Thread started 13 Mar 2015 (Friday) 11:46
Prev/next
Autofocus in Live View mode - Bad idea?
texshooter
Post has been edited over 2 years ago by texshooter.
Mar 13, 2015 11:46 |  #1
I hear one should not use autofocus in Live View mode when precise and reliable focusing is required. Rather, one should zoom in 10x and focus manually instead. This is because lenses are not designed for Live View focusing and, as such, cannot be calibrated like viewfinder autofocus mechanisms can. Is this true?
shaunmcfd
shaunmcfd's Avatar
Joined Nov 2012
Mar 13, 2015 11:48 |  #2
I've never had an issue when auto focusing in live view.
6D | 5D4 | 24-105 f4L | Sigma 50 2.8 Macro | 17-40 f4L| 135 f2L | 70-200 f2.8L ii | Sigma 35 1.4 Art | Tamron 24-70
GeoKras1989
GeoKras1989's Avatar
Joined Jun 2014
Mar 13, 2015 11:55 |  #3
banned
I only use LV to see how accurate PDAF is. Phase detect is never better than LV. It can only be as good as LV.
WARNING: I often dispense advice in fields I know little about!
AJSJones
AJSJones's Avatar
Joined Dec 2001
California
Post has been edited over 2 years ago by AJSJones.
Mar 13, 2015 12:17 |  #4
texshooter wrote in post #17473284external link
Contrast detection AF is more accurate than PD simply because it does not need to be calibrated - it requires more time and confidence that the specific feature in the AF zone is the one the user wants to use. It is usually simpler/quicker to zoom in and manually focus because WYSIWYG - you can see that the target is in focus kin the image that will be captured.
"Modern lenses are not optimized (in gearing) for MF" is perhaps what you have heard - that means that you only need a small amount of rotation of the focus ring to go from MFD to infinity (it's designed this way so AF can work quickly) but for manual focus you need to be very precise in your rotation. Movie lenses and older MF lenses you need to turn the focus ring a long way to get from MFD to infinity, so it's easier to make fine adjustments to focus position.
My picture galleriesexternal link
BigAl007
Repps cum Bastwick, Gt Yarmouth, Norfolk, UK.
Mar 13, 2015 12:33 |  #5
The Contrast Detect AF system that is used in LV, unless you use the quick focus mode that flips the mirror up does a normal Phase Detect AF and drops the mirror, uses the actual sensor to determine the state of the focus. Because it is measuring the focus at the sensor plane it needs no calibration. PDAF uses a sensor mounted in the bottom of the mirror box, which has to be mounted at exactly the same optical distance from the lens as the sensor is. This is where the possibility of miscalibration comes from.
The real problem is that CDAF is perfectly accurate, but really really slow. Also you still have the problem of making the area selected from the image that is used to Af actually look exactly at the spot you want in focus. By using manual focus, and 10× magnification you can ensure that the exact point you want to be in focus is, and usually without worrying about how much contrast you have present, or it's exact orientation.
Alan
My Flickr (external link)
texshooter
Post has been last edited over 2 years ago by texshooter. 2 edits done in total.
Mar 13, 2015 13:45 as a reply to BigAl007's post |  #6
Au contraire. According to Michael Tapes, the designer of LensAlign, auto focusing using Live View is unreliable:
https://mtd.zendesk.co​m ...an-I-calibrate-Live-View- (external link)
GeoKras1989
Joined Jun 2014
Mar 13, 2015 16:36 |  #7
banned
texshooter wrote in post #17473479external link
https://mtd.zendesk.co​m ...an-I-calibrate-Live-View-external link
I'm a tad curious. If you already have the answer, why ask the question?
texshooter
Mar 13, 2015 17:11 |  #8
GeoKras1989 wrote in post #17473704external link
Second opinion. Do you believe everything you're told?
apersson850
apersson850's Avatar
Traryd, Sweden
Mar 13, 2015 17:12 |  #9
What he's referring to is that the AF motor drives in the lenses are designed for quick point to point operation. From current position to position of correct focus, as calculated by the standard AF system.
He seems to neglect that today's USM drives are designed with both rapid execution of standard AF commands as well as the slow motion more suitable for video production. Look at the power focus function in lenses like the EF 300 mm f/2.8L IS II USM or the new EF 400 mm f/4 DO IS II USM, for example.
He also totally forgets that the STM focus drive motors are fully designed to support slow, creeping focusing operation as well as rapid focusing.
So I dare say the statement quoted above is either several years old, or he doesn't know what he's talking about.
Anders
GeoKras1989
Joined Jun 2014
Mar 13, 2015 17:49 |  #10
banned
texshooter wrote in post #17473749external link
I understand wanting a second opinion. It is telling those who provide what you ask for that they are wrong that I find quite odd.
GeoKras1989
Joined Jun 2014
Mar 13, 2015 17:52 |  #11
banned
apersson850 wrote in post #17473752external link
I lean heavily in this direction. I've had 500D, 60D and 6D that all have LV focus. It is dead-on with any lens I mount. CDAF is so accurate because it is an iterative process. PDAF is so useful because it is so fast. They are two entirely different animals.
texshooter
Mar 13, 2015 18:04 |  #12
GeoKras1989 wrote in post #17473799external link
I reserve the right to tell anybody they are wrong whenever I decide they are wrong. I also have the prerogative to change my mind about who is wrong after I've elicited their opinion--even while I wait for a third one. Now then... after reading apersson850's reply, I'm on the fence again.
GeoKras1989
Joined Jun 2014
Mar 13, 2015 18:09 |  #13
banned
texshooter wrote in post #17473816external link
Exactly! And that is why we ask for others' opinions. I did the same thing when considering a 1D3/7D a little while ago. I decided to stick with my 60D. Now I am thinking about upgrading my crop body to the 1D4! The more you ask, the more you know. Sometimes it helps you decide. Sometimes it just adds to your confusion. Sometimes it just makes your head hurt.
WaltA
WaltA's Avatar
Joined Feb 2006
White Rock, BC, Canada
Mar 13, 2015 18:19 |  #14
Well, the problem with opinions is that they are often wrong.
Or they may be right for the opinion-holder and wrong for you.
But its nice to share opinions - even if we may decide not to adopt them.
Whats really nice is to have this conversation and then go out and test it for yourself and tell us what worked for you.
Walt
400D, 5D, 7D and a bag of stuff
AJSJones
AJSJones's Avatar
Joined Dec 2001
California
Mar 13, 2015 18:21 |  #15
Live View (contrast-detection) AF on a still target is more accurate than phase-detection AF. It should be so. Contrast detection is using the actual sensor to determine focus; phase detection is not. Overall we found about one shot in ten was out of focus with phase detection.
Phase-detection AF has more shot-to-shot variation than contrast detection. It’s not huge, but it’s real. This shouldn’t surprise anyone. Phase detection was developed for fast AF speed and to detect subject movement. It wasn’t developed to be more accurate.
Microfocus adjustment pulls good phase-detection AF results up to a par with Live View, but it doesn’t eliminate the small amount of shot-to-shot variation that phase-detection AF has.
This is based on, wait a minute, it's actual dataexternal link, not opinions or guesses:D:D:D (There's a follow-up hereexternal link.) Roger Cicala is one of the few people who is in a position to test these issues on multipleexternal link lenses and is extremely methodical/systematic about his testing.
4,342 views & 3 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.00664 for 4 database queries.
PAGE COMPLETED IN 0.03s
Latest registered member is brirog1211
883 guests, 459 members online
