| sponsored links |
Thread Tools | Display Modes |
#1 |
Hello everybody,
I am thinking about buying this lens as part of my current collection. Would you please post photos you have taken with the 28mm f/1.8? Do you think this would be a good addition for low light/indoor sports photography? Thanks in advance!
~Jenn~ "Raise the bar to a level only you can jump!" {Gear List & Market Feedback} |
| sponsored links |
#2 |
Jenn I see you have the 85 1.8. The 28 is wide how do you imagine using it? What sport?
Bill Canon 1DMkII, Zooms: Canon 17-40 F4, Canon 24-70 2.8, Canon 70-200 2.8 IS, Sigma 120-300 2.8 EX DG , Canon 1.4 TC Primes: Canon 28 1.8, Canon 50 1.8 II, Canon 85 1.8, 400 2.8 II, Speedlite 420ex, Speedlite 580ex. |
#3 |
I bought it for low-light shots, when I'm too close to the subjects for the 50f1.4, which I consider better.
28f1.8 is not as sharp as 50f1.4 and may not focuses so quick, but it's solid and I'm happy to use it.
G6; 30D, 40D, 28F1.8, 50F1.4, 60F2.8M, 85F1.8, 10-22, 17-85IS, 70-300IS
http://www.flickr.com/photos/ilcantiere/ |
| sponsored links |
#4 |
I think this lens is every bit as good as the 50/1.4 and 85/1.8 in terms of IQ, build, etc. It is fast in low light and quick to focus. I like it very much.
Scott Vista owner...and user _________________________________________Gear www.scottcphotography.com |
#5 |
should have taken his own advice
Here's one I shot from the top of the CN Tower in Toronto last August:
![]() And here's a shot inside a theatre in San Diego's North County: ![]() I find that I don't use it nearly as often as I thought I would. Even still, when I want it, I'm glad I have it. I found mine used, and am generally happy to have it... |
#6 | |
I was thinking of using it for group shots of my daughter's cheerleading team. Will the lens be good for that? I will be taking the pictures while they are doing their routine. What do you think?
#7 | |
#8 | |
#9 | |
#10 | |
#11 |
Here are some shots taken with the 300D:
http://www.pbase.com/bosphorousman/inbox If you're using a 1.6 sensor camera and focusing at wide apertures, larger than f3.5 - f3.0, then you need to turn the MF to the right past the point of focus. Then press the shutter half way to zero in on your subject. This will give you more accurate focusing with the Digital Rebels. The 20D is supposed to have better focusing with larger aperture settings. Hope this helps! It's a great little lens. |
#12 | |
Yes, both of those were wide open... |
#13 |
Just to see on portrait. I dont do portrait yet but this is the 28
Ben |
#14 |
i guess it didnt upload
#15 | |
Thanks again!
| Thread Tools | |
| Display Modes | |
| canon 28mm 2.8f lens | jimbobski | Canon EOS Digital Cameras | 0 | 19th of January 2003 (Sun) 14:15 |
