Thread started 05 Mar 2017 (Sunday) 14:17
ISO Noise on Canon 7D Mark II
kerryN
Post edited over 1 year ago by kerryN.
Mar 05, 2017 14:17 |  #1
I keep seeing videos and write ups that say there is little to no noise on a 7D Mark II at speeds of 2000 ISO, but I find with mine I have a lot of noise even at 1600 ISO. What are others finding that have this camera and why might mine have more noise? I shoot in RAW by the way.
Thanks for your input.
Bassat
"I am still in my underwear."
Joined Oct 2015
Mar 05, 2017 16:16 |  #2
The best way to get appropriate comments is to post a raw file. "... a lot of noise..." is very subjective. How are you viewing the file? Full-screen? 100%? How are you processing it (program, parameters)? How much did you get right in camera (exposure, WB, etc.)?
ISO 2000 should not be a problem for any Canon SLR made in the last 7 or 8 years.
Tom,
Film gear: Elan 7NE / Elan 7 / EOS T2
Yashica FX-D (x2) & FX-3 Super 2000 / DSB 28mm f/2.8 / 50mm ML f/2 / 135mm ML f/2.8 / Sigma Zoom-gamma II 21-35mm f/3.4.2 / Yashica ML 28-85mm f/3.5-4.5 / Tokina 70-210mm ML f/4.
Wilt
Mar 05, 2017 16:52 |  #3
Look at dpreview.com for a direct comparison, in this case vs. the newest 80D
IMAGE: http://i69.photobucket.com/albums/i63/wiltonw/POTN%202013%20Post%20Mar1/7D2_zpsm4lk39b9.jpg
You need to give me OK to edit your image and repost! Keep POTN alive and well with member support http://photography-on-the.net/forum/donate.p​hp
Bassat
Joined Oct 2015
Post edited over 1 year ago by Bassat. (3 edits in all)
Mar 05, 2017 17:39 |  #4
Wilt, I've seen those types of comparisons. IMHO, they are for the most part, pointless. They are shot with a centered meter, under ideal conditions, no NR, and viewed at 100%. Nobody looks at photos in that manner. I can shoot my 80D JPG at 6400 and produce nice looking, properly exposed shots, producing near noise-free 11"x17" prints, if I do my part with the camera. I can also shoot my 6D raw at ISO 400 and get shots so noisy nobody would use them. Your post only shows the relative difference between the 7D2 and 80D under completely unrealistic conditions. It offers no information about what properly exposed and processed real results from either camera look like at a 'normal' viewing size/distance.
The oldest 'modern' bodies I've used are the 7D and T1i. I could get useful files out of either of them at ISO 6400, if I did everything right. Noise at 6400? You betcha! Controllable and useful for some applications? Most certainly. My current 6D and 80D are significantly better, and easier to work with at those levels. The 7D2 should have no problems with ISO 1600, or 2000.
Tom,
gjl711
They have pills for that now you know.
Mar 05, 2017 17:49 |  #5
Yes, may be pointless compared to a processed pic, but they do set the bar as to what the camera is capable of. Once processed an image is worthless in assessing noise.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
Bassat
Joined Oct 2015
Mar 05, 2017 18:24 as a reply to  @ gjl711's post |  #6
Where I come from the final image IS the point of releasing the shutter.
Tom,
Wilt
Post edited over 1 year ago by Wilt. (4 edits in all)
Mar 05, 2017 21:59 |  #7
Bassat wrote in post #18292780 (external link)
I look at it from a different point of view:
Yes, it may fail to show what happens at ISO 6400 or ISO 12800, but that is like saying that 'a GRAPH which compares the two cameras is no good because both are not graphed at ISO 12800 (although they are both graphed at ISO 6400)!"
The two comparisons show ISO 3200 exposed properly, and ISO 1600 pushed 1EV...both ARE valid comparisons, although the comparison discloses no information about a variety of other tests like higher ISO, nor including pushing both cameras by 3EV, like some tests do show.
