Thread started 03 Apr 2014 (Thursday) 22:44
Prev/next
How much pp is need for this look...
Perfectly ­ Frank
I'm too sexy for my lens
Apr 03, 2014 22:44 |  #1
I came across this photographer's work while surfing flickr.
These images (and this one in particular) look exceptionally sharp and very detailed.
Can both LR and CS provide this quality? Or is some special technique used?
https://www.flickr.com ...otocomphotos/126558​57404/external link
My flickr albums (external link)
My Best Aviation Photos (external link)
gjl711
They have pills for that now you know.
gjl711's Avatar
Deep in the heart of Texas
Apr 03, 2014 22:47 |  #2
Doesn't really look like much was done at all. Maybe shot with a polarizer and a few adjustments like contrast, saturation and such.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
Alveric
Alveric's Avatar
Canada
Apr 03, 2014 23:12 |  #3
Micro contrast and curves.
Perfectly ­ Frank
Apr 04, 2014 00:06 as a reply to Alveric's post |  #4
Thanks for the replies. I considered asking the photographer herself, but she gets hundreds of comments per shot, so I doubt she'd answer. ;)
One more thing, her photos are very sharp. When I upload my photos they always loose some sharpness. They never look super sharp like hers.
Alveric
Alveric's Avatar
Canada
Apr 04, 2014 00:09 |  #5
Do you apply any 'export sharpness'?
Perfectly ­ Frank
Apr 04, 2014 00:44 |  #6
Alveric wrote in post #16808587external link
I upload the full size jpeg image. I don't resize for the web. Is export sharpness a feature of flickr, or pp software? I'm only using dpp.
tonylong
...winded
tonylong's Avatar
Gallery: 58 photos
Vancouver, WA USA
Apr 04, 2014 00:56 |  #7
Perfectly Frank wrote in post #16808658external link
If you are uploading "full size" images to Flickr, then Flickr has to do a lot of "resizing" in order to display it at a "normal" Web-viewing size. So, if you aren't happy with those re-sized images, then it's up to you to size your images smaller for viewing...although if you have a reason for uploading a full-size "original" (like if you are providing large files for clients to get big prints) then your options may be limited...
Otherwise, DPP gives you the tools to resize in the Convert and Save and the Batch Process dialogs. You can resize to your chosen "pixel dimensions". For example, you can resize pics to the POTN limit of 1023 pixels at the widest dimension (although I'm not sure if you can do this with a "non-pro" Flickr account...? You can also use DPP to "play with" the final sharpness of an image...try resizing, Converting and Saving an image to a jpeg, open the smaller jpeg in the DPP editor, then applying some sharpening. If the result is better than what Flickr has been producing, then try uploading the resized image to Flickr.
It's true that Flickr will still resize your pics to produce the various "views", Thumbnails, Small, etc., but you will have more control over your outcome.
Tony
Tony Long Photos on PBaseexternal link
Wildlife project pics hereexternal link, Biking Photog shoots hereexternal link, "Suburbia" project hereexternal link! Mount St. Helens, Mount Hood pics hereexternal link
Perfectly ­ Frank
Apr 04, 2014 19:11 as a reply to tonylong's post |  #8
^^ Thanks Tony, much appreciated info!
I do have a pro flickr account. I upload the full size image as a type of backup, so I can recover images if needed (I also backup on HDs as well).
I'll give your suggestions a try. I think it's also time I give LR or CS a try.
Adharr
Adharr's Avatar
Joined Mar 2014
Arizona, United States
Apr 05, 2014 05:29 |  #9
banned
I have never actually used export sharpness in Lightroom. I just do my sharpness and noise reduction processing in the he Details panel and have never thought twice about it. Do any of you see an advantage to doing so?
My Homepageexternal link
Alveric
Alveric's Avatar
Canada
Apr 05, 2014 11:29 |  #10
Adharr wrote in post #16811227external link
I never do either. I just thought that maybe that was the cause for the 'super sharpness' in that photographer's photos.
BigAl007
Repps cum Bastwick, Gt Yarmouth, Norfolk, UK.
Apr 05, 2014 14:33 |  #11
All of my images posted to Flickr are resized down to 1024 px on the long edge. I also have sharpening output sharpening set to Screen/Standard and I set the PPI value in the publish dialogue to 100 as this setting is also used by LR within the output sharpening algorithm. If I size LR so that the an image is sized to about fill 1024 pixels (in the Library module) and compare it to an exported JPEG displayed from Flickr (in Chrome) then the uploaded image has much better micro contrast than that of the image displayed in LR. All finished images exported from LR get output sharpening added with the settings depending on the intended use of the export. The only draw back with LR output sharpening is that you cannot preview it, although it's not much of a problem with prints, you only really know if it's right when you have the print in hand.
Alan
My Flickr (external link)
Perfectly ­ Frank
Apr 05, 2014 15:57 as a reply to BigAl007's post |  #12
Thanks folks for the tips.
bsmotril
bsmotril's Avatar
Joined Feb 2006
Austin TX
Apr 05, 2014 20:05 |  #13
To my eye, that image looks like a focus bracketed stack of images blended together.
Galleries: http://www.flickr.com/​photos/smopho/external link --- http://billsmotrilla.z​enfolio.com/external link
HBOC
PDX
Apr 06, 2014 22:00 |  #14
it might have very well been a depth of field blend. I use the kuyper action for web sharpening and use save for web. I never post anything over 900px on the long side. For print, I use Niks output sharpening with amazing results!
FBexternal link
500pxexternal link
Blogexternal link
catclaw
Joined Apr 2014
Apr 07, 2014 13:31 |  #15
banned
bsmotril wrote in post #16812429external link
That's a great idea. I never thought about doing that for landscapes.
TriExposureexternal link
1,974 views & 0 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.00191 for 4 database queries.
PAGE COMPLETED IN 0.05s
Latest registered member is chooter
1002 guests, 522 members online
