FORUMS General Gear Talk Tripods, Monopods & Other Camera Support
Thread started 15 Jan 2015 (Thursday) 06:31
RRS tripod equivalent to Gitzo series 3
Tareq
"I am very lazy, a normal consumer"
Jan 15, 2015 06:31 |  #1
Which tripod from RRS has similar or equivalent specifications to Gitzo series 3 [mountaineer] CF?
I am looking for a tripod that has 3 main features:
1. Load capacity minimum 20KGs even it is overkill
2. Folding length less than 60cm [<23"]
3. Weight less than 2KG, but i may accept weight around 2.5KG only to give rigidity or sturdy to the tripod
Any recommendations?
Galleries:
http://hamrani.deviant​art.com/gallery/ (external link)
Facebook (external link)
peter_n
Jan 15, 2015 09:08 |  #2
I think the only tripod that RRS makes that comes with a center column is their TQC-14 which is a small travel tripod. Their regular tripods are all systematics, although you can buy center columns for them separately. They have a new series 3 model TVC-34 which is a direct competitor to the Gitzo 3542LS, with very similar specs and price.
~Peter
Tareq
Jan 15, 2015 13:04 |  #3
peter_n wrote in post #17383635 (external link)
I see, then i have to keep a look at that model
Thank you very much!!!
Galleries:
peter_n
Jan 15, 2015 20:38 |  #4
They also have the 3 leg section series 3 tripod that was their very first model, the TVC-33. Inevitably, it has a much longer folded length than the new TVC-34 which isn't so good for travel.
The Gitzo 3542LS/RRS TVC-34 specs are great for an average sized person who doesn't use very big lenses and may occasionally take the tripod on a trip. I use a Gitzo 3541LS and it's a really good tripod too, although no longer manufactured. I have a Gitzo center column for it also which I've never used, but will someday...
~Peter
Tareq
Jan 16, 2015 04:50 |  #5
peter_n wrote in post #17384632 (external link)
This is the main reason i use Gitzo series 3 and wanted to upgrade it to newer version of Gitzo or RRS, i want a tripod that is for travel with good enough load capacity even for long lenses or heavy gear so it is overkill for smaller gear and folding smaller, i have Gitzo series 2 but it is not so sturdy enough to be honest, and i always feel worried it may not give sharp results for longer exposure in windy conditions.
I am not sure if i should go with 3 sections or 4 sections legs, i did read the details between the two and still if i should look at any tripod overall or each/specific detail must be considered.
Galleries:
peter_n
Jan 16, 2015 09:00 |  #6
For travel I'd definitely go with a 4 leg section model. 26 inches is too long as I generally travel as light as possible.
~Peter
Tareq
Jan 16, 2015 17:11 |  #7
peter_n wrote in post #17385236 (external link)
Yes, i agree, i want lighter but sturdy enough tripod, so if that 4 leg sections is lighter or folder smaller then it will be a better choice, and sure i can read each tripod specifications to see which one is meeting the needs, but hope i don't buy another tripod and then it is same as what i have already if not better, all those tripods are very expensive and i don't look at anything less than Gitzo/RRS, even Manfrotto tripods i don't look at nowadays.
Galleries:
koala ­ yummies
Gallery: 33 photos
Jan 21, 2015 17:27 |  #8
I have two RRS, a TVC-33 for primary use, and a TVC-24 for travel. Peter has some good recommendations and I also suggest looking at the TVC-34 and also the 24 for your load capacity, weight and collapsed dimension requirements. Both are quite short, light and robust. The TVC-34 is an inch longer than the 24 when collapsed while 10" taller in extended-height but the larger-diameter 3-series leg-apex and extra pound of weight is another thing to consider as well along with what head you'll be using.
The TVC-24 with BH-40 is a total collapsed length of 22.2". Mine pictured below is a little longer at 23.5" but I have two additional clamps between the head and legs, one for a removable carrying strap and the other so the ball-head can be removed from the legs easily (dovetail on the bottom of the head). When the ball-head is removed the legs are just 20" (with clamp) when collapsed and the ball-head can go in the camera bag. It is a little extended-height limited for taller people (I'm 6'1") but for it's uses as a smaller lighter travel-use/lots of walking/hiking tripod, it works perfectly. I pretty much never need shoot above eye-level when out and about and crouching down to frame upwards isn't a deal-breaker for me but might be for others.
