Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Nature & Landscapes
Reply
Thread Tools Display Modes
Old 12th of March 2006 (Sun)   #1
krash
krash's Avatar
Default St. Louis Riverfront at night
Just wanted to share a couple more images, shots were taken on different nights.
Bodies: 350D, 300D, TL, Mamiya 645J
Lenses: Carl Zeiss Jena DDR 2.8 135mm,
Asahi Pentax 1.8 50mm,
Pentacon 1.8 50mm,
Canon EF 28-90 F/4-5.6 USM, Mamiya 105-210mm f4.5,
Mamiya 45mm f2.8, Mamiya 80mm f2.8
krash is offline   Reply With Quote
Old 12th of March 2006 (Sun)   #2
SanderH
Default Re: St. Louis Riverfront at night
If you correct the / \ perspective (especially on the right so: | \) on the second one, then it's a keeper! Great nightshot.
www.PiCTOSO.nl (en) / www.PiCTOSO.nl (nl)
SanderH is offline   Reply With Quote
Old 12th of March 2006 (Sun)   #3
krash
krash's Avatar
the perspective is correct, I was on the Eades bridge walkway, it has an outcropping you can stand on that is about 50 feet above the Mississippi river and puts you off at an angle.
It does give the image a bit of a heavy feel on one side, but I really like it as it sits, but I might play with changing it.
Pentacon 1.8 50mm,
Old 12th of March 2006 (Sun)   #4
rudgej
Couch-potato photographer
Interesting shots Krash. Do you use a different lens or a filter in the second one as the lights are all starred?
rudgej is offline   Reply With Quote
Old 12th of March 2006 (Sun)   #5
krash
krash's Avatar
Nope, same lens, just difference in the weather - Foggy and Misty - no filters, just some basic tweaks and cleaning up in Photoshop.
Pentacon 1.8 50mm,
Old 12th of March 2006 (Sun)   #6
rudgej
Interesting. I presume that the first one was the foggy/misty shot then?
Old 12th of March 2006 (Sun)   #7
krash
krash's Avatar
Actually the first one was a misty evening, no low lying fog, just damp and the second was a very foggy night in the low lying areas. The river front was not as foggy as I had hoped, if I could have standed to freeze for another hour or so I would have gotten the fog I wanted.
The first one was also a hand held shot, the second I had my tripod with me and it was shot at a slightly different angle. I was on the Metrolink platform, which put me farther away and about 10 feet lower.
Pentacon 1.8 50mm,
Old 12th of March 2006 (Sun)   #8
Transportithere
Transportithere's Avatar
Very pretty, I was driving a truck years ago. I was able to see the arch, in the daylight, as I drove by. I have never see the arch at night untill now.
Thank you for sharing...
POTN is a wonderful source of information.
POTN has taken me around the world.
Transportithere is offline   Reply With Quote
Old 12th of March 2006 (Sun)   #9
rudgej
The fact that the first shot was hand-held would explain why the star highlights on the lights was missing then. Impressive hand-held capture.
Old 12th of March 2006 (Sun)   #10
krash
krash's Avatar
I thought about that after I mentioned it was hand-held
thanks!
Pentacon 1.8 50mm,
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
St Louis airfrogusmc Nature & Landscapes 6 8th of July 2007 (Sun) 12:07
Chicago's riverfront at night dilorenzo1954 Nature & Landscapes 7 24th of February 2007 (Sat) 06:09
St. Louis at Night and Spring Break C&C Please. LJubel328 Critique Corner 2 1st of June 2006 (Thu) 06:54
St. Louis at Night. Please Comment LJubel328 Critique Corner 6 24th of May 2006 (Wed) 16:25
Saint Louis By Night Dale Allen Nature & Landscapes 6 13th of March 2006 (Mon) 22:27
