Thread started 14 Sep 2014 (Sunday) 01:06
Prev/next
200-400 aviation raw files to download...
Perfectly ­ Frank
I'm too sexy for my lens
Sep 14, 2014 01:06 |  #1
I rented the 200-400 and took it to my local airport. With my 1D4 I shot a number of prop and jet planes. Hand held and at various shutter speeds. Most were with the 1.4x engaged. A few were with an external 1.4xIII attached. I was surprised how well some of these shots came out at 784mm.
Note: this is not a lens test. But it does give one an idea of what this lens can do for aviation photography. I'm sure some are better at panning than I, so keep that in mind. Images greater than 560mm were taken with an external 1.4xIII attached.
Bombardier jet 560mm
https://dl.dropboxuser​content.com/u/39824303​/AU4C5145.CR2external link
Prop 560mm
https://dl.dropboxuser​content.com/u/39824303​/AU4C5209.CR2external link
Jet 490mm
https://dl.dropboxuser​content.com/u/39824303​/AU4C5228.CR2external link
Cessna 172 600mm
https://dl.dropboxuser​content.com/u/39824303​/AU4C5465.CR2external link
Gulfstream IV
https://dl.dropboxuser​content.com/u/39824303​/AU4C5496.CR2external link
AT-6 784mm
https://dl.dropboxuser​content.com/u/39824303​/AU4C5419.CR2external link
Bellanca 560mm
https://dl.dropboxuser​content.com/u/39824303​/AU4C5157.CR2external link
Prop 645mm
https://dl.dropboxuser​content.com/u/39824303​/AU4C5348.CR2external link
My flickr albums (external link)
My Best Aviation Photos (external link)
DJHaze596
DJHaze596's Avatar
Joined May 2012
Florida
Sep 14, 2014 09:00 |  #2
1/180th? Are you crazy? lol They look a bit soft to me. Should of took the lens to a Zoo.
Canon C200 | Canon 5D Mark IV | 16-35 f4L IS USM | 24-105mm f4L
50mm STM | 70-200mm f2.8L II | 100-400mmL II | 400mm f2.8L IS USM
Previously Owned: 1DX Mark II | Canon 5D Mark IV | 7D Mark II | 1D Mark IV
Talley
Talley Whacker
Talley's Avatar
Gallery: 35 photos
Joined Dec 2011
Houston
Sep 14, 2014 09:44 |  #3
DJHaze596 wrote in post #17153401external link
Yup... animal fur is a great sharpness test subject!
5D4 |12mm 2.8 FE | 16-35L 2.8 III | Σ 35A | Σ 50A | Σ 85A | 200 F2 IS | 1.4xIII
X-T20 | X-E3 | 18/2 | 35/1.4 | 56/1.2 | 18-135
My Gear Archive
NinetyEight
"Banned for life"
NinetyEight's Avatar
Dorset - England
Sep 14, 2014 09:45 |  #4
One is a t 1/160th at 645mm! - Probably for the 'prop blur'? - Mind you, f/16 - f/18 doesn't help as diffraction will be softening the images.
A friend of mine has bought a 200-400 (:mad:) and even with a separately attached 1.4x converter it is capable of superb results.
Kev
Perfectly ­ Frank
Sep 14, 2014 10:06 |  #5
Aviation photographers shoot at slow shutter speeds to capture prop blur. But I agree, many are a bit soft, even the jets at higher speeds. I didn't apply any sharpening.
kjonnnn
Chicago, Illinois
Sep 14, 2014 10:53 |  #6
Perfectly Frank wrote in post #17153479external link
At 1/180 you're introducing alot more camera shake than prop blur into the image at that focal length I think was the point.
BigAl007
Repps cum Bastwick, Gt Yarmouth, Norfolk, UK.
Sep 14, 2014 11:25 |  #7
There are more than one or two shooters out there that can nail 500mm and 1/60 quite regularly. I'm sure the keeper rates are not high, but they do it consistently. Many think that 1/160 is almost a maximum shutter speed for propellor driven aircraft. So if you are at ISO100 you either stop down or use a filter. If you then want to quickly move to a jet at 1/1000 then the filter is a bit cumbersum.
Helicopters usually need around 1/100 or slower. The bigger the helicopter the slower you usually need. Things like Seakings won't come near to showing a full disk blur (which would take 1/5th of a rotor rotation) at 1/60s shutter speed.
Alan
My Flickr (external link)
FEChariot
FEChariot's Avatar
Joined Sep 2011
Sep 14, 2014 18:24 |  #8
kjonnnn wrote in post #17153549external link
With two 1.4 TCs on a 1.3 crop camera, one should be able to hit at 1/1000" with out IS. With 4 stop IS in the 200-400, that should bring it down to 1/60".
Canon 7D/350D, Σ17-50/2.8 OS, 18-55IS, 24-105/4 L IS, Σ30/1.4 EX, 50/1.8, C50/1.4, 55-250IS, 60/2.8, 70-200/4 L IS, 85/1.8, 100/2.8 IS L, 135/2 L 580EX II, 430EX II * 2, 270EX II.
Perfectly ­ Frank
Sep 15, 2014 00:21 |  #9
That may very well be. I only had about 3 hours to use the lens, and it's heavier than my 300 f2.8. Perhaps more practice will help. I usually don't shoot aircraft
at greater than 500mm, except for the high flying aerobatic planes. I just wanted to see what the lens - and me - could do above 560mm.
Although even at 1/750s my jet shots are a bit soft. Adding 3 or 4 points of sharpening in dpp cleans them up pretty well.
I use a filter in my 300 f2.8 to keep the f number reasonable. But I forgot to bring it with the 200-400.
1,373 views & 0 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.00174 for 4 database queries.
PAGE COMPLETED IN 0.04s
802 guests, 400 members online
