Thread started 08 Mar 2017 (Wednesday) 14:30
Name this Technique - Multiple Exposures with Narrow Lens - Shallow DoF
icor1031
Gallery: 14 photos
Joined Jan 2015
Mar 08, 2017 14:30 |  #1
Use a telephoto lens and then take, for example, a 3x3 section and combine the images so that you get as much context as you would have with a wide lens - but, you get the DoF of a telephoto lens.
What's this technique called?
(2) Canon 6D || Zeiss Sonnar 135mm f/2 || Zeiss Otus 85mm f/1.4 || Sigma 85mm f/1.4 || Helios 44-2 58mm f/2 || Sigma 50mm f/1.4 Art || Canon 24mm f/2.8 || Rokinon 14mm f/2.8 || (2) Eg-S Focusing Screen
Ideal Portraits (external link)
3Rotor
Mar 08, 2017 14:34 |  #2
The Brenizer Effect?
JESSEMAK.COM (external link)
icor1031
Gallery: 14 photos
Joined Jan 2015
Mar 08, 2017 14:36 as a reply to  @ 3Rotor's post |  #3
Thanks!
digital ­ paradise
Gallery: 10 photos
Mar 09, 2017 11:01 |  #4
You can recreate it using PS.
PHOTOBUCKET EMBEDDING IS DISABLED BY THIS MEMBER.
Photobucket sends ads instead of embedding photos from their free galleries.
Click the link (if available) below to see the image in a gallery page.
http://i33.photobucket​.com …_zpsbf2ed029.jp​g~original (external link)
http://i33.photobucket​.com …_zps66329caf.jp​g~original (external link)
http://i33.photobucket​.com …_zps1494493e.jp​g~original (external link)
Image Editing OK
Tom ­ Reichner
"I am a little creepy"
Gallery: 134 photos
Post edited over 1 year ago by Tom Reichner. (3 edits in all)
Mar 09, 2017 11:27 |  #5
digital paradise wrote in post #18296333 (external link)
In this example, it doesn't seem to work at all. Why? Because there is no integrity to the plane of focus. The red bus is more or less in focus, then things behind it are out of focus, then things behind them are back in focus again. It just looks like a random mish-mash of what is in focus and what is out of focus. The focus seems to have no correlation to the distance between the camera and the various elements in the scene.
This is not at all what one would get if they use the method described in the OP.
digital ­ paradise
Gallery: 10 photos
Mar 09, 2017 11:32 |  #6
Yeah it is just a trick and not the real thing. I rarely us it and I'm too lazy to do it properly :lol:
Image Editing OK
kjonnnn
Post edited over 1 year ago by kjonnnn.
Mar 16, 2017 11:21 |  #7
I believe the method the OP is thinking of is the Brenizer Method. There are already several threads regarding it on this site.
http://photography-on-the.net …/showthread.php​?t=1138306
The samples given in this thread are more like the Tilt-Shift Method. Photoshop does have a "blur" for this. It is often used to make every day situations look like shots of miniatures. It looks more effective if you are taking the shot from an "above" position so that the dof radiants out. Using this method taking photo straight on doesnt make "dof" sense.
The two methods yield different results.
Picture ­ North ­ Carolina
Gaaaaa! DOH!! Oops!
Post edited over 1 year ago by Picture North Carolina.
Mar 17, 2017 07:20 |  #8
Tom Reichner wrote in post #18296371 (external link)
kjonnnn wrote in post #18302500 (external link)
I believe the method the OP is thinking of is the Brenizer Method...The samples given in this thread are more like the Tilt-Shift Method.
Agree. To the OP, the method to research is the Brenizer method. The fake /photoshopped tilt-shift examples given are wrong and should be disregarded. As pointed out, there are threads here on POTN about the method. There is also a ton of outside resources (external link). Good luck. It takes a little more time to shoot and a little more time to process, but the results can be stellar.
And many videos on Youtube (external link).
Website (external link) |
2,028 views & 4 likes for this thread
version 2.0 /
Latest registered member is CanucksFan
603 guests, 347 members online