Even though both the 24 and 34 are 4-leg sections, they're much more stable than my 3-section thicker-leg (aluminum) Manfrotto I keep around. Regarding center sections personally I avoid them now but you can always add and remove them pretty easily with RRS.
TVC-33 and TVC-24, you can see how much narrower the 2-series apex is compared to the 3-series:
Though the TQC-14 is another consideration as it's their smallest and lightest overall tripod and comes with a center column like Peter mentioned (which is also removable). It's just as strong, there's a photo of the RRS owner hanging his entire body weight from one demonstrating that all RRS load-capacities are pretty conservative:
http://blog.reallyrigh​tstuff.com …3/03/TQC-Joe-1024x656.jpg (external link)
I got a hands on with the TQC-14 when I visited RRS and was extremely impressed with it but ultimately decided on the 24.
It's a tough decision to make spending this much on a travel tripod, I wasn't going to spend this much without a hands-on/trip up to Obispo, so hopefully this personal experience helps as not everyone can get a hands-on before buying.
i-G12
Wat?
Jan 22, 2015 03:11 |  #9
Great review.
Thanks for sharing that.
I'm still trying to figure out which RSS tripod to get and yur comments shed some additional light on the issue for me!
Tareq
Jan 30, 2015 12:54 |  #10
Thank you very much, it is helpful indeed!!!
Galleries:
jlt23
Jan 31, 2015 10:36 |  #11
I have virtually the same setup as koala yummies. I really like RRS gear and recommend them. I also have gitzo, but RRS takes the edge for me.
James
00derek
Gallery: 28 photos
Joined Dec 2012
Jan 19, 2018 08:24 as a reply to  @ koala yummies's post |  #12
Hi,
I'm getting ready to pull the trigger on a TVC-33, but I'd like to know if you think the TVC-34 is significantly less stable with 4 leg sections. Portability is important to me too, so if the difference in stability is small, I'd rather get the extra benefit of compactness. I'm sure a 3 section will always be slightly better than a 4, but is it better enough to have to give up the convenience of being able to pack the smaller tripod easily?
Thanks in advance.
Derek.
ShadowHillsPhoto
Gallery: 156 photos
Joined Aug 2015
Post edited 4 months ago by ShadowHillsPhoto.
Jan 19, 2018 10:14 |  #13
00derek wrote in post #18544333 (external link)
Hi,
Thanks in advance.
Derek.
I haven't used the regular TVC-34, but I do own the TVC-34L and it is rock solid. I've had some hands on experience with the TVC-33 as well, and while it may be theoretically more stable I think you would be hard pressed to ever notice a difference. My TVC-34L mostly gets used with a 600mm f4 IS II, frequently at 840mm, and I've never felt i was lacking stability. I also use it for landscapes and long exposure work, and I mount an AstroTrac to it for tracked star shots
peter_n
Jan 19, 2018 16:08 |  #14
Well this thread is 2 years old and I'm sure Tareq has made his decision and is enjoying his now relatively new gear. :) Modern leg locks are no longer candidates for the transmission of vibration so a 3 or 4 leg section can be chosen on other criteria.
I've sold all my Gitzo tripods and bought a RRS TVC-24 last July after finally being able to evaluate RRS products for myself in the B&H store in NYC. The TVC-24 is just 0.4lbs heavier than my travel tripod and folds to the same size. It's also way smaller in diameter than my Gitzo series-3 systematic. A series-2 RRS tripod is equivalent to a series-3 Gitzo - the model numbers do not match in terms of their specs. I only found this out in the store last year.
~Peter
stevewf1
Feb 20, 2018 02:02 |  #15
I have the RRS TQC-14 tripod with the RRS BH-30 ball head and it's really stable. Holds my 7Dii with grip and various lenses steady with no problem. The center column is also very steady if you don't extend it all the way. Careful with the center column though. The "butterfly" ring to loosen/tighten the column can chop up your fingers because of its close proximity with the ball head if you're not careful.
Overall, I'm very happy with this small but sturdy tripod setup but keep in mind, the legs and ball head together will set you back almost $1,200...
Steve
5,311 views & 5 likes for this thread
Latest registered member is ChrisS76a
755 guests, 305 members online
