Thread started 29 Mar 2017 (Wednesday) 10:18
Lens switches keep turning off.
Martin ­ Dixon
Gallery: 59 photos
Joined Sep 2009
Mar 29, 2017 10:18 |  #1
My IS and AF switches keep turning off.
I use a cheap shoulder sling/rapid type of camera strap, which is a godsend especially using 70-200 lens - no more sore neck. But there is one down side, the switches on the lens always seem to be knocked to the off position, and this is very annoying!
I am thinking of using gaffer tape to stop this, but I was hoping someone has a better way to prevent switchs being knocked and yet be able to switch if I really do want to.
Thanks!
flickr (external link) Editing OK (external link)
Wilt
Post edited over 1 year ago by Wilt.
Mar 29, 2017 10:27 |  #2
I just looked at my 70-200 f/4L IS and I find that the switches are so flush with the barrel of the lens that I have to be very deliberate in moving the the switches to any different position...I have to aim my fingernail into the switches to get any bite on them.
I am puzzled why you have a problem in that regard.
You need to give me OK to edit your image and repost! Keep POTN alive and well with member support http://photography-on-the.net/forum/donate.p​hp
Martin ­ Dixon
Gallery: 59 photos
Joined Sep 2009
Mar 29, 2017 10:38 as a reply to  @ Wilt's post |  #3
I have a canon 70-200 f/2.8 L IS USM where the switches look prety similar to yours, but the AF and IS switches have a (~2mm) raised section where the indicator line is, thus making the swich very vulnerable to being accidentally knocked.
I also tried rotating the tripod mount to ffer some protection, but hasn't had a noticable effect.
Tom ­ Reichner
"I am a little creepy"
Gallery: 134 photos
Mar 29, 2017 10:56 |  #4
I would put a neoprene sleeve over the barrel of the lens. Doesn't have to be custom made, or even fit very properly. Just any piece of neoprene tubing that will fit over the barrel but not so loosely that it falls off.
Lots of hunting supplies and accessories are made of neoprene (usually camouflage) so you just have to look in the sporting goods department at your local Walmart and you should be able to find something that can be used as a lens sleeve. Three of my lenses have neoprene sleeves on their barrels now, and I can't even remember what the neoprene was taken from.
If for any reason you can't find neoprene, then a real heavy winter sock should keep the strap from being able to catch on the switches. Just cut the sock to the length you need and slide over the barrel of the lens - I have done this plenty of times as a way of adding some extra protection to my 100-400 zoom, which is about the same size as your 70-200mm (assuming you use an f2.8 model).
Wilt
Post edited over 1 year ago by Wilt. (4 edits in all)
Mar 29, 2017 10:57 |  #5
I see the problem in a photo on the web (Ken Rockwell), one can readily see the raised wide ridge clearly visible in profile in this photo, that protrude above the level of the surrounding collar...
IMAGE: http://i69.photobucket.com/albums/i63/wiltonw/POTN%202013%20Post%20Mar1/70200%20f28_zpstglq7ejx.jpg
On my f/4L IS it is absolutely flat! The engraved line on the switch actually is in a shallow valley between slightly raised parallel narrow lines which form the high point of the switch and which provide zero 'grab' when brushed against anything
As an alternative to neoprene, I would go to a fabric store and get some elastic strip (for the waistband of clothing), cut to right length and then stitch the ends together so the elastic is somewhat stretched when it is on the barrel...or just gaffer tape!
Martin ­ Dixon
Gallery: 59 photos
Joined Sep 2009
Mar 29, 2017 11:00 as a reply to  @ Tom Reichner's post |  #6
Not a bad idea - just to protect the switches I would need a cut-out for the focus window I have an old wetsuit somewhere!
Nathan
So boring
Gallery: 16 photos
Mar 29, 2017 11:03 |  #7
Weird. When I had that lens, I never had the problem. Are your switches loose, by any chance?
Taking photos with a fancy camera does not make me a photographer.
www.nathantpham.com (external link) | Boston POTN Flickr (external link) |
5D3 x2 | 16-35L II | 35 L | 50L | 85L II | 135L | 580 EX II x2
Martin ­ Dixon
Gallery: 59 photos
Joined Sep 2009
Mar 29, 2017 11:15 as a reply to  @ Wilt's post |  #8
I saw. Perhaps an improved design :)
Martin ­ Dixon
Gallery: 59 photos
Joined Sep 2009
Mar 29, 2017 11:19 as a reply to  @ Nathan's post |  #9
Not loose. I didn't have problem before changing camera strap, I guess it just gently knocks onto my hip. As I said I much prefer this strap.
gjl711
They have pills for that now you know.
Mar 29, 2017 11:29 |  #10
Gaffers tape sounds like a very viable solution though I am surprised that they switch so easily. I've tried several of my lenses and they are not easy to move at all.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
Tom ­ Reichner
Gallery: 134 photos
Mar 29, 2017 13:01 |  #11
Martin Dixon wrote in post #18314073 (external link)
On a couple of my lenses the neoprene sleeve fits rather loosely, so I can still focus without having a window cut out - I just turn the neoprene along with the focus ring.
The neoprene doesn't need to fit snug - just not so loose that it falls off.
Martin ­ Dixon
Gallery: 59 photos
Joined Sep 2009
Post edited over 1 year ago by Martin Dixon.
Mar 31, 2017 05:37 |  #12
After attempting a too complicated elastic and neoprene solution I used gaffer tape to attach a strip of neoprene. This allows me to change switches if needed. Fair trudge round with it yesterday and no unexpected switching. Seems still firmly attached. Success!
A transparent alternative to neoprene would be neat.
Echo63
Mar 31, 2017 06:49 |  #13
I don't think i ever touched the switches on my 70-200
set them once, put a big stripe of 1" gaffa tape over the top and left it
never had any issues.
did the same to my 24-70 and 16-35 too.
My Best Imageswww.echo63.deviantart.​com (external link)
Gear listhttp://photography-on-the.net …p?p=2463426&pos​tcount=385
tonylong
...winded
Gallery: 60 photos
Apr 01, 2017 00:07 |  #14
Hmm ... I've had switches go "off" on different occasions. To me, it's just "normal" when shooting to keep my eye on things via the viewfinder, and, sure, the AF/MF switch is there, and I can tell at a glance if it's been nudged, and then I can make the switch if I want to MF a shot! As to the IS switch, well, I do value Image stabilization! I have on occasion noticed that it's not operating, especially when using a tripod, but it's something I notice, and again at a glance I can see if the switch got nudged, whatever, it's just something that I learned early on, you can glance and "correct" things in a heartbeat!
Tony
welshwizard1971
Joined Aug 2012
Apr 01, 2017 01:38 |  #15
Velcro straps, instant on and off, always the right fit, adjustable for any lens....
https://www.amazon.com …11&keywords=vel​cro+straps (external link)
5DIII, 40D, 16-35L 35 ART 50 ART 100L macro, 24-70 L Mk2, 135L 200L 70-200L f4 IS
Hype chimping - The act of looking at your screen after every shot, then wildly behaving like it's the best picture in the world, to try and impress other photographers around you.
7,766 views & 7 likes for this thread
version 2.0 /
Latest registered member is deckermargie
585 guests, 287 members online
