FORUMS Photography Talk by Genre Sports Talk
Thread started 23 Apr 2017 (Sunday) 22:24
Prev/next
speed vs exposure
kckmarc
Joined Nov 2016
Apr 23, 2017 22:24 |  #1
the common trade off for anyone shooting sports on a budget. I've had the 7d2 for the speed only to have issues with iso tolerance and cropped sensor and considering the upgrade to 5d3 or 4 slightly slower but better low light ability. anyone made this switch? the decrease from 10fps to 6fps feel significant?
bildeb0rg
bildeb0rg's Avatar
uk
Apr 24, 2017 07:35 |  #2
Best way to feel it is set your fps to 6 on your 7d and see if you can take the reduction in speed. I imagine the noise reduction will significant too.
TeamSpeed
01010100 01010011
TeamSpeed's Avatar
Gallery: 63 photos
Joined May 2002
Northern Indiana
Post has been last edited 10 months ago by TeamSpeed. 2 edits done in total.
Apr 24, 2017 07:48 |  #3
kckmarc wrote in post #18336448 (external link)
I have both the 7D2 and 5D4. They make for a very complementary set. I shoot the 7D2 up to 12800 for sports and a bit higher on the 5D4, sometimes up to 25600. I have shot an entire season of basketball with the 7D2 and the only limitation I had was that with the ISO level where it was, I had to sacrifice a bit of shutter and thus some shots had motion blur in them. The 5D4 allows me that extra bit of shutter now.
This is ISO 10K and 12.8K, it is very usable for my needs. I also use some homegrown NR actions, using Noiseware as a base action. Perhaps share a few of your examples and settings you are using?
IMAGE: https://photos.smugmug.com/Sports-Events/Mad-Ants-20152016/March-9-2016/i-chxzmWW/0/X2/216A5250-X2.jpg
IMAGE: https://photos.smugmug.com/Sports-Events/Mad-Ants-20152016/Feb-25-2016/i-gnMsX2r/1/X2/216A4682-X2.jpg
Past Equipment | My Gallery (external link)
kckmarc
Joined Nov 2016
Apr 24, 2017 10:45 |  #4
those are 10k+ on the 7d2, wow. very nice. maybe i should work on my post production NR skills
sapearl
sapearl's Avatar
Gallery: 63 photos
Cleveland, Ohio
Apr 24, 2017 11:00 |  #5
kckmarc wrote in post #18336942 (external link)
ACR actually works pretty competently under those circumstances, so long as you nail the exposure reasonably well. I'm only using the 5D3 but routinely get beautiful results from ISO 6400, post processing the RAW file in ACR and then sharpening to taste.
MY WEBSITEexternal link- MY GALLERIESexternal link- MY BLOGexternal link
Artists Archives of the Western Reserveexternal link - Board
John ­ Sheehy
Post has been edited 9 months ago by John Sheehy.
Apr 24, 2017 12:00 |  #6
Every camera has its inherent noise, but lots of times, noise is much more visible than it needs to be because of processing and display methods.
Just one very vivid case in point: If you have the image viewing program, "Faststone Image Viewer", load a full-res very high ISO image into it, and go to fullscreen mode. If you bring the pointer down to the left end of the screen at the bottom, a toolbar opens with a checkbox that says "Smooth". Check and uncheck this box, and look at how the noise changes in the image. Two people, using this same software, not aware of the "Smooth" option, would get very different impressions of the same image, noise-wise! These kinds of illusion are rampant in people's experiences with cameras.
As objective as imaging might at first seem, it is far from it in the way it is generally experienced.
If you make a triptych of 3 different full-resolution conversions of the same high-ISO file, one with lots of NR and no sharpening, one medium, and one with no NR and lots of sharpening, take the same 1/3 from each image to make the triptych, and then toggle the "Smooth" button again. You will see a much greater range of apparent noise than just with the single conversion. You can use the + and - keys to change the zoom ratio, and you will see that the smaller you make the full image, the worst it gets with "Smooth" turned off. Lots of folks don't even know if their processing or viewing methods have "Smooth" off or on!
Over-sharpening for the task at hand, and poor resampling methods, can both destroy an image, relative to what it can be.
Dan ­ Marchant
Dan Marchant's Avatar
Joined Oct 2011
Where I'm from is unimportant, it's where I'm going that counts.
Apr 24, 2017 23:20 |  #7
...I've had the 7d2 for the speed only to have issues with iso tolerance and cropped sensor and considering the upgrade to 5d3 or 4 slightly slower but better low light ability. anyone made this switch? the decrease from 10fps to 6fps feel significant?
I went to the slower 5DIII and had no issues with the fps but then I'm not your normal sports shooter. I have found that the more I shoot sports the less shots I actually take. I rarely take bursts and if I do it is usually just three or four shots. I find I get a much better keeper rate if I am more deliberate about my shots and work on perfecting my timing instead of hoping the camera catches the action.
Dan Marchant
12Rock
Apr 25, 2017 13:19 as a reply to TeamSpeed's post |  #8
amazing shots , how i wish
TeamSpeed
01010100 01010011
TeamSpeed's Avatar
Gallery: 63 photos
Joined May 2002
Northern Indiana
Apr 25, 2017 13:24 |  #9
12Rock wrote in post #18338153 (external link)
Thank you! The 2nd shot would be better if the defensive player didn't have a head coming out of his shoulder though. :D
john ­ crossley
john crossley's Avatar
The Rhubarb Triangle
Apr 25, 2017 13:55 |  #10
I suppose a lot depends on what sports you are photographing and your shooting style/technique.
Some days I'm the dog, some days I'm the lamppost.
ScooterShooter
Joined Feb 2015
Akron, Ohio
Jun 14, 2017 12:03 |  #11
TeamSpeed wrote in post #18338162 (external link)
And I'd like to see the ball and some feet. But colors and clarity are great.
Nikon D5300, D610 | Nikon AF-S Nikkor 85mm f/1.8G, AF-S DX Zoom-Nikkor 18-135mm f/3.5-5.6G IF-ED, AF-S VR Zoom-Nikkor 70-200mm f/2.8G IF-ED, AF-S Zoom-Nikkor 24-70mm f/2.8G ED |
5,203 views & 5 likes for this thread
speed vs exposure
made in Finland
by Pekka Saarinen
Spent 0.00089 for 4 database queries.
PAGE COMPLETED IN 0.03s
Latest registered member is seattletan
1016 guests, 476 members online
