Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Weddings and Other Family Events
Reply
Thread Tools Display Modes
Old 3rd of March 2006 (Fri)   #1
VanceW
Default First Wedding Under My Belt.
Okay,
Guess I better start pitching in some images around here, been hanging around in the dark corner long enough.
This was my first real wedding gig with digital and I was as nervous as a long tailed cat. Luckily for me a buddy of mine from another forum drove all the way over to help out and lend his moral support.
Anywho... here are just a few of the images. Some will be recieving some more work on them.
Bride with daughter.
The Groom (and buddy)
The Bride
The Kiss
Formal
Sorry for the edit.. pressed enter key by mistake.
Vance White
30D(new)10D
17-40mm f4/L 28-135mm IS 70-200mm f4/L
400mm 5.6/L and a whole bag of extra goodies.
My humble spot on the big ole web.
http://www.vancewhitephotography.com
VanceW is offline   Reply With Quote
Old 3rd of March 2006 (Fri)   #2
bpuppy
bpuppy's Avatar
Default Re: First Wedding Under My Belt.
That first one is a nice moment captured ... did you add the soft focus effect? I'd like to see it au naturel.
bpuppy is offline   Reply With Quote
Old 3rd of March 2006 (Fri)   #3
VanceW
Thanks!
I did do a post process on the soft focus shot. I don't have the unprocessed shot on my page, but here's the shot right before that one...
I'm actually thinking of doing it in B&W .. might be a nice look.
Vance White
30D(new)10D
Old 4th of March 2006 (Sat)   #4
CyberPet
Hiding Under a Rock
CyberPet's Avatar
Watch that white balance, now the photo's are a bit all over the place in colors. But nice photo's so with some tweaks they'll be thrilled!!
/Petra Hall
Click here to view my geeky gear list
I shoot as much as possible in available light... sometimes, my flash is available – Joe Buissink
CyberPet is offline   Reply With Quote
Old 4th of March 2006 (Sat)   #5
VanceW
Thankfully I shot in RAW, so I can get back in there and fix'em up.
Thanks for the comments Petra.
You want a real nightmare... the reception was in an adjoining building, and the interior, walls, ceilings, doors were a dark dark (almost purple) blue.
Kinda made the gymnasium/sancuary(sp) seem pleasant. If you don't count the basketball hoops at both ends.
Vance White
30D(new)10D
Old 4th of March 2006 (Sat)   #6
CyberPet
Hiding Under a Rock
CyberPet's Avatar
Poor Vance
/Petra Hall
Old 4th of March 2006 (Sat)   #7
VanceW
Yeah .. I can see in your eyes how bad you feel for me.
Here's a shot my buddy/second shooter took .. that shiny head in the chair is me.
And from the pulpit, you can try for a three pointer over the Grooms right shoulder.
Vance White
30D(new)10D
Old 4th of March 2006 (Sat)   #8
Wazza
Wazza's Avatar
Some cool shots there. I remembered reading your post saying you've also got a wedding coming up. Good to hear you didn't pass out from it.
If you shot them all RAW (which I hope you did), it should be easy to make all white balance the same with colour temp settings.
Wazza is offline   Reply With Quote
Old 4th of March 2006 (Sat)   #9
CyberPet
Hiding Under a Rock
CyberPet's Avatar
OMG, that's a blue room for sure!!!
But good thing you had that shiny head, sorta built-in ligthsphere (JOKING!)
/Petra Hall
Old 4th of March 2006 (Sat)   #10
Az2Africa
Az2Africa's Avatar
Weddings are scarey for sure. But you did good. Thank God for raw.Some BG colors and mixed lighting can be a real challenge. I did a couple of weddings for friends and they loved the shots and keep sending people to me. Then I have to tell them I don't do weddings!
"If you're not living on the edge. You're taking up too much room !"
My Gear Arizona's POTN Flickr Gallery
Az2Africa is offline   Reply With Quote
Old 6th of March 2006 (Mon)   #11
VanceW
I think that's what my buddy was going for.
Az2,
Yeah, I learned a long time back that the only way to go is RAW. I tried to talk my buddy into using an established wedding photographer, but he just wouldn't let it go.
Vance White
30D(new)10D
Old 6th of March 2006 (Mon)   #12
PIXI_666
PIXI_666's Avatar
Yes i too think a bit of tweaking with white balance and these shots will pop out! I find them to be a bit cold, but it's probably because of that nasty blue wall hahaha - maybe a bit of warm filter through them in PS and they wil be eve better! I liek your close ups of the bride and groom individually!!
The first shot is a gorgeous capture!!
Del
"Capturing, Creating & Preserving your memories"
Adelle Cousins Photography
www.adellecousins.com.au
info@adellecousins.com.au
PIXI_666 is offline   Reply With Quote
Old 6th of March 2006 (Mon)   #13
VanceW
Thanks for the kind words Del.
That first shot was down with a PS plug-in called virtualphotographer.
Here's a link if you want to try it. It isn't for Mac's though.
http://www.optikvervelabs.com/download.asp
Vance White
30D(new)10D
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
my little black belt mkuriger Performing Arts 21 27th of July 2007 (Fri) 10:44
First wedding under my belt! Big John Weddings and Other Family Events 9 16th of May 2007 (Wed) 11:45
I DID IT! First Wedding Under my Belt xmacvicar Weddings and Other Family Events 17 22nd of April 2007 (Sun) 23:15
2nd wedding under my belt... much happier with this one than the 1st PuR HART Weddings and Other Family Events 8 24th of April 2006 (Mon) 10:56
Rust Belt RbnDave Nature & Landscapes 13 22nd of January 2006 (Sun) 19:06
