Thread started 01 Oct 2014 (Wednesday) 11:26
Prev/next
Why don't they have a shuffling mode for dual card cameras?
benji25
benji25's Avatar
Twin Cities
Oct 01, 2014 11:26 |  #1
To my knowledge there is only 3 types:
1 Shoot until fill, then switch
2 Shoot the same thing to both cards so you have a copy
3 Shoot one file type to one and one to the other
Why is there no option to shoot the first image to card 1, second to card 2, third to card 1 etc.? Let's assume you lose a card in all 3 of the current types of writing options assuming you have two full cards.
1. You lose half of your pictures in a big chunk (i.e. first half of day or second half of day)
2. You are fine but you are limited to half as much space (as it is mirror if you have two 32 gig cards you can only shoot 32 gigs of photos)
3. You potentially lose all of your raw files. JPGs lost probably won't matter.
If you alternate cards and lose a card you can still potentially have every photo. For example in a wedding, if you lost a card, you would still have a story from the whole day on the second card. Sure you might not have a specific shot of the bride getting ready, but you will have some because the 4 shots you took of the bride tying her dress got divided up to two cards. Whereas if you were filling both cards and you lost one you would lose the first part of your day.
It also serves to maximize your memory. If you shoot two 32 gig cards you essentially have 64 gigs of photos. If you lose one of them, instead of taking a chunk out of your story, it kind of "thins" the photos from throughout the whole shoot.
Websiteexternal link
flickrexternal link
jmikolich
jmikolich's Avatar
Joined Feb 2013
Ohio
Oct 01, 2014 11:33 |  #2
seems like a good application for something like Magic Lantern...
But with the falling cost of flash memory, its not unreasonable to have 2x64gb cards in a camera.. considering to have dual slots you spent >1000 US and the cards would run you around 200.
That said, I think its a good idea, though the memory controller may not be so happy depending on the architecture of the circuitry behind it.
-Jim
Canon 5D3,5D3,5D2,6D,24 f2.8 IS,35L,45 TS-E,50L,85 f1.8,70-200 f2.8L II,100L
Rokinon 14mm f2.8
jra
jra's Avatar
Ohio
Oct 01, 2014 13:16 |  #3
I would rather just shoot RAW to both cards to have a complete back up. Memory cards aren't that expensive that it's cost prohibitive to purchase two very large (or multiple) cards. I guess if one was in a bind for memory space though, your suggestion would be useful.
Luckless
Joined Mar 2012
PEI, Canada
Oct 01, 2014 14:40 |  #4
Personally I want dual cards with staggered write and delayed backup.
That is, when shooting large bursts of photos at one time it will switch between which card it is writing the 'next' photo to during continuous shooting. So for a burst of photos half will be on Card A, and Half on B (assuming they're equal speed cards, a mismatch in speeds could see A freeing up for another photo to be written to it before B does.)
Then after the buffer is empty and no additional photos are being taken the camera will look at a list and start copying the files over to each card one at a time. if it gets powered off mid transfer then that photo gets 'flagged' on boot and the camera attempts an integrity check.
So you get the advantage of clearing the buffer as fast as possible, and reasonable file redundancy.
Canon EOS 7D | EF 28 f/1.8 | EF 85 f/1.8 | EF 70-200 f/4L | EF-S 17-55 | Sigma 150-500
Flickr: Real-Lucklessexternal link
JeffreyG
JeffreyG's Avatar
Gallery: 34 photos
Detroit, MI
Oct 01, 2014 15:16 |  #5
I see low application which is why this isn't available. Basically I suspect that people who need a backup need a real backup. If you shoot a wedding for pay, losing every other shot is better than losing the first half of the day, but it still isn't acceptable so what's the point? Especially when you can just put two big cards in the camera and have a full backup.
I use a Canon 5DIII
Luckless
Joined Mar 2012
PEI, Canada
Oct 01, 2014 15:22 |  #6
JeffreyG wrote in post #17188443external link
Writing every other photo to a card also means you can essentially double your card write speed, and clear your buffer faster. In my view it has just as much use as "Write to Card A till full, then use Card B", but spreads the data more evenly over the multiple cards.
