Would the X1T for sony do hss on the Adorama Rovelight RL 600 like the YongNuo YN622C do with the Rovelight trigger on top off it plus the pc cable. Like the picture below
http://flashhavoc.com …/08/RoveLight_23_d850.jpg
hidroela Senior Member ![]() More info       | Jun 24, 2016 07:57 | #1 Would the X1T for sony do hss on the Adorama Rovelight RL 600 like the YongNuo YN622C do with the Rovelight trigger on top off it plus the pc cable. Like the picture below
Jun1or Member 46 posts Joined Jan 2014 More info       | Nov 10, 2016 09:11 | #3 So if i pick up an X1T and set it up like the picture above i can get HSS with the Rovelight 600b? 6d, t5i, 20mm 2.8 canon, 50mm 1.8 canon, 50mm 1.4 canon, 85mm 1.8 canon, 28-70mm 2.8 sigma , 70-200 2.8 non is canon
Jun1or Member 46 posts Joined Jan 2014 More info       | Nov 10, 2016 10:23 | #5 Thank you. I Just picked up an a7ii and was looking for a cheap option to fire my rovelight. where did you get the pc to hot shoe adapter? Is there any other setting i need to mess with?? 6d, t5i, 20mm 2.8 canon, 50mm 1.8 canon, 50mm 1.4 canon, 85mm 1.8 canon, 28-70mm 2.8 sigma , 70-200 2.8 non is canon
Jun1or Member 46 posts Joined Jan 2014 More info       | Nov 17, 2016 11:06 | #7 Just wanted to say I got my X1T in and it works just like you said. One thing I noticed is that there is a gradient to my images when I'm in HSS with the rovelight. Is this normal? Another question I have is, will I be able to trigger X1C-R with this? 6d, t5i, 20mm 2.8 canon, 50mm 1.8 canon, 50mm 1.4 canon, 85mm 1.8 canon, 28-70mm 2.8 sigma , 70-200 2.8 non is canon
hidroela THREAD STARTER Senior Member ![]() More info Post edited over 1 year ago by hidroela. (8 edits in all)       | about the gradient is something that you will have to live with it. it doesn't bother me i beat.about the X1C-R I does not have one.
y 1600 |
Log in |
Latest registered member is dan.potter86 624 guests, 335 members online Simultaneous users record so far is 6430, that happened on Dec 03, 2017 |
