Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Canon EOS Digital Cameras
Reply
Thread Tools Display Modes
Old 2nd of August 2003 (Sat)   #1
tikkeltokkel
Default Buying the Sekonic L-508... but first!
I have decided on the L-508 lightmeter. I need to know what "accessory" i need to get to trigger the studio lights "cordless" ( I have 3 bowens monolites but only two slaves ) what accessory do i need (as cheap as possible) to use my lights cordless all the time.
tikkeltokkel is offline   Reply With Quote
Old 2nd of August 2003 (Sat)   #2
scottbergerphoto
scottbergerphoto's Avatar
Default Re: Buying the Sekonic L-508... but first!
www.pocketwizard.com - for Pocket Wizard
www.qtm.com - for Freewire
Pocket Wizard sells a module that will slip inside your Sekonic Meter that will trigger the lights as well for flash metering.
One World, One Voice Against Terror,
Best Regards,
Scott
We're Not Afraid
ScottBergerPhotography
scottbergerphoto is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
surprise when buying a used Sekonic meter from B&H Converge Small Flash and Studio Lighting 13 4th of May 2007 (Fri) 13:18
Opinions on Sekonic L-508? dtrayers General Photography Talk 1 31st of October 2004 (Sun) 08:00
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
