#1 |
Just wondering how many of you keep the lens adapter on the lens as a safety. Does it block the on camera flash? I want to use the LA-DC58D lens adapter and keep it on the body of the G6.
Thanks guys Visuals~
This Forum Still Exists?
Sony RX1 and Iphone 5 |
| sponsored links |
#2 |
I leave it on. But then, I dont use the onboard flash (have a 380EX for when I need a flash). The adapter also blocks the viewfinder - grrr.
Vandit
These are my opinions. If you don't like them, I have others [Groucho] The Restless Photographer - Wildlife, nature & travel photography, and blog Photo Safari India - Photography workshops, tours and image sales |
#3 |
Yes, at wide it blocks the built-in flash. I've saved (through trial and error) a setting in one of the custom settings (C1 or C2) a zoom which is the widest without seeing a darkening in the corner. But as my G5 doesn't quantify zoom settings I can't tell you what that is.. (boo)
I leave my lens adapter on all the time for safety too with a proper lens cap (don't know about the G6 but the G5 has a slipon cap which is good for saving the lens in case you switch on inadvertently but too many times I've reached into my bag to find it come off and my beloved lens exposed to my detritus. |
| sponsored links |
#4 | |
Moderator
#5 |
23mm is the actual focal length.
But as there is no way of telling your focal length without downloading and checking EXIF, I would take photos of a blank wall progressively zooming from tele to wide until you see the shadow. |
| Thread Tools | |
| Display Modes | |
| S1Is 52mm conversion lens adapter | weilaphobia | Small Compact Digitals by Canon | 2 | 7th of December 2005 (Wed) 20:35 |
| Canon Conversion Lens Adapter | ansonwong | Canon G-series Digital Cameras | 10 | 26th of July 2005 (Tue) 13:18 |
| Conversion Lens Adapter for G5 | Paul Devlin | Canon G-series Digital Cameras | 1 | 14th of June 2004 (Mon) 06:31 |
| canon conversion lens adapter | dagmd | Canon G-series Digital Cameras | 1 | 2nd of September 2003 (Tue) 16:20 |
| A70 Conversion Lens Adapter | warrenpass | Small Compact Digitals by Canon | 0 | 27th of May 2003 (Tue) 09:58 |
