Thread started 16 Mar 2017 (Thursday) 12:32
Complete lighting gear setup help. One for video. One for photography.
Mr. ­ Sparkles
1 post
Joined Mar 2017
Mar 16, 2017 12:32 |  #1
Hi All,
My main expertise is in design, and I have a bit of experience being scrappy in photo and video, but certainly I could use some assistance. Most of my clients are based in the natural foods industry and at this point I am trying to piece together a lighting gear collection. Working in both photo and video, I need to acquire different tools for the different use cases. But there are so many options out there today, I can't seem to get a grasp on what brands & models will work best for my needs.
Here are the various situations which I need to take into account:
VIDEO | INDOOR: Product/Food
VIDEO | INDOOR: Medium Wide Shots/Scenes with people
PHOTO | INDOOR: Product/Food
PHOTO | INDOOR: Medium Wide Shots/Scenes with people
PHOTO | OUTDOOR: Product/Food
PHOTO | OUTDOOR: Medium Wide Shots/Scenes with people
Without unlimited funds, what's the best I can do here?
Please do lend some help if you can.
Thank you!
RDKirk
Adorama says I'm "packed."
Joined May 2004
Mar 16, 2017 13:25 |  #2
Mr. Sparkles wrote in post #18302543 (external link)
Hi All,
Thank you!
I've recently moved into video from long years doing portraits, including owning a studio.
A couple of years ago, my solution was to purchase some high-power LED video lights in the cylindrical form-format of studio flash so that I could continue to use my studio flash modifiers (umbrellas, soft boxes) in the same fashion as I do with still photography. I still use my studio electronic flash because even "high power" LEDs don't come anywhere close to the momentary power of electronic flash. Also, while today's LED lights are spectrally balanced well enough to pass in video, the results are clearly inferior in still work. So having two set of lights using the same modifiers has worked for me.
However, the Paul C Buff company has developed inexpensive studio flash with high-color quality, high-power LED modeling lights bright enough to serve as video lights--one light serving both purposes well seems ideal. I haven't actually listened to one of them--the quietness of the internal fan would be an issue. But in practical terms, a bit of fan noise is acceptable if it tests as unnoticeable to an audience during dialog.
Wilt
Post edited over 1 year ago by Wilt.
Mar 16, 2017 13:28 |  #3
RDKirk wrote in post #18302586 (external link)
Any idea of what representative exposure (ISO, shutter, aperture) is claimed for the LED output of this Buff product?
[edit]just learned that Buff claims 400W equivalent, 75W LED...pretty bright, especially in view of the previously rather anemic 100W-150W mdelling lights they used to support
You need to give me OK to edit your image and repost! Keep POTN alive and well with member support http://photography-on-the.net/forum/donate.p​hp
RDKirk
Joined May 2004
Mar 16, 2017 15:00 |  #4
Wilt wrote in post #18302588 (external link)
The high-intensity LEDs I'm currently using run 100 real watts and supposedly have a 500 watt lumen equivalence. The particular model I used is no longer available under the same name on Amazon, but I left a lengthy review here (external link) that should give others some buypoints to evaluate other models.
With that 500watt equivalent light:
The light is bright enough for video use from both the reflector and my big umbrella, an 84-inch Paul C. Buff PLM super silver (which required a bit of DIY tinkering to convert to Bowens S-mount). With just the stock reflector, my Sekonic meter measured f8.2 at six feet, ISO 200, 1/45.
With regard to color accuracy, all LEDs used for photography are single-color blue LEDs that are coated with phosphors to create red and green light, blending to the eye to look white. The quality of the phosphor mix appears to be the difference between lights. A whole lot of the common photo LEDs from China appear to be using a phosphor mix that is deficient in red.
This can't be countered accurately with a red (pink) filter because, as you know, filters don't add color, they subtract the opposite color. But if there isn't much red from the source, you can't add it. With my Canon cameras, I can crank up the red in the White Balance Shift menu, which helps. It's okay for video, but in stills skin tones are noticeably muted.
Left ­ Handed ­ Brisket
That's my line!
Joined Jun 2011
Mar 18, 2017 12:21 |  #5
Do those 400/500 watt LEDs generate a lot of heat?
RDKirk
Joined May 2004
Mar 18, 2017 14:17 |  #6
Left Handed Brisket wrote in post #18304263 (external link)
They actually consume only about 100 real watts. My 100 watt (500 watt equivalent) LED light measures 120F right on the glass cover of the element after being on for half an hour--warm water.
That's my line!
Joined Jun 2011
Mar 18, 2017 14:35 |  #7
RDKirk wrote in post #18304365 (external link)
Thanks.
I'm shooting with CFLs at my "real" job, and my guess is that they get warmer than that. I think each bulb is probably 100-120 watt equivelant ... Six bulbs per large softbox. I pull back a corner or two to let air flow through.
Fwiw, for the OP, the boxes we use are PBL from Amazon. No idea if they are still made, they were purchased years ago, long before I started working there. They have held up though. Might make a decent continuous light for video, we use them for production oriented product photography.
1,162 views & 0 likes for this thread
version 2.0 /
Latest registered member is Lausti
634 guests, 368 members online
