Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Canon EOS Digital Cameras
Reply
Thread Tools Display Modes
Old 25th of July 2003 (Fri)   #1
Highland
Default i950
Anyone use the i950 to print their pix.
Having a heck of a time getting the images from the printer to match the screen - any advice?
Also noticing that printed images on close exam seem to almost have a white haze layer on them.
Using 4x6 glossy plus paper. Images from 10D camera.
Thanks,
Don
Highland is offline   Reply With Quote
Old 25th of July 2003 (Fri)   #2
tannoy
Default Re: i950
Are you using a Macintosh or a PC?
Darrin
1DMK2,35 1.4L, 50 1.4, 135 2.0L, 300f4 L is, 16-35 2.8L, 24-105 f4L, 1.4 Canon t-con
tannoy is offline   Reply With Quote
Old 25th of July 2003 (Fri)   #3
Belmondo
Admin
Belmondo's Avatar
Default Re: i950
I've had my i950 for a while, but really hadn't paid much attention to the fidelity of the prints to the Photoshop files until recently. The prints, although very clear and bright, do tend to differ somewhat from what's being displayed on the monitor.
I'm using a good quality photo paper, but not Canon's own (as they recommend). I'll pick up some of that when I can find it and see if that makes a difference---I suspect it won't. Next, I'll start playing around with printer settings and will report back on what success I've had, if any.
Obviously it's a matter of calibration, and that will take some time and experimentation. I, too, would appreciate hearing from others who've already gone through that.
All in all, though, I love the printer. Not nearly so much as the camera, however.
I'm not short. I'm concentrated awesome!
Belmondo is offline   Reply With Quote
Old 25th of July 2003 (Fri)   #4
justme_dc
Default Re: i950
I am using an i950 with a mac running OSX and OS9 so far it works just fine. No printer will print perfect out of the box, you almost always have to do a little set up. You have to calibrate your monitor then make some test prints and calibrate your printing profile a bit but once you do that it prints like nobody's business!
I really like the i950 I hope it works out for you.
justme_dc is offline   Reply With Quote
Old 25th of July 2003 (Fri)   #5
Highland
Default Re: i950
How does one calibrate the monitor.
I am running win 98 on a PC.
Don
Old 25th of July 2003 (Fri)   #6
Highland
Default Re: i950
Don
Old 25th of July 2003 (Fri)   #7
justme_dc
Default Re: Re: i950
Don
I am no PC expert but there should be some sort of Gamma set up menu in your control panels or software that came with your monitor. Failing that, colorvision makes calibration tools such as the spyder. Perhaps a PC guy will have a better answer.....
Old 25th of July 2003 (Fri)   #8
eddylush
Default Re: i950
If you have photshop in the control panel there will be a utility called adobe gamma run it and follow the on screen instructions!
A bit more rough and ready way is to print a kodak colour control patch then hold it to the screen and ajust the best you can!
There are also variouse monitor calibration things on the net! just type monitor calibration and search!
Good luck
eddylush is offline   Reply With Quote
Old 25th of July 2003 (Fri)   #9
kn_guy87
kn_guy87's Avatar
Default Re: i950
Thanks,
Don
I have the i950 and the i9100. I get excellent results with both printers. Of course, I use Canon inks and Canon papers. I use the Easy-PhotoPrint s/w that came with the printers. This software allows me to set the media types correctly.
The Canon papers do cost more but they will give you the best results. I shopped around and found that www.canogacamera.com have the best prices on Canon papers (especially the 13x19 size). If anyone can find a cheaper place, please do share.
I read that the other good but less expensive are
* Ilford Galerie - Smooth Gloss Paper from Sam's Club ($25 for 100 sheets 8.5x11)
* Office Depot Premium High-Gloss Photo Paper from Office Depot of course ($28 for 100 sheets 8.5x11)
I also read that Kodak papers would not give you good results on Canon printers.
kn_guy87 is offline   Reply With Quote
Old 25th of July 2003 (Fri)   #10
tikkeltokkel
Default Re: i950
if your printer has a choice of printing "Adobe RGB" or "sRGB" make sure you try the "sRGB" your colours will be richer.... try that
tikkeltokkel is offline   Reply With Quote
Old 25th of July 2003 (Fri)   #11
Highland
Default Re: i950
Thanks gang. Great stuff.
Only have Adobe PS elements at the moment, but I will look there for gamma match.
Tried the link www.canogacamera.com.com, but no luck.
Thanks again,
Don
Old 25th of July 2003 (Fri)   #12
CyberDyneSystems
Wait, all that time and all I get is "Cream of the Damn Crop" ?!!!!!!!!!!!!!!!!
CyberDyneSystems's Avatar
Default Re: i950
Take one of the .com off of the above link
It is ;
Printer-monitor-camera color management is one of the ultimate pains in the rear!
There are quite a few good threads on the subject though. But you can not expect your prints to look exactly like your monitor,. or your monitor to show you exactly what the camera has taken,. star reading on color management and you will go nuts just tryoing to understand how it is even remotel possible to pull such a feat off!
CyberDyneSystems is offline   Reply With Quote
Old 25th of July 2003 (Fri)   #13
sochigetto
Default Re: i950
You know - I've had problems getting good images from my 10D. I've been going to quite a few forums to see what solutions others have tried. It seems to be a pretty widespread issue to get good image quality on photographic paper. Everyone points out the focusing issue - maybe there's a color management issue also. I've shut off the EXIF, changed the color space to Adobe RGB when shooting - tried to Adobe Gammaize my monitor and it's still kind of hit or miss. Why buy some Spyder for a few hundred bucks and then the technology changes again. Prints at home are not cheap. I've gotten great prints from scans, also from my Olympus 360D(L)(?) - a point and shoot. The flash pictures are great color saturation, the pictures shot in the shade come out with out much manipulation. Why isn't it that easy with the 10D? I know it's not a point and shoot but all the monitor and printer modifications that have to be done is kind of ridiculus. Oh well, I have a Best Buy down the block from me. I took my files there to be printed - wow! At 29 cents per print - I may not be doing much printing at home. The young lady there also let's me behind the counter to do my own stuff. I did 20 4x6's in about 10 minutes. Modifications and printing.
Oh well - just my thoughts.
andy.
sochigetto is offline   Reply With Quote
Old 26th of July 2003 (Sat)   #14
Mark Kemp
Default Re: i950
Try following sites for advice
http://www.icehousedesigns.com/tools/monitor.php
http://www.normankoren.com/makingfineprints1A.html
http://www.photoscientia.co.uk/
http://www.photoscientia.co.uk/Gamma.htm
Mark Kemp is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
replacement for i950 printer Bushman RAW, Post Processing and Printing 4 14th of June 2005 (Tue) 19:06
i950 problem bwmatz RAW, Post Processing and Printing 0 11th of February 2005 (Fri) 18:35
Canon i950 Troubles harttim1 General Photography Talk 3 26th of December 2004 (Sun) 10:01
i950 vs i960 Rusty Shackleford General Photography Talk 0 10th of November 2003 (Mon) 17:52
i950 and p-400 Highland Canon EOS Digital Cameras 0 31st of July 2003 (Thu) 09:11
