#1 |
Hi All,
I was justwondering, with my 20D I generally attach my 430EX flash and tilt the head either 45 or 60 degreesto bounce the flash off the ceiling and shoot in manual mode between 1/60th & 1/125th at F4.0-F5.6 with a Stofen Onmi-bounce at ISO400 with just ok results..but most of the time the pictures are overexposed I also add +2/3 Flash exposure Compensation set in the camera..this works great with the on-board flash My question is being that I am shooting in Manual modewith an external flash is the camera really applying the +2/3 FEC and is that why my pictures are over exposed ?? basically what is the best way handle flash with the 20D ?? Thanks in advance...Shkj |
| sponsored links |
#2 |
in Manual mode, you set your flash to expose for your subject.
The simplest way to look at this is. Shutter/Aperture controls background/ambient light, and FEC and Aperture controls subject exposure. Of course Aperture also controls your DOF. And of course Shutter will control your motion. I cover a range of events.. From hollywood A list to Fashion Runway. So flash is a big part of my life. Depending on the situation I might be using a portable softbox or a LS2. But I first make sure I know how fast things are moving (nothing than a super blurry picture). That will give me an idea what shutter speed to keep from going over or under. Next I check out how much background I have. This will tell me how much ISO I need + shutter speed. How far am I from subject, than subject to background, this gives me an idea of aperture. From there Its pretty much basic photography. I never close up aperture more than f5.6, this keep the background still pretty blurry and not imprint any distraction to the picture. Of course I carry a 2 battery packs, so I get the 1s recharge time, to keep shooting. You'll never know which star will show their personal parts next Last edited by mbze430 : 4th of March 2006 (Sat) at 20:39. |
#3 |
Moderator
Cocker Spaniel Mod Join Date: Jun 2004
You're bouncing off the ceiling and using an OmniBounce? ISTR other threads here where the OPs found that the combination of a diffuser, bounce, and E-TTL threw things off. What ended up happening was that the combination of the bounce and the diffuser led to such a weak preflash reading that the system really went all out on the actual flash, leading to overexposure.
Jon ---------- EOS, Powershot and Domke - it doesn't get any better than this!
T90 and stuff | F-1n, New F-1, FTb and more stuff out on loan Cocker Spaniels Maryland and Virginia activities DC Cherry Blossoms Image Posting Rules and Image Posting FAQ Report SPAM, Don't Answer It! (link) PERSONAL MESSAGING REGARDING SELLING OR BUYING ITEMS WITH MEMBERS WHO HAVE NO POSTS IN FORUMS AND/OR WHO YOU DO NOT KNOW FROM FORUMS IS HEREBY DECLARED STRICTLY STUPID AND YOU WILL GET BURNED. |
| sponsored links |
#4 |
Sorry if I'm a bit late on this, but why are you using a + 2/3 FEC, then complaining that your pictures are overexposed. What are they like if you dont use any FEC?
1DsMkIII | 1DMkIIN | 20D + grip | 70-200 f/2.8L IS | 24-70 f/2.8L | 17-40 f/4L | 50 f/1.2L | WFT-E1 & E2 Transmitters - Click Here for setup advice | CP-E4 Battery Pack x 2 | ST-E2 | 580EX | 550EX | 420EX | Tripod + monopod | Bowens Esprit Gemini 500W/s heads & Travel-Pak | All this gear - and still no idea |
#5 | |
Moderator
#6 | |
Moderator
#7 | |
All ETTL does is make an programmed decision on how much output of a flash is required. Here is a very simple excerise for you. turn off ETTL, and set it to manual flash. Now YOU are in control of flash power. That's all ETTL does. Now, you are at task to make the right decision for the amount of output for which aperture you will use. Last edited by mbze430 : 12th of March 2006 (Sun) at 13:13. |
#8 | |
Moderator
I also think we might be meaning the same thing. However, when using ETTL, the aperture does *not* influence the amount of light hitting the sensor: If the aperture is closed further, ETTL tells the flash to output more. The result is that the same amount of light reaches the sensor. Therefore exposure is the same. (Flash output is different though) When using manual flash, the flash gives the same output every time, therefore the aperture can be used to regulate the amount of light reaching the sensor (thus exposure) |
| Thread Tools | |
| Display Modes | |
| Flash Exposure Compensation | azpix | Small Flash and Studio Lighting | 3 | 24th of July 2007 (Tue) 07:55 |
| 20D Exposure Compensation | cthomas | Canon EOS Digital Cameras | 17 | 15th of January 2006 (Sun) 19:33 |
| Sigma EF 500 DG Super Flash & 300D: Flash Exposure Compensation? | Vita Rara | Canon EOS Digital Cameras | 2 | 4th of January 2005 (Tue) 15:31 |
| G2 - Flash exposure compensation. | cpc1225 | Canon G-series Digital Cameras | 6 | 29th of June 2004 (Tue) 19:23 |
| Flash exposure compensation question? | charr5 | Canon EOS Digital Cameras | 1 | 24th of May 2003 (Sat) 14:43 |
