Thread started 15 Nov 2014 (Saturday) 21:10
Prev/next
24 or 28 f2.8 IS USM ?
Perfectly ­ Frank
Nov 15, 2014 21:10 |  #1
I'm thinking about either the 24 f2.8 IS USM or 28 f2.8 IS USM for mostly my SL1, and some times my 6D. Since I shoot indoor events and museums, I believe the IS will be a benefit.
But there's only 4mm difference between the two lenses. 4mm doesn't seem like much. Is there a build quality or IQ difference?
Any opinions?
My flickr albums (external link)
My Best Aviation Photos (external link)
GeoKras1989
GeoKras1989's Avatar
Joined Jun 2014
Nov 15, 2014 23:08 |  #2
banned
I looked through your car show stuff. Nice!
Anyway, I don't think either of these choices adds much to your 24-70II. As much as you are using 24mm, would 28 work for you? I notice quite a few shots at much smaller than f/2.8, too. Would you get more versatility out of something like the 16-35 f/4 IS? Zoom versatility, the IS you want, and f/4 is hurting anything when your not shooting at f/2.8 anyway. Just some random thoughts at midnight.
WARNING: I often dispense advice in fields I know little about!
melcat
Joined Nov 2010
Melbourne, Australia
Nov 15, 2014 23:36 |  #3
Perfectly Frank wrote in post #17274270external link
When comparing focal lengths, use division rather than subtraction. 4mm at these focal lengths is significant.
There is a different "feel" to the two focal lengths on full frame.
apersson850
apersson850's Avatar
Traryd, Sweden
Nov 16, 2014 03:32 as a reply to melcat's post |  #4
You can always crop a picture taken with a 24 mm to look like what you get with a 28 mm, but not the other way around.
I have the EF 28 mm f/2.8 IS USM myself, but I use it mainly when I want the camera to be as compact as possible (yeah, I know, with a 1DX behind the lens...), but most of the time when using focal lengths in this region I find one of three other lenses on the camera.
Anders
MalVeauX
"Looks rough and well used"
MalVeauX's Avatar
Joined Feb 2013
Florida
Nov 16, 2014 03:38 |  #5
Any opinions?
Heya,
The 28 F2.8 IS is a very good lens. It's wide on full frame, but not super wide, so it's just another "wider than 35mm" there. It's great if you care about distortion (as in, less distortion from being wide). On a crop, it's a lot like using a 40 or 50mm on your full frame in terms of field of view. Great IS.
Have you considered the 35 F2 IS though? Is it too wide?
Very best,
DoughnutPhoto
Joined Aug 2014
the Netherlands
Nov 16, 2014 03:39 as a reply to apersson850's post |  #6
http://www.the-digital-picture.com ...8-IS-USM-Lens-Review.aspxexternal link
These two lenses are very close... the only thing I can come up with in addition to the link above, is that you might like the 24mm better on the SL1 than the 28mm since you seem to like wide angle lenses.
The 28mm lens will have the FOV similar to a 44mm lens on full frame - so that's nearly normal. The 24mm lens will have a FOV similar to a 38mm lens on full frame.
Canon 5d, 60d, 17-40mm L, 30mm Art, 50mm, 85mm
Perfectly ­ Frank
Nov 16, 2014 20:18 as a reply to DoughnutPhoto's post |  #7
Thanks folks for the comments.
I think the main reason I'm looking at these two lenses is for their small size and good IQ. Small size since I'll mostly use the lens on the SL1.
Since the SL1 is a crop camera, I'm thinking the 24mm might be best. As some one said, I can always crop the image if a narrow fov is needed.
speedync
Joined May 2011
Geelong, Australia
Nov 16, 2014 20:27 |  #8
Perfectly Frank wrote in post #17276118external link
This. I had the 24 on my T2i/550D, & it was excellent. I use the 28 IS far more on my 6D. Less distorted look, & sharp as. I got the old non IS 24 as a lightweight cheap wide option for the few times I use it on the 6D. The 22 pancake covers my crop needs now :) If you really want the 28, then maybe the new EF S 24 might suit. Cheap enough to own the 2.
lilkngster
NJ
Nov 16, 2014 21:22 |  #9
More of a difference on a FF than a crop. I would suggest you consider basing your decision on your FF rather than the crop. Depending on your needs, even 24mm might not be wide enough on the SL1. I'd sure like an EF-S 18mm IS...
As mentioned, there are more options at the 24mm range (L, TS, Ef-s, micromotor) compared to the 28 (USM and the micromotor versions), if you were thinking of complementing, i.e. 24L with the 28IS would be more useful. I'd like to see a 28mmL as well...
Also like the idea of the Ef-s for the Sl1 and the 28 for both.
80d and 1dIII|lenses from 8 to 400mm
ed ­ rader
"I am not the final word"
ed rader's Avatar
silicon valley
Nov 16, 2014 21:23 as a reply to speedync's post |  #10
28mm = cheaper, sharper, smaller. great lens that I owned for awhile but I now have 35 f2 IS.
5D4, 80d, 16-35L III, 24-70L II, 70-200L F4 IS, 100-400L II, 430exII, gitzo 3542, markins Q10, kirk, really right stuff
ed ­ rader
ed rader's Avatar
silicon valley
Nov 16, 2014 21:24 |  #11
I'd get the new 24 efs. much cheaper and smaller but of course no IS. in fact I will get this lens for my SL1 because I use it for quick snaps like ebay.
artyH
Nov 16, 2014 21:40 |  #12
The 35F2 IS is great in museums, and would be perfect for both cameras. Mine is very sharp.
DreDaze
DreDaze's Avatar
Gallery: 19 photos
S.F. Bay Area
Nov 17, 2014 00:31 |  #13
I'd go for a stabilized f2.8 17-5Xmm zoom instead
Andre or Dre
gear list
Instagram (external link)
my 366 for 2016 (external link)
2,125 views & 0 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.00193 for 4 database queries.
PAGE COMPLETED IN 0.06s
Latest registered member is Hslim
822 guests, 302 members online
Simultaneous users record so far is 6106, that happened on Jun 09, 2016