While not a 'full' backup, it is still a far safer position than "Fill A then B" write option.
benji25
benji25's Avatar
Twin Cities
Oct 01, 2014 16:14 |  #7
It would also help for travel photographers who could use the extra card space and don't want to lose an entire chunk of their trip if one card goes down. If you go to Spain and England you could potentially lose shots of an entire country.
flickrexternal link
JeffreyG
JeffreyG's Avatar
Gallery: 34 photos
Detroit, MI
Oct 01, 2014 17:49 |  #8
benji25 wrote in post #17188543external link
OK, I'll admit the usefulness may be higher than I first thought. I'm not totally sure this would improve buffer clearing because I don't know that writing to both cards would really improve what the processor is doing. Maybe it helps, maybe not.
Like somebody else said, probably a ML software bit first.
I use a Canon 5DIII
hollis_f
hollis_f's Avatar
Sussex, UK
Oct 02, 2014 05:03 |  #9
Luckless wrote in post #17188451external link
Er, no.
Imagine you're filling buckets from a hose. It takes the same time to fill 2 buckets if you do them one-by-one or you switch every few seconds.
As for insurance against losing images - this happens so rarely that it's not worth the hassle. I've been using CF cards for 16 years. Apart from losing a whole card I've never lost an image.
Frank Hollis - Retired mass spectroscopist
Give a man a fish and he'll eat for a day. Teach a man to fish and he'll complain about the withdrawal of his free fish entitlement.
Gear Websiteexternal link
Joined Mar 2014
Oct 02, 2014 05:22 |  #10
banned
benji25 wrote in post #17188040external link
#2 just seems perfect to me. 2x 64GB cards, space not really an issue.
memoriesoftomorrow
Joined Nov 2010
Oct 02, 2014 05:30 |  #11
Just buy two big cards and shoot the same on both. If you run our of space have more cards available. Cards are cheap and small. I'd rather have a complete backup than risk losing half my shots as you would with your suggestion when shooting a wedding... that isn't a backup... it is stupidity when you have two slots available.
Peter
john ­ crossley
john crossley's Avatar
The Rhubarb Triangle
Oct 02, 2014 06:15 |  #12
I just don't see the point of it.
Those that can, do. Those that can't whinge.
Luckless
Joined Mar 2012
PEI, Canada
Oct 02, 2014 08:16 |  #13
hollis_f wrote in post #17189501external link
Er, no.
That is only true if you're filling buckets with water from a hose and only have one hose. If you're writing data to cards then things are very different.
Flash memory is Slooooow, while volatile memories use for things like the camera buffer are exceptionally fast to read and write from. This is why you can take a bunch of photos really fast for awhile and then have it slow way down as it slowly writes to the card. However while CF cards might share a data bus they are completely independent devices, and that data bus can be easily made to exceed that of the CF cards. You can easily write two different files to two different drives at the same time, and therefore use less time over all.
It is far more like using two smaller hoses connected to a much larger hose, and then filling two buckets at the same time. You can only put water in so fast to a given bucket, but you have more than enough water in the pipes to fill more than one bucket at a time.
However my degree is in computer sciences, so I've actually done stuff like this with real hardware, and have no need to imagine it with buckets of water.
And as for insurance, fires happen so rarely... No one in my family has lost a home to fire in over 150 years, so why should any of us bother paying for insurance? Clearly it will never happen, and if it does it will obviously be on a home that isn't remotely important to us...
melcat
Joined Nov 2010
Melbourne, Australia
Oct 02, 2014 08:23 |  #14
I think it's a very good idea.
benji25
benji25's Avatar
Twin Cities
Oct 02, 2014 10:08 |  #15
That is almost more reason for it. Since they fail so rarely why have a complete backup? This way you maximize space and still have some recoverability when they fail once every 16 years.
flickrexternal link
3,079 views & 0 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.00177 for 4 database queries.
PAGE COMPLETED IN 0.03s
Latest registered member is xeunskate
777 guests, 311 members online
