Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Canon EOS Digital Cameras
Reply
Thread Tools Display Modes
Old 21st of February 2006 (Tue)   #1
roanjohn
roanjohn's Avatar
Default 30D vs 5D
Aside from the larger sensor of the 5D..........are they pretty much the same camera??
Me think so.............Which means, we are paying an extra 1000+ for the fuller sensor.
Am I missing something here??
Ro1
www.pbase.com/roanjohn
roanjohn is offline   Reply With Quote
Old 21st of February 2006 (Tue)   #2
EOSAddict
Book Committee Immortal
EOSAddict's Avatar
Default Re: 30D vs 5D
Guess you will be getting a 30D then Ro1 I guessed you would like the spot metering!
Al
My Gear, My Website: www.e-ScapePhotography.co.uk
EOSAddict is offline   Reply With Quote
Old 21st of February 2006 (Tue)   #3
DavidW
The 5D isn't just a larger sensor. Various other components have to be larger as well, including the (far from cheap) pentaprism. Further, I suspect the 5D is more of a niche camera than the 30D (and the 20D before it), as it needs good lenses to get the most out of it. With cheap glass, you could finish up with worse results than cropping the edges from a 30D / 20D shot - the 30D / 20D use the better centre portion of an EF lens.
You have to decide what you want. If you're a fan of wide angle photography, and the extra resolution is of value to you, go for the 5D. If 8 megapixels will do, go for the 20D or the 30D when it's available.
David
DavidW is offline   Reply With Quote
Old 21st of February 2006 (Tue)   #4
roanjohn
roanjohn's Avatar
Another negative for the 5D............lack of pop-up flash.
YIKES!!!
Here's hoping we get a $500 rebate........ HEHEHE
Ro1
Old 21st of February 2006 (Tue)   #5
roanjohn
roanjohn's Avatar
As of right now.......I am leaning towards that direction. YES................
Ro1
Old 21st of February 2006 (Tue)   #6
sapearl
emailed Tim some prozac
sapearl's Avatar
Well, one of the strengths of the 5D over the 20 was a better/faster buffer I believe. I don't know if they modified this for the 30D. Lack of a flash would be a non-issue for my circumstance. I do weddings and always have the strobe mounted off camera on a bracket.
Other than these I'd like to see a side by side feature comparison of the 2. Likely DPReview will publish something like this soon.
Ro1
sapearl is online now   Reply With Quote
Old 21st of February 2006 (Tue)   #7
OceanView
OceanView's Avatar
I am in the same boat,
I was hoping that today's announcement would be more interesting but it isn't
The main thing for me is, will the new 30D have improved images over the 20D?
And will the new AF algorithim be improved or close to that of the 5D?
OceanView is offline   Reply With Quote
Old 21st of February 2006 (Tue)   #8
roanjohn
roanjohn's Avatar
The image quality of the 30D is similar to the 20D........
OH......and the 5d AF has 6 invisible points in the center focus......which the 30D does not have.
Ro1
Old 21st of February 2006 (Tue)   #9
RikWriter
RikWriter's Avatar
The 5D has a significantly larger buffer than the 30D. It also focusses more accurately (in my experience) and not least has 12.8MPs.
My gear: 1D MKIII, Tamron 17-35 f2.8-4, 28-75 f2.8, Canon 100-400L IS, 500mm f4L IS, 1.4X II TC, 2X TC.
My pics:
www.pbase.com/rikwriter
RikWriter is offline   Reply With Quote
Old 21st of February 2006 (Tue)   #10
Tom W
Canon Fanosapien
Tom W's Avatar
Ro1
The extra focus points are a plus for tracking smaller objects such as birds and the like. It's easier to keep the spot-meter circle on a small moving subject than just the center AF point. BTW, they aren't functional in one-shot mode. I expected Canon to put those in the 30D, but they didn't.
If the 5D's reported focus precision improvements are passed on to the 30D, then it is an improvement of value (going by what others say here - I've never had a 20D).
Tom
5D II, 7D, & various lenses
Tom W is offline   Reply With Quote
Old 21st of February 2006 (Tue)   #11
::John::
Moderator
Try going here:
http://www.canon-europe.com/For_Home...PageID=26009#2
Select the 2 cameras and press the compare button
::John:: is offline   Reply With Quote
Old 21st of February 2006 (Tue)   #12
sapearl
sapearl's Avatar
Ask, and yee shall receive! Thank you - I knew if I posted someone will have already researched this. I appreciate the link.
Originally Posted by kiwibloke
Try going here:
Old 21st of February 2006 (Tue)   #13
Cathpah
Cathpah's Avatar
Try going here:
funny that they list the 5D and 1DmIIN as NEW, yet the 30D has no such designation. have you euros been hiding this from us or what?
Eyeball Imaging or my Mayhem
too much gear to deny the addiction
oh, and my name is Jeff
Cathpah is offline   Reply With Quote
Old 21st of February 2006 (Tue)   #14
SkipD
SkipD's Avatar
YIKES!!!
Why is the lack of a popup flash a negative? The popup flash is the dumbest thing about the 20D that I can think of.
It's so useless for several reasons - lousy position, it can't get light past any decent (as in large diameter) lens (especially when hoods are mounted), it's too weak, it can't be aimed at a nearby wall or ceiling, and more......
Skip Douglas
A few cameras and over 40 years behind them .....
SkipD is offline   Reply With Quote
Old 21st of February 2006 (Tue)   #15
CyberDyneSystems
Admin - MOD OF STEEL...
CyberDyneSystems's Avatar
Dissing pop up flashes has become something of a cult favorite,. but it never hurts to have the added feature for use in a pinch IMHO..
There are times that a pop up is better than none.
Anyway.. 30D Vs. 5d IMHO is not much different than 20D Vs. 5D
Still the same change in application...
But I agree that the 30D makes the 5D seem even more overpriced to me.
CyberDyneSystems is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Hoodman H-30D LCD Hood/Protector for Canon EOS 30D DSLR TeamSpeed Canon EF and EF-S Lenses 1 1st of February 2007 (Thu) 12:01
30d vs. XTi -- is the 30d really that much better? photo_trev Canon EOS Digital Cameras 30 20th of January 2007 (Sat) 12:08
Another 20d vs 30d (WAS: Calling all new 30D owners) Keiffer Canon EOS Digital Cameras 103 12th of August 2006 (Sat) 12:14
30D Owners.. 30D on/off switch. zacker Canon EOS Digital Cameras 28 19th of July 2006 (Wed) 11:06
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