We do graph cars' acceleration from 30-50mph, even though both cars might be able to accelerate from 60-100mph as well. It is NOT that graphing only 30-50 is 'not valid'...merely not a 'complete comparison' of acceleration of both cars. The fact that some can accelerate to 135 or 155mph does not render the graph from 0-100mph as 'not valid'.
So the comparison may not matter 'to you' but it certain does matter to some! In the case of the OP, the complaint was about noise at ISO 1600...so why is posting examples at ISO 1600 and ISO 3200 not of interest to the OP?!
kerryN
Mar 06, 2017 05:18 |  #8
Thanks everyone for your responses. I have tried to upload a raw file but it won't let me do it so I have uploaded a jpeg that has had no alteration whatsoever, other than conversion to a jpeg obviously! The image settings are as follows:
ISO 1600
F8
1/1600 shutter
0 EV comp
TeamSpeed
01010100 01010011
Gallery: 72 photos
Joined May 2002
Post edited over 1 year ago by TeamSpeed.
Mar 06, 2017 05:51 |  #9
What raw converter? I suggest trying DPP if you used another tool. You could try to use Dropbox or other online files share to provide a raw.
Past Equipment | My Gallery (external link)
kerryN
Mar 06, 2017 05:56 as a reply to  @ TeamSpeed's post |  #10
I used Canon's own raw converter: DPP 4. I shall have a look at dropbox - thanks for the suggestion.
kerryN
Mar 06, 2017 06:40 |  #11
The following link should lead to the raw image. The preview option won't work so I can't check until it is posted. Just checked and it leads to a download link.
IMG_4926.CR2 (external link)
Dan ­ Marchant
Gallery: 18 photos
Joined Oct 2011
Mar 06, 2017 08:28 |  #12
1. The above JPG looks fine to me (more than fine actually). There is some "texture" to the background but that enhances the image in my eyes.
2. What if any noise reduction have to applied? Obviously NR isn't a magic bullet. It can't make an image perfect but a sensible application of NR will clean up most images - at least to some degree.
Dan Marchant
Tom ­ Reichner
"I am a little creepy"
Gallery: 134 photos
Mar 06, 2017 10:30 |  #13
kerryN wrote in post #18293164 (external link)
0 EV comp
That there is a problem that will lead to unnecessary noise in most images. Shooting as far as you can to the right will help to keep the noise down.
In this particular instance, it looks as though the central part of the bird's white cheek patch is going to be your limiting factor - it appears as though you could have only given this about one third stop of additional exposure before you would lose the feather detail in that area. .But even that one third of a stop would help to reduce the fine graininess that you have in your background.
Now that I look more closely, it looks like the bird's crown would also be a limiting factor, inasmuch as additional exposure compensation is concerned.
When shooting bird set-ups such as this, I try to select as light of a background as possible, while still keeping the desired aesthetic. .A lighter background will generally show less noise grain. .When the background is completely out-of-focus, mid-tones such as what you have here will generally show the most noise grain, particularly when they are slightly toward the dark end of "mid-tones".
I am curious about something:
It looks as though you had plenty of light for this shot. .Why, then, use such an unnecessarily high ISO in this situation? .You don't need anywhere near that much shutter speed for perched birds. .I don't see any valid reason as to why you couldn't have shot this at ISO 800 and 1/640th of a second, and still at f8 . - . or even ISO 800 and 1/500th of a second. Both of those settings would have given you a markedly cleaner image and not sacrificed anything, as 1/500th or 1/640th are still way faster than you need for a static image.
CyberDyneSystems
Admin (type T-2000)
Gallery: 79 photos
Joined Apr 2003
Mar 06, 2017 10:52 |  #14
ISO 1600
F8
1/1600 shutter
0 EV comp
thumbnail
Hosted photo: posted by kerryN in
./showthread.php?p=182​93164&i=i46170448
forum: General Photography Talk
What noise?
CDS' HOT LINKS
Bassat
Joined Oct 2015
Mar 06, 2017 11:08 |  #15
CyberDyneSystems wrote in post #18293399 (external link)
What noise?
+1. I will look at raw later. Agree with ISO/ SHUTTER point.
Tom,
5,846 views & 19 likes for this thread
version 2.0 /
Latest registered member is Nidge
787 guests, 448 members online
