Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Canon EOS Digital Cameras
Reply
Thread Tools Display Modes
Old 23rd of February 2006 (Thu)   #1
reewik
reewik's Avatar
Default Rebel Question
Since I bought my 400 5.6 it seems my mount has become loose.... Not loose I guess but it seems to flex so to speak... Ok I know this is not clear... What do you all think. (I have tightened all the screws, none were loose)
I look forward to an upgrade to possible the 30D or the MkII... we will see what the Easter bunny, my Birthday, Fathers day, Christmas, and whatever other day I can think of will bring me...
I sill love what the rebel does for me so this may be a non issue.
Eric: www.avianart.net
Canon 1D MKIII, 600 f4 IS, 85 1.2L
Canon 1D (Classic),50 2.5 Macro, 1x lifesize
reewik is offline   Reply With Quote
Old 23rd of February 2006 (Thu)   #2
Kinger
Kinger's Avatar
Default Re: Rebel Question
Well with a lens like that make sure that you are supporting the wait of the lens, and not just let it hang off the end of the camera.
Stephen King
Drebel, EF 17-40L, EF 50, EF 85, EF 100-400L, 550 EX
http://home.comcast.net/~king247 (randomly changing)
Kinger is offline   Reply With Quote
Old 23rd of February 2006 (Thu)   #3
reewik
reewik's Avatar
Right, I realize that but i am looking to see if anyone else has also experienced this issue.
Old 23rd of February 2006 (Thu)   #4
Kinger
Kinger's Avatar
Well I haven't experienced that issue at all with mine, and I have had it for two years. But then I just got my 100-400 and it is my first heavy lens.
Stephen King
Old 24th of February 2006 (Fri)   #5
gunnut
I've got a sigma 170-500 with hood hanging on my rebel.I have not noticed it being loose.I use it manly with a monopod,and the clamp bracket around the lense.
gunnut is offline   Reply With Quote
Old 24th of February 2006 (Fri)   #6
AMainePhoto
AMainePhoto's Avatar
how bad is it flexing?
Canon DSLR 350D - black
Sigma 70-300mm F4-5.6 DG Macro
Sigma 10-20mm F4-5.6 EX
Canon BG-E3 Battery Grip
Canon SpeedLite 420EX
Apple Powerbook G4 - Tiger
AMainePhoto is offline   Reply With Quote
Old 24th of February 2006 (Fri)   #7
reewik
reewik's Avatar
Well with nothing to campare it too it is hard to say... I can hear it move it that indicates anything.. I can probably see a mm of space if I put a little pressure on it??
Old 24th of February 2006 (Fri)   #8
maggie_potatoes
maggie_potatoes's Avatar
At what weight are lenses considered heavy enough to require support?
Mags
maggie_potatoes is offline   Reply With Quote
Old 24th of February 2006 (Fri)   #9
Kinger
Kinger's Avatar
Ok, I may be wrong in this assumption, but if the lens weighs more then the camera, then support the lens.
Stephen King
Old 24th of February 2006 (Fri)   #10
Steve Parr
should have taken his own advice
Steve Parr's Avatar
Quite honestly, I never gave it much thought, but that makes perfect sense...
Steve
Steve Parr is offline   Reply With Quote
Old 24th of February 2006 (Fri)   #11
Curtis N
Master Flasher
Curtis N's Avatar
Perhaps a good rule of thumb is, if the lens has a tripod ring, it's meant to be supported. I don't think a normal person is strong enough to cause damage by trying to hold it up with the camera, though.
To the OP: I would have the camera/lens checked by someone knowledgeable. The flexing you describe doesn't sound right, and it could cause focusing problems if the amount of flex changes between the moment of focus and the moment you take the shot.
Chicago area POTN events
Flash Photography 101 | The EOS Flash Bible | Techniques for Better On-Camera Flash | How to Use Flash Outdoors | Excel-based DOF Calculator
Curtis N is offline   Reply With Quote
Old 24th of February 2006 (Fri)   #12
Pyrex
Pyrex's Avatar
I feel a bit presumptious adding to this as a fairly new user of an XT Rebel, but I have seen several magazines comment on NOT supporting a heavy or long lens with the body.
They all say hang the camera off the lens, as the lens can support the weight of the body, but the camera body WILL flex if you try to hold the lens up with it.
Hope you haven't already strained it....
EOS Digital Rebel XT (Black)
EFS 18-55 USM kit lens / EFS 10-22 USM
EF 70-200 USM f2.8L / EF 50 USM f1.4
EF 2X Mk11 Extender
Speedlight580EX /Jessops Ext Tubes
Pyrex is offline   Reply With Quote
Old 24th of February 2006 (Fri)   #13
reewik
reewik's Avatar
Well, the camera has no problems and I always hold the lens not the camera no matter what lens I use... Ok the 50 and , kit, and 28-105 I do not but the rest I do... The bad part is I cannot just hang it over my sholder.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Rebel XT Question..... ItsMike Canon EOS Digital Cameras 17 11th of September 2006 (Mon) 02:04
Question about my Rebel XT hasan_Z Canon EOS Digital Cameras 11 19th of July 2005 (Tue) 10:32
Rebel xt question Learner Canon EOS Digital Cameras 15 13th of July 2005 (Wed) 18:55
rebel xt question.. smittymike19 Canon EOS Digital Cameras 1 19th of April 2005 (Tue) 12:34
D Rebel Question bballboy30 Canon EOS Digital Cameras 8 30th of October 2004 (Sat) 14:52
