Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Canon EOS Digital Cameras
Reply
Thread Tools Display Modes
Old 8th of March 2006 (Wed)   #1
JohnnyBlood
User is banned from forums
JohnnyBlood's Avatar
Default 20D & 5D Eyepiece Cover
I'm now through reading the manual to my Canon 20D for the third time. Every time I read it I learn something new. Some how the first two times I completely missed the part about the eyepiece cover, which is supposed to be used in self-timer or remote switch mode because "stray light may enter the eyepiece" and affect the exposure. Do people have any real time experience with this? Is it really that necessary?
Also, as I contemplated having to start using the eyepiece cover, I began to think about the proper workflow needed to take stunning long exposures at night. This is what I have come up with; am I missing anything?
1.) Use a tripod and make sure tripod is steady (obvious)
2.) Attach remote switch (also obvious)
3.) Enable long exposure noise reduction (C.Fn-02 set to 1:On)
4.) Enable mirror lock up (C.Fn-12 set to 1:Enable)
5.) Compose photograph
6.) Set the mode dial to M and set shutter speed to bulb
7.) Set desired aperture
8.) Slide cover over eyepiece
9.) Press shutter button on remote switch once to activate mirror lock up
10.) Press shutter button on remote switch again to take photo
Am I missing any steps?
JohnnyBlood is offline   Reply With Quote
Old 8th of March 2006 (Wed)   #2
cspratt
cspratt's Avatar
Default Re: 20D & 5D Eyepiece Cover
Not much. I have a so-called eyepiece cover for my 10D. Piece of junk. The one for my 10s got lost years ago. Make your own.
Chris. Spratt
Victoria, BC
In the game of life, Mother Nature bats last. Happy ninth inning.
cspratt is offline   Reply With Quote
Old 8th of March 2006 (Wed)   #3
ScottE
How about deciding the length of exposure, looking at a watch and holding the shutter button on the remote down until the time has elapsed? For very long exposures you may want to use the lock switch on the remote to hold the button down so you can leave the remote and come back later when the time has elapsed. This would be done for things like star trails.
Using mirror lock-up for very long exposures where you use bulb setting is kind of redundant because the camera is stationary for so long during the exposure that the small amount of vibration at shutter release does not do any significant damage.
ScottE is offline   Reply With Quote
Old 8th of March 2006 (Wed)   #4
Quad
Quad's Avatar
You forgot step 7b remove eye piece so cover will fit.
It is very poor part. My old A1 had a small lever by the viewfinder and a small shutter closed inside to close it up. That was an elegant implementation. This was the biggest disappointment on my 5D when I first got it.
Quad is offline   Reply With Quote
Old 8th of March 2006 (Wed)   #5
ScottE
I find it easier to just hang may hat over the back of the camera.
Old 8th of March 2006 (Wed)   #6
jjonsalt
DUCT TAPE, don't leave home without it.
jjonsalt is offline   Reply With Quote
Old 9th of March 2006 (Thu)   #7
CliveyBoy
Duct tape! So simple.
I found that the neck strap swung in the breeze, producing vibrationmovement that defeated the tripod. So I detached the cover from the strap, and could never find it.
Then I bought the angle finder, and never again use the tripod without it. Hopefully, the angle finder provides a sufficient reduction of light.
Clive
50D; 580EXII, 430EXII, 550EX, YN568EX; YN-622C controllers
TOYUG YN622 Guide https://docs.google.com/open?id=0B77...FpqNkpBYXBHajA
CliveyBoy is offline   Reply With Quote
Old 9th of March 2006 (Thu)   #8
Mike K
Mike K's Avatar
Somewhere between step 5 and 8 I would focus the lens.
Canon 6D, 1DmkII, IR modified 5DII with lots of Canon L, TSE and Zeiss ZE lenses
Mike K is offline   Reply With Quote
Old 9th of March 2006 (Thu)   #9
ghocking
I just cup my hand over the eyepiece. You could get a 1D, the have a built in slider.
Geoff Hocking
G9|20D|40D|50D|5D|7D|1DMkIIN
60 Macro|50 1.4|100 Macro|17-40 L|24-105 L|100-400 L|Sigma 18-200 OS
270EX|430EXII|580EX
ghocking is offline   Reply With Quote
Old 9th of March 2006 (Thu)   #10
JohnnyBlood
Angle finder?
Old 9th of March 2006 (Thu)   #11
Jon
Moderator
Cocker Spaniel Mod
Jon's Avatar
If you're setting the exposure manually, you don't need to cover the eyepiece. It's only if you try to meter with the eyepiece open to stray light that there's a risk of a messed up exposure.
Jon
EOS, Powershot and Domke - it doesn't get any better than this!
T90 and stuff | F-1n, New F-1, FTb and more stuff out on loan
Cocker Spaniels
DC Cherry Blossoms
Jon is offline   Reply With Quote
Old 9th of March 2006 (Thu)   #12
ScottE
That is so obvious I had never thought about it. If the mirror is locked up, it blocks light going down to the image sensor. Thanks for pointing that out. OK, I've learned something for today, I can quit thinking now.
Old 10th of March 2006 (Fri)   #13
Jon
Moderator
Cocker Spaniel Mod
Jon's Avatar
No, keep thinking. Then you can point out the "obvious" to someone else.
Jon
Cocker Spaniels
DC Cherry Blossoms
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
20D viewfinder eyepiece elbirth Canon EOS Digital Cameras 4 13th of May 2008 (Tue) 18:13
Do you ever use the eyepiece cover ? Papaw Canon EOS Digital Cameras 20 4th of April 2006 (Tue) 22:56
eyepiece for 20d biggin Canon EOS Digital Cameras 9 15th of December 2005 (Thu) 23:20
Eyepiece Cover UK russellsnr2 Canon EOS Digital Cameras 3 9th of September 2005 (Fri) 19:48
Eyepiece cover billsh Canon EOS Digital Cameras 8 24th of September 2004 (Fri) 19:49
