Thread started 14 Mar 2017 (Tuesday) 21:29
pocket wizard or Paul C buff Cyber commander?
Prime ­ Visual ­ Productions
Joined Aug 2016
Mar 14, 2017 21:29 |  #1
which should I get?
Joined Aug 2016
Post edited over 1 year ago by Prime Visual Productions.
Mar 14, 2017 21:30 |  #2
I currently only own an Einstein flash, but of course will purchase more lighting in the future(not sure what it may be). So, should I go with the paul bluff cyber commander, or get the pocketwizard as a more future proof option?
dmward
Gallery: 28 photos
Mar 14, 2017 21:39 |  #3
Prime Visual Productions wrote in post #18301263 (external link)
If you want a system, then go with the Buff products and take advantage of the features and benefits of the Cyber Commander as a controller.
I had 6 Einsteins and a cyber commander. Its an amazing tool. Very well thought out and makes controlling a lighting setup a dream. There's a learning curve but its worth the investment.
Scatterbrained
Gallery: 211 photos
Best ofs: 11
Mar 14, 2017 22:14 |  #4
The cybercommander works great, and you can use it and a battery operated cybersync to trigger non Buff lights, you just won't be able to adjust the lights remotely.
500px (external link)
1x (external link)
instagram (external link)
bobbyz
Mar 14, 2017 22:16 |  #5
Doesn't matter one way or the other. PW lost the game now. I still like them but the future is HSS capable triggers and they are mfg dependent be it profoto, elinchrom, godox.
5dmk3, 35L, 85L II, 300mm f2.8 IS I, 400mm f5.6
Fuji XT-1, 14mm f2.8, 23mm f1.4, 35mm f1.4, 56mm f1.2, 90mm f2, 50-140mm f2.8
Joined Aug 2016
Mar 15, 2017 00:22 |  #6
seems to be pretty clear. cyber commander it is. thanks!
Joined Aug 2016
Mar 15, 2017 21:42 |  #7
What do I need with the cyber commander to power the Einstein 640 light?
they have cybersync plus recievers / cybersync receivers / cybersync transceiver / trigger transmitter 2
which of these do I need to attatch to the einsten 640 to get it all to work?
RDKirk
Adorama says I'm "packed."
Joined May 2004
Post edited over 1 year ago by RDKirk.
Mar 15, 2017 22:19 |  #8
I also vote for the CyberCommander. As has been mentioned, PW is approaching obselsence as a general trigger because it doesn't do HSS.
The Buff system retains relevance (despite not having HSS) because of its incredible remote control at far less a price than others with as much capability. But without the CyberCommander system, it doesn't give you all those benefits (and if you don't get all the benefits, you might as well get something else).
Prime Visual Productions wrote in post #18302155 (external link)
You need the CyberCommander. For each Einstein light you need a CyberSync Transceiver.
It's a good idea to get a CyberSync Trigger for your camera and keep the CyberCommander in you pocket, around your neck, or on your belt to control the lights.
Joined Aug 2016
Mar 15, 2017 23:52 as a reply to  @ RDKirk's post |  #9
so the cyber commander can't go on the cameras hot shoe and trigger the lights? i must buy both the cyber comander and the cybersync trigger as well as the cybersync transceiver for each light?
Scatterbrained
Gallery: 211 photos
Best ofs: 11
Mar 16, 2017 00:53 |  #10
Prime Visual Productions wrote in post #18302199 (external link)
It can, but if you're making a lot of adjustments it's easier to just use it as a lightmeter/remote control. That's how I use mine anyway.
1x (external link)
dmward
Gallery: 28 photos
Mar 16, 2017 07:52 |  #11
It can but its not the best way to use it.
Here's my workflow for a 5 light setup.
First set two lights into group for background, using light meter, adjust them individually until background is uniformly lit. The as group, adjust output from subject position to ensure white background without bleed into subject.
Next set main light for desired exposure in its own group.
Next set fill light for desired exposure in its own group.
Next set kicker/hair light for desired exposure in its own group.
Combine main/fill/kicker into a group so they can be adjusted up and down as desired.
Finally combine all the lights into a group so they can be adjusted up and down as desired.
Start shooting.
It may sound complicated but once you're familiar with the system it does take long and once set, the shoot, with ability to adjust power by group is a real time and model saver.
1,723 views & 6 likes for this thread
version 2.0 /
Latest registered member is Gibby391
684 guests, 392 members online
