Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Weddings and Other Family Events
Reply
Thread Tools Display Modes
Old 13th of March 2006 (Mon)   #1
morehtml
morehtml's Avatar
Default Wedding with 5D and 20D what lenses?
OK shooting my 1st wedding for a friend (not paid) and will use 2 bodies. Wedding outside. For 90% of the time I was thinking about putting the 70-200 2.8 IS on the 5D and the 17-40 L on the 20D for closer shots. Most shots will be from a medium distance. Out of my lenses in my sig what do you think of that plan? For any extra wide shots I can put the 17-40 on the 5D? Does this sound ok?
"Allen's Visions of Nature Gallery"
www.allensvisions.com
more glass than I need
morehtml is offline   Reply With Quote
Old 13th of March 2006 (Mon)   #2
RobKirkwood
Default Re: Wedding with 5D and 20D what lenses?
I'd probably put the 24-70 on the 20D instead of the 17-40 - but you'll know better what shooting distances you'll be dealing with.
Gearlist
RobKirkwood is offline   Reply With Quote
Old 13th of March 2006 (Mon)   #3
CyberPet
Hiding Under a Rock
CyberPet's Avatar
I'd probably put the 17-40 on the 5D to take advantage of the full frame and get some good wide angle shots and put the 24-70 on the 20D. Only use the 70-200 for special shots, I think you'll notice that you'll use the two former lenses more.
/Petra Hall
Click here to view my geeky gear list
I shoot as much as possible in available light... sometimes, my flash is available – Joe Buissink
CyberPet is offline   Reply With Quote
Old 13th of March 2006 (Mon)   #4
Ronald S. Jr.
Prodigal "Brick" Layer
Ronald S. Jr.'s Avatar
I could do an entire wedding with a 24-70L. In fact, I have- more than once. On a 5D, I think it'd be just perfect. However, in your situation, I think I'd put the 24-70L on the 5D to make a nice wide lens that won't vignette much, if at all, and put the longer lens on the 20D for even more reach.
Mac users swear by their computers. PC users swear at theirs.
Ronald S. Jr. is offline   Reply With Quote
Old 13th of March 2006 (Mon)   #5
tim
Light Bringer
tim's Avatar
I would put the 24-70 on the 5D, and swap the 17-40 and 70-200 onto the 20D as you needed it. Don't forget to use fill flash for outside shots.
tim is offline   Reply With Quote
Old 13th of March 2006 (Mon)   #6
mizuno
User is banned from forums
17-40 on the 20D will effectively give you 28-64 which you would have covered on the 5D in full frame and at higher resolution.
I would just use the 24-70 on the 5D and thw 70-200 on the 20D.
Put the 17-40 on the 5D only when you need the extra width.
mizuno is offline   Reply With Quote
Old 13th of March 2006 (Mon)   #7
morehtml
morehtml's Avatar
Yea I really like the 24-70 on the 5D, for some reason during the ceremony I have in my head I'll be using the 70-200 more. I guess I'll try out a combo or 2 at rehearsal. I want to put my most used lens on the 5D of course
Old 13th of March 2006 (Mon)   #8
tim
Light Bringer
tim's Avatar
Fair point, I wasn't thinking about that! I agree with you then, 24-70 on 5D, wide on the 5D only if it's needed, and 70-200 on the 20D.
Old 13th of March 2006 (Mon)   #9
morehtml
morehtml's Avatar
yea it makes it a little more math with the 2 differnt sensors. If they were both 20d's I'd put the 24-70 on one and the 70-200 on the other. I'll have the other lenses handy anyway though. Thanks guys.
Out of my gear list if distance to subject is not a problem what lens would be best for the bridal shot for a 16x20 photo. Of course I'll use the 5D. I was thinking 50 1.4? Or even the 24-70 since I have a super copy of it.
Old 13th of March 2006 (Mon)   #10
jamiewexler
jamiewexler's Avatar
85 f1.8. Great flattering perspective, and a nice working distance on a 5D.
jamiewexler is offline   Reply With Quote
Old 14th of March 2006 (Tue)   #11
Wedding Shooter
Wedding Shooter's Avatar
I have the same camera combo and use the 24-70 on the 5D and the 70-200 2.8 on the 20D.I also have a 10-22 and an 85 1.8 which I use on the 20D from time to time.
Chris
Wedding Shooter is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Wedding lenses? dwoods2160 Canon EF and EF-S Lenses 20 18th of June 2007 (Mon) 07:36
Wedding lenses ShotByTom Weddings and Other Family Events 6 25th of April 2007 (Wed) 03:26
planned 20d: what lenses for nature/wedding golfluder01 Canon EF and EF-S Lenses 6 15th of March 2006 (Wed) 07:45
First wedding, what two lenses? John Mac Weddings and Other Family Events 13 8th of February 2006 (Wed) 01:57
lenses for 20D...wedding photography?? lisa.ireland Canon EF and EF-S Lenses 10 18th of January 2005 (Tue) 09:23
