FORUMS Nikon Cameras, Lenses & Accessories Nikon Lenses
Thread started 29 Aug 2016 (Monday) 04:28
Prev/next
Sigma 150-600mm sports version Or nikon 200-500
rajdey1
Joined Aug 2016
Aug 29, 2016 04:28 |  #1
Hi,
I am lil confused over deciding on two lenses Sigma 150-600mm Sports and Nikon 200-500 mm
I am getting the following offer
1)Nikon 200-500 $1179.28 (US Dollar)
2) Sigma 150-600mm sports version with USB Dock $1940.59 (US Dollar)
3)Sigma 150-600mm sports version with Sigma TC1401 (1.4x USB Dock) $2164.50 (US Dollar )
Which one i should go for I own Nikon D750
explanation with taking photographs and its difference would be very helpful but not madatory
Thanks in advance
smythie
I wasn't even trying
Sydney - Australia
Aug 29, 2016 05:22 |  #2
Have you considered the 150-600 Contemporary? ($1089@ B&H)
I can't help much more than that as haven't used any of these (already have a 120-300/2.8 OS)
peeps27
Joined Mar 2003
Nottingham
Aug 29, 2016 14:49 |  #3
What is your main use for this lens? What is your budget as options 2 & 3 are almost twice the price of 1. How strong are you?
I own the Nikon 200-500 and the Sigma 150-600 Sport and have tried the Sigma 150-600 Contemporary lens.
My main uses for these lenses are for motorsport and air displays. I have the Nikon 200-500 paired with a D500 and have been happy with the results. I also have the much heavier Sigma 150-600 Sport which is currently in Japan, where Sigma are changing the camera mount from Canon to Nikon and I think when it is returned will be my first choice with a monopod, as it is too heavy for me to hand hold for long periods.
The Nikon 200-500 is good value and can be handheld for most of the time. Also constant 5.6 throughout the range and can take a teleconverter.
It does lose out to the Sigma at both near and far, so I believe that the Sigma is more flexible
A UK magazine has just votes the 150-600 sport as the best zoom lens against the Nikon, Sigma Contemprary and Tamron equivalents.
I would steer clear of the Sigma 150-600 Contemporary as it is quite soft at the longer end. I did buy it to use with the D500 but returned it as a lot of images (more than I expected) were borderline "soft".
Nikon 200-500:
Advantages:
Price
Constant aperture f5.6
Less weight
Disadvantages:
Less range than Sigma equivalent
Hood does not fit well and comes away easily
Sigma 150-600 Sport
Advantages:
Built like a tank (but also a disadvantage)
Greater zoom range
Disadvantages:
Heavier, may need a monopod
More expensive
f6.3 at long end
If I could only have one lens then I would probably have the 200-500!
Hope this helps...
Sigma
rajdey1
Joined Aug 2016
Aug 30, 2016 02:13 as a reply to peeps27's post |  #4
Thanks for such a detailed review I have used nikon 200-500 it was heav but manageable I am not getting sigma 150-600MM sports on rent next weekend renting tamron 150-600mm
my main use is birding or wildlife
I am not that happy with Nikon 200-500 rented one..
recently 6 months back I upgraded to Nikon D750 from Sony A200 to be honest my click from Sony A200 with sony 70-300 was much better than Nikon D750 Nikon 200-500 dont know why but I like the sony combo
Since you posses both 200-500 and sigma 150-600 sports can you share pics of both so that I can just have a feel
Regards
peeps27
Joined Mar 2003
Nottingham
Aug 30, 2016 12:26 as a reply to rajdey1's post |  #5
Hi
Not possible at the moment as I am still waiting return the of the Sigma 150-600mm from Japan.
I notice that you have already hired the Nikon 200-500 and are not impressed. Can you not hire the Sigma 150-600 Sport so that you can have a hand-on comparison with the D750?
As I mentioned earlier I have only used these lenses with crop sensor cameras. (Canon 7D II and D500).
Regards
Dan ­ Knowlton
I love myrtle!
Joined Sep 2009
La Mesa, CA (San Diego area)
Jan 13, 2017 15:52 |  #6
Here is a pic from last weekend - D800 with the Sigma lens that was taken on a tripod with a gimble mount. I've found that works better for *me* than a monopod, although those are OK. I had to crop significantly to get under the 10mb limit.
FWIW, I can do OK with the lens handheld for short periods but the pics are softer.
