoot both girls' softball and boys' baseball, so these tips will soon be put into practice.
liza is offline   Reply With Quote
Old 11th of February 2006 (Sat)   #11
cargo123
Jerry, Thanks for the tips. I shot sball last year, and I am giving another try this year. Mike
cargo123 is offline   Reply With Quote
Old 11th of February 2006 (Sat)   #12
fslshooter
fslshooter's Avatar
---- Gavin
Cheers Gavin - You and your Q&A session are the impetus for this thread. I was rehashing things in my mind and making notes for the new season when it hit me that perhaps these notes might help others as you've helped me.
With the popularity of cricket there, I rather doubt that you'll find the game of baseball played anywhere in the UK. When we were living in Berkshire and Cambridgeshire we played softball at American military bases all over England and the two games are similar.
Old 11th of February 2006 (Sat)   #13
fslshooter
fslshooter's Avatar
Originally Posted by cking2
Jerry,
Thanks,
Rick - You and your son are lucky. He will provide you with some great sports photo opportunities and you'll provide him with lifetime photographic memories. Good luck to both of you in your endeavors and have fun!
Old 11th of February 2006 (Sat)   #14
DaveL
DaveL's Avatar
Thanks for the great tips everyone...
I'm leaving for Florida in 16 days with my 10
year old and my brand new digital rebel XT (w/a
canon 75-300, a 2x tc and a 50mm 1.8). We'll
spend a few days following our Red Sox and then
head up to Dunedin for a couple days... BTW:
Jerry, we are really jealous of the FSL. I love the
fact that you can pay $3, sit in the front row and
end up with as many foul balls as you want
Our town (Manchester, NH) has an Eastern League
affiliate so I expect to shoot quite a bit this year.
DaveL is offline   Reply With Quote
Old 12th of February 2006 (Sun)   #15
fslshooter
fslshooter's Avatar
It sounds to me like you might be as passionate about the game of baseball as I am. I think you and your son are going to have a blast at Spring Training and that you're going to give your new gear a real workout. You might not be aware of it but 11 of the 12 teams in the Florida State League play at Spring Training facilities. Dunedin is one of my favorites too -- both the ballpark and the town.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
First attempt at shooting baseball roundsquare1 Sports 0 25th of June 2007 (Mon) 19:50
shooting first baseball game. tips? carpenter Sports 4 10th of September 2006 (Sun) 10:11
Tips for shooting snow covered landscape pics? carpenter The Business of Photography 1 21st of July 2006 (Fri) 06:27
Shooting baseball sportraits... jsanz11 Sports 3 11th of April 2006 (Tue) 00:34
Night baseball tips dmwierz Sports 9 10th of July 2005 (Sun) 00:19
