FORUMS Photo Sharing & Visual Enjoyment Underwater Photography
Thread started 31 Jan 2017 (Tuesday) 06:47
Reading Lenses for Dive Mask
gug
Joined Oct 2011
Jan 31, 2017 06:47 |  #1
Has anyone used the above? It would be nice to have a pair of 1.75's installed for macro photography. What brands or experience you have had with them? Thanks in advance for your replies.
Dennis
cicopo
Gallery: 161 photos
Jan 31, 2017 22:16 |  #2
I tried them but no luck keeping them stuck to the mask. Even tried CA (superglue) & it still fell off. Gave up.
A skill is developed through constant practice with a passion to improve, not bought.
gug
Joined Oct 2011
Feb 01, 2017 05:08 as a reply to  @ cicopo's post |  #3
Thanks for the feedback. Defogging stuff likely does not help.
MikeThompson
Location: On the road somewhere between the Atlantic and Pacific
Feb 03, 2017 12:15 |  #4
I had lenses put in my mask by an optical shop. They were placed in the lower section of the mask like reading glasses or bifocals and were still in when the mask finally had to be replaced. Seems like the shop was in Florida, but that was sometime around 2000 or 2001 so I can't be sure. Check with your local dive shop and see if they know of any place that can install them.
Mike
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and proclaiming....."WOW, WHAT A RIDE".
gug
Joined Oct 2011
Feb 04, 2017 06:43 as a reply to  @ MikeThompson's post |  #5
Thanks, appreciate the reply.
ThreeHounds
Gallery: 70 photos
Joined Mar 2014
Feb 09, 2017 05:48 |  #6
I had these custom ground lenses installed (external link), also with color correcting filtration. nothing to delaminate or fall off.
5D MkIII | 7D | Bronica ETRS
EF 24-105 f/4 L | EF 85mm f/1.8 USM | EF 17-40 f/4 L | EF 70-300 f/4 L | 105 f/3.5 Zenzanon | Tamron SP90 f/2.8 Di Macro VC USM
SteveInNZ
Feb 09, 2017 13:58 |  #7
I had corrective lenses put in the bottom of my mask. If you find an optometrist that dives, they can have a lens ground and glued in with the curvature to match your eye position.
Now I use a mask with the whole lens having correction (but less than my full prescription) since everything I'm looking at is relatively close anyway. I have the other mask as a backup and would probably use it if I was diving with whales or something in 200ft viz but the number of times I'll get to do that can be counted on one finger.
If you're using a camera with your corrected mask, don't forget to change the diopter adjustment to match your mask.
Steve.
"Treat every photon with respect" - David Malin.
gug
Joined Oct 2011
Feb 10, 2017 05:05 |  #8
SteveInNZ wrote in post #18268902 (external link)
Steve.
Thank You!
WildImages
Gallery: 59 photos
Post edited over 1 year ago by WildImages.
Feb 10, 2017 14:01 |  #9
The information in this thread is a keeper. I sure learned something I didn't think was possible!
1,675 views & 0 likes for this thread
version 2.0 /
Latest registered member is dan.potter86
728 guests, 305 members online
