FORUMS Photography Talk by Genre Bird Talk
Thread started 09 Apr 2017 (Sunday) 22:01
Prev/next
Ducks eyes focusing problem
Greg_8
Greg_8's Avatar
Michigan, Northern Lower & Eastern Upper
Apr 09, 2017 22:01 |  #1
Hi.
Does anyone else have a problem getting Ducks' eyes in focus? I get what is like a reflection. I do not sense it as much on other birds or in other photography.
I'm wondering what I am seeing is evidence that I need to micro focus adjust my 7DII or if there is something unique with Duck eyes giving more reflection?
Keep 'em flying,
Greg B
Greg_8
Greg_8's Avatar
Post has been edited 10 months ago by Greg_8.
Apr 09, 2017 22:02 |  #2
Two more
Keep 'em flying,
Greg B
Tom ­ Reichner
"I am a little creepy"
Tom Reichner's Avatar
Omak, in north-central Washington state, USA
Apr 10, 2017 10:49 |  #3
Greg_8 wrote in post #18323862 (external link)
Hi, Greg!
I do not understand what you are saying. I think that perhaps you think you are seeing a problem that does not exist?
It is really hard to see what you are talking about in the photos you posted because the ducks are so small in the frame. If you had some close-ups, then it would be possible to see what part of the duck is in focus and what part isn't. When you mention getting something that looks like a reflection, it would be especially helpful if you could post a close-up of this so that we could see what you mean.
I have not had any special difficulties getting duck's eyes in sharp focus......at least no more so than getting other bird's eyes in focus.
teekay
teekay's Avatar
Joined Apr 2001
British Columbia, Canada
Post has been last edited 8 months ago by teekay. 2 edits done in total.
Apr 10, 2017 18:23 |  #4
..Does anyone else have a problem getting Ducks' eyes in focus?...
Not really, unless you mean the pupil itself, which is hard to focus on because it is of course both jet black and reflective. This is a crop from an old shot so a bit grainy, but you can see what I mean.
IMAGE: http://community.netidea.com/teekay/temp/NoImage.jpg
Larry ­ Johnson
Larry Johnson's Avatar
Joined Sep 2011
Virginia
Post has been edited 10 months ago by Larry Johnson.
Apr 12, 2017 18:30 |  #5
You can easily test your camera/lens setup to determine if you need to micro adjust, but if you are only seeing focusing issues with one group of birds, it's not likely a camera issue. There's nothing particular about waterfowl eyes that require special focusing techniques. Don't let the camera select your focus point because it may be focusing on the water movement (not that I see that in your photos). Use one single AF point, no expansion. Put it right on the eye or the head.
Did you use a teleconverter on the last two. Could be the issue.
Ain't Nature Grand!
Shooting 7D2 with Canon 400mm, f/5.6.
60D, canon 18-135 EFS, and 1.4 extender in the bag.
Bsmooth
Bsmooth's Avatar
New England
Apr 14, 2017 11:42 |  #6
I've had this same exact problem myself, and I'm nor sure why. Possibly reflections from the water. I use a Canon 1DMKIV and the later version of the 100-400V2. I've tried it in AIServo and also in one shot with the same results. It seems to be very much hit or miss whether the eye is in focus or not. I can basically get within a few feet too of some of the tamer ducks.
Its a very weird thing, which I haven't figured out, but when I saw the title I knew I had to look, because I know now I'm not the only one.
Bruce
ejenner
ejenner's Avatar
Joined Nov 2011
Denver, CO
May 04, 2017 00:12 |  #7
I've had this problem with ducks with extreme change in brightness on their head, like your first shot, but not particularly otherwise.
Now I do occasionally find I just can't get anything sharp, but that is usually air currents.
Edward Jenner
5DIII, 7DII, M6, GX1 II,M11-22, Sig15mm FE,16-35 F4,TS-E 17,Sig 18-250 OS Macro,M18-150,24-105,T45 1.8VC,70-200 f4 IS,70-200 2.8 vII,Sig 85 1.4,100L,135L,400DOII.
http://www.flickr.com/​photos/48305795@N03/ (external link)
https://www.facebook.c​om/edward.jenner.372/p​hotos (external link)
Greg_8
Greg_8's Avatar
May 06, 2017 16:21 |  #8
Thanks to all for sharing your experiences. I have decided to get a micro focus adjustment tool, and hopefully if I don't mess the camera/lens up, I might get the tad more sharp I am looking for.
Thanks again.
Keep 'em flying,
Greg B
Bsmooth
Bsmooth's Avatar
New England
May 12, 2017 08:52 |  #9
I'm not sure exactly why, but I've heard other photographers say the same thing. If everything else shoots ok and its only ducks or birds in water, I'll bet it has something to do with reflections. You could also check and see where the AF point was when you took the shot. I know theres a plugin for Lightroom thats shows where the AF point was, not sure about other ways but it does help quite a bit.
Bruce
D ­ Jacobs
Jun 18, 2017 04:55 |  #10
That's interesting and I would think that I might have trouble too trying to focus on just the eye.
5D Mark II / 7D / 70-200mm f/2.8L IS / 24-105mm f/4L / 17-40mm f/4L / 600 EX-RT / Need to stop before more things are listed here...
pinball
Joined Jun 2004
Jun 23, 2017 20:09 |  #11
I think what happens it depends on how many focus points are being used, if you using more than 1 then it will adjust too which focus points are being used
Bill
Tom ­ Reichner
Jun 25, 2017 11:37 |  #12
Greg_8 wrote in post #18347945 (external link)
Hey, Greg
Did you get the micro adjustment tool yet? . If so, how did it work out for you?
Also, do you have any close-ups of ducks, so that we can see the eye focus problem you were talking about? . I asked about this in post #3, back when you first started the thread, but didn't hear anything back from you about it.
Lester ­ Wareham
Moderator
Lester Wareham's Avatar
Hampshire, UK
Jul 13, 2017 11:57 |  #13
Tom Reichner wrote in post #18324235 (external link)
Hi, Greg!
I am with Tom here, I have often notice apparant eye softness in duck, the tufteds are typical. Yet the feathers around are sharp. I think they have diffused edges to the pupils that can make they eyes look soft and trigger the old wildlife photog paranoia.
My Photography Home Page (external link) RSS Feed (external link)
Macrophotography by LordV
Bsmooth
Bsmooth's Avatar
New England
Jul 14, 2017 11:33 |  #14
You know what I've also noticed this on as well....Cormorants.The thing is it usually happens in the air as well as on the water.
Bruce
Greg_8
Greg_8's Avatar
Jul 15, 2017 05:07 |  #15
Hi all. No, I never did the Micro adjust. I've been enjoying dragonfly action lately and am getting sharp pictures. I am agreeing with Tom and Lester; I believe duck eyes are naturally diffused and the camera captures it accurately.
Thanks again for all the comments.
Keep 'em flying,
Greg B
8,732 views & 6 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.001 for 4 database queries.
PAGE COMPLETED IN 0.07s
Latest registered member is grstrong
1040 guests, 463 members online
