FORUMS Photo Sharing & Visual Enjoyment Still Life, B/W & Experimental
Thread started 19 Sep 2014 (Friday) 02:20
Ultraviolet (UV) Image Gallery
CRCchemist
Joined Apr 2014
Sep 19, 2014 02:20 |  #1
I was recently introduced to the beautiful art of ultraviolet photography of flowers. Patterns that are not visible to our eyes, but attract insects and birds, are some of the most interesting patterns and colors I've ever seen.
I was hoping that there would be some examples of ultra-violet photography here on POTN, but nobody's posted anything! People portraits look very cool in the ultraviolet spectrum as well.
Now you have a gallery to post your UV images and a place to talk about how you achieved the shots.
Let's see them!
SteveInNZ
Sep 19, 2014 03:43 |  #2
I played around with UV imaging a while back. I tried a variety of point&shoot and DSLR cameras and lenses to find something that would work. The focus shift of most lenses at the UV end is huge.
This is taken with an unmodified 10D and B+W/403 filter. The flower is 'Goldmound' (Bidens ferruifolia).
The top half is visible light and the bottom is reflected UV.
IMAGE: https://farm5.staticflickr.com/4086/4989186231_02552228a7_z.jpg
IMAGE LINK: https://flic.kr/p/8AST​fg  (external link)
Bidens ferrurifolia In UV light (external link) by stevetla (external link), on Flickr
and this is the common Dandelion flower.
IMAGE: https://farm7.staticflickr.com/6005/5932832163_e9f5d962f8_o.jpg
IMAGE LINK: https://flic.kr/p/a3gj​iH  (external link)
UV Dandelion (external link) by stevetla (external link), on Flickr
Steve.
"Treat every photon with respect" - David Malin.
CRCchemist
Joined Apr 2014
Sep 20, 2014 01:06 |  #3
This is so interesting. I thought that I would have to do a full-spectrum conversion to a camera to take ultraviolet images.
What resources did you go to to learn how to do this? Is it literally a stock camera with the 403 filter?
SteveInNZ wrote in post #17164741 (external link)
Steve.
SteveInNZ
Sep 20, 2014 04:01 |  #4
I originally bought the filter to create a UV only light source to do some fluorescence photography. I knew that the filtering varied between cameras at the red end from an interest in astrophotography so just experimented.
Full spectrum will be much more sensitive but the 403 filter lets in quite a bit of IR which the 10D wasn't sensitive to. The full spectrum camera will be, so you'll need to block that somehow. An alternative is the Baader Planetarium UV-Venus filter which is much more expensive but doesn't have the IR leakage.
The exposure of the UV section of the first one is 4 minutes compared to 1/20 sec for the visible section. I used a different lens for the dandelion and that was 30 sec for the UV and 1/60 for the visible portion.
Steve.
CRCchemist
Joined Apr 2014
Sep 22, 2014 00:21 |  #5
I found some spec sheets for Hoya filters. All their ultraviolet transmitting filters are at the link below.
http://www.hoyaoptics.​com …ilter/uv_transm​itting.htm (external link)
It looks like the Hoya U-340 would make a very good ultraviolet band pass filter for UV photography. It has a wide band of UV pass while still blocking visible light and infrared light very well, with the U-350 blocking the non-UV spectrum just a little better. Do you happen to know where to find the B+W specification sheets for their 403 UV transmitting filter?
However, I've heard that the Baader-U filter is the best one out there. It's an astronomical purpose filter that has an extremely good transmission response curve. Information is in the link below:
http://www.savazzi.net​/photography/baader_u.​htm (external link)
I have also found an excellent resource at the link below:
http://www.ultraviolet​photography.com/ (external link)
There is an entire community of UV photographers there that advise on equipment and techniques.
This is also a great article on UV photography that covers everything from a UV flash to camera sensors:
http://www.savazzi.net​/photography/uv.htm (external link)
I'm continuing to learn more about this.
SteveInNZ
Sep 22, 2014 20:33 |  #6
I agree. It looks good.
The 403 is Schott glass used in black lights, etc. A google search turns up some data. It's probably the most economical option.
Steve.
calypsob
Joined Jan 2012
Oct 02, 2014 20:36 |  #7
Cool. I've wanted to experiment with uv photography. I have read that quartz glass un coated lenses are used for uv ir photography because normal lenses filter a lot of the uv. What lens did you use here? I have seen many uv filters on ebay, just search uv band pass filters.
Wes
Gear: Many gears Yes.
CRCchemist
Joined Apr 2014
Oct 02, 2014 20:58 |  #8
calypsob wrote in post #17190834 (external link)
This guy below:
http://nickspiker.devi​antart.com …Series-Number-B-113065418 (external link)
Provides a lot of good information in the comments section of this image comparison he posted at that page above.
MCBarksdale
1 post
Joined Oct 2014
Oct 04, 2014 06:54 as a reply to  @ CRCchemist's post |  #9
These pictures are just wonderful. It will be interesting to see a human photo with UV effect. I was wondering if the UV effect can be given through painting as there are many mediums to convert photo to paintings. And if UV could be one of them?
learn this here now (external link) .
CRCchemist
Joined Apr 2014
Oct 07, 2014 14:13 |  #10
MCBarksdale wrote in post #17193050 (external link)
When people are photographed in UV, it reveals sun damage to the skin. Basically, a bunch of hidden freckles and sunspots are visible that you can't see in normal light that our eyes are capable of seeing.
It makes people look very old and weathered.
On the other hand, infrared portraits of people actually make the subject look like mythical creatures. It makes women look like nymphs or fairies and men look like Greek or Roman deities.
UV is best for insects and flora. Lots of hidden patterns are visible in UV light that are invisible otherwise.
kufiroqi
1 post
Joined Aug 2016
Aug 15, 2016 03:02 |  #11
Pictures are beautiful. I purchased a custom painting from Paintmyphotos.net (external link). Anyway to have a UV effect?
WillJohn9
1 post
Joined Jan 2018
Jan 27, 2018 19:21 |  #12
Great pictures, looks great. Perhaps you would want to have someone turn your photo into painting?
4,429 views & 0 likes for this thread
Latest registered member is cabvkam
754 guests, 342 members online
