FORUMS Photography Talk by Genre Architecture, Real-Estate & Buildings Talk
Thread started 02 Dec 2016 (Friday) 09:27
Prev/next
Real estate photography edit
krisammad
Joined Oct 2016
Dec 02, 2016 09:27 |  #1
Is there a specific lens that does the hdr type effect or is it all photoshoped work? Seems to be quite popular in today's market. I will try to find a photo of what look im going for.
gjl711
They have pills for that now you know.
gjl711's Avatar
Deep in the heart of Texas
Dec 02, 2016 09:32 |  #2
HDR is a post processing activity. There is no way optically to compress dynamic range into one image. It requires separate images exposed for different areas which are then combined.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
krisammad
Joined Oct 2016
Post has been last edited over 1 year ago by krisammad. 2 edits done in total.
Dec 02, 2016 09:44 |  #3
This is the look im going for. Any specfic light room edits or presets? Or would using a video light work best?
1500
x
1000
TOO LARGE!
EMBED PREVENTED, IMAGE TOO LARGE:
http://caliramedia.com ...2/Peninsula-calira-16.jpg
Click here to see our image rules.
BobDawg
Minnesota, Eh!
Dec 02, 2016 12:41 |  #4
Like gjl711 said, it's a post processing activity, but you need to have the correct pictures taken prior to doing so. Since you're new to the forum, what is your knowledge of HDR, do you understand all the steps it takes?
Canon 60D, Canon 10-22mm, Sigma 30mm 1.4, Tamron 17-50mm, YN-560 IV Flash (2)
krisammad
Joined Oct 2016
Dec 02, 2016 12:49 as a reply to BobDawg's post |  #5
Yes I have fiddled around just wasnt sure if there are any specific presets to be used in lightroom for quicker post processing.
gjl711
gjl711's Avatar
Dec 02, 2016 13:01 |  #6
It's more important to capture the base frames correctly. Expose for the darkest sections, the brightest sections, and maybe a few in between. It helps if you set WB manually unless your shooting raw and shoot tripod mounted to make frame alignment easier. I haven't used LR to do the merge but I know it has the merge hdr function.
::Gear::
BobDawg
Minnesota, Eh!
Dec 02, 2016 13:21 |  #7
You can create presets based on your shooting and what you want the outcome to be, but since each house is different based on color/lighting/etc... there is no one 'easy mode' button. I created one that does all the general stuff, but then I go in and do the final tweaks.
Wilt
Wilt's Avatar
Belmont, CA
Dec 02, 2016 13:27 |  #8
One CAN set a baseline exposure to
  1. capture the room light illumination suitably,
  2. gel the windows with ND gel to drop that exposure to suit, and
  3. reduce high contrast shows left by the room lights with suitably adjusted electronic flash
...none of it requiring photoshop, Architectural interior photographers did it with film, even the more challenging lattitude of color transparency. So you do NOT 'have to' Photoshop.
HDR techniques change the methodology, ridding the need for Step 2 above. In the days of film, the photographer might need to plan his shoot in that room to occur at a certain time of day, shooting elsewhere in the meanwhile.
Today, the best combination might be to employ both traditional methods supplemented by modern digital techniques, to accomplish an even better result than only-analog or only-digital.
You need to give me OK to edit your image and repost! Keep POTN alive and well with member support http://photography-on-the.net/forum/donate.p​hp
aparis99
aparis99's Avatar
KY
Mar 13, 2017 09:49 |  #9
The image you posted is "popular" only b/c it's a quick shoot and batch process in Photomatix. To be honest, though subjective, that's not considered "professional" architectural photography. It gives you exaggerated colors and looks very hazy and fake. If you want to work toward a quality image, take note of architectural magazines and learn to introduce some light if you can. If you're absolutely against adding in some flash, then look into more exposure fusion to give a more realistic look.
I was asked to re-shoot a property in my area due to some bad photos, here's the other "professional", next to mine. You can see how bad the colors were etc...
Mine are still "HDR" and for commercial shoots, that's where I introduce my own extra light, but hopefully a little cleaner/crisp look.
My Site - www.apimagery.com (external link)
Canon 5DmkIII, Canon 7D, Canon 16-35f4L, Canon 70-200 f/2.8 ISL II, Canon 24-105 f/4L, Sigma Art 35 f1.4, Canon 50mm f/1.4, Canon 85 f1.8, Canon 100-400L II, 2x Extender III, 580exII, Think Tank Retro 30 and 40
joooowan
Mar 17, 2017 00:55 |  #10
Everyone does it a little differently. I use 2 ambient frames to get a base exposure and I build on it with flashed frames.
CC welcome.
calypsob
calypsob's Avatar
Joined Jan 2012
Roanoke Virginia
May 27, 2017 14:07 |  #11
The biggest difference I see int eh above exposures is correct white balance vs a very warm white balance. This is arises when you have different light temps.
Wes
Gear: Many gears Yes.
1,821 views & 0 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.00085 for 4 database queries.
PAGE COMPLETED IN 0.05s
Latest registered member is Brofessor
886 guests, 426 members online