Dan
smythie
Sydney - Australia
Jan 13, 2017 16:02 |  #7
A higher shutter speed can help reduce softness. That image also looks like the lens is front focussing a bit, assuming your focus point was on the boy's face (a lot more of the turf in front of him is in focus than behind).
Dan ­ Knowlton
I love myrtle!
Joined Sep 2009
Jan 16, 2017 12:26 |  #8
That pic is a crop, there was another kid right in front of him and slightly closer to the camera that was the point of focus. If I remember correctly it was 1/1000 at f14.
I'll check out your suggestions - thanks!
Dan
smythie
Sydney - Australia
Jan 16, 2017 13:45 |  #9
No problems. another suggestion if you don't mind: I wouldn't be using f/14 unless I was desperate for a huge depth of field. With the high pixel density of the D800, you'll see that f/14 is a bit softer than f/8 or f/11 when cropping heavily
I'm guessing you were in Shutter Priority set at 1/1000? If so, I would be using Aperture Priority with the aperture set at f/8 (or f/11 if not confident that the lens was suitably sharp by f/8) and AutoISO with the minimum shutter speed in the ISO Priority settings at either 1/1000 or in Auto at one or two clicks faster than middle.
This is from the D750 manual but should be the same for your D800
TheBigDog
Sicklerville, NJ, USA
Jan 16, 2017 19:25 |  #10
Some shots I took with my 150-600 Sport...I switch between the 80-400 and 150-600. The Sig is definitely much heavier compared to the 80-400 but sometimes the reach is needed. The quality is, imo fantastic....these were all hand held:
IMAGE: https://c1.staticflickr.com/6/5664/30832405162_df8f388000_b.jpg
[IMAGE'S LINK: https://flic.kr/p/NYy8​Ss] (external link)DSC_6364 (external link) by Christian Gross (external link), on Flickr
IMAGE: https://c1.staticflickr.com/6/5716/22770354768_2e1731e58b_b.jpg
[IMAGE'S LINK: https://flic.kr/p/AG92​aA] (external link)DSC_6500 (external link) by Christian Gross (external link), on Flickr
And just for comparison, here's the 80-400
IMAGE: https://c1.staticflickr.com/6/5832/30495573870_c801fc41c7_b.jpg
[IMAGE'S LINK: https://flic.kr/p/NsMM​Eo] (external link)DSC_4143 (external link) by Christian Gross (external link), on Flickr
IMAGE: https://c1.staticflickr.com/6/5746/30161242153_70ab5202b6_b.jpg
[IMAGE'S LINK: https://flic.kr/p/MXff​ur] (external link)DSC_4093 (external link) by Christian Gross (external link), on Flickr
Chris
http://www.cegphotogra​phy.com/ (external link)
Flickr (external link) * Facebook (external link)
Nikon D5 * D810 * 24-70 f/2.8 * Sigma 50mm f/1.4 Art * 105mm f/2.8 * 70-200 f/2.8 * 80-400mm * Sigma Sport 150-600mm
AvianScott
AvianScott's Avatar
Joined Mar 2011
Jan 17, 2017 10:59 |  #11
I have owned both and ended up with the 200-500. One thing you'll want to check from the very beginning is making sure you have as sharp copy wide open at maximum focal length. Both lenses have some copy variation and could leave a bad taste in your mouth if you end up with a bad copy. That being said, I ended up with the 200-500 for a few reasons: faster aperture, significantly less vignetting wide open, much lighter (I can hand hold it significantly longer than the 150-600 S), better image stabilization, and better bokeh. Wide open sharpness is excellent with both lenses, and I think the decision should ultimately come down to whether or not you think you need that extra 100mm, or if you hand hold your lenses for a significant amount of time. I, for one, rarely use a tripod or monopod which made the 200-500 choice a no-brainer for me. I've gotten sharp images hand held down to 1/30 sec. at 500mm with the 200-500, something I would never be able to do with the Sigma given its weight and seemingly lesser image stabilization.
Here are a couple of sample images from the 200-500 from this past weekend:
lacogada
Joined May 2015
Dec 01, 2017 15:36 as a reply to AvianScott's post |  #12
Beautiful images AvianScott
ICee
ICee's Avatar
Newcastle upon tyne uk
Dec 14, 2017 15:28 |  #13
I use a 150-600C, this was the second copy I got the first being soft. The second one is sharp wide open.
5,818 views & 5 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.00161 for 4 database queries.
PAGE COMPLETED IN 0.04s
Latest registered member is Steffan DK
989 guests, 493 members online
